I have a USB mouse and keyboard, if that matters. That is asked a lot in similar topics to mine.
I use Qubes like normal, then after some time, it begins stuttering and lagging. It’s very much apparent in the cursor that seemingly teleports instead of moving smoothly.
The problem manifests persistently within a few hours following each system restart and continued use.
That fixed it. 400 MB is nowhere near enough memory. Is this information included anywhere? Someone should add it to the docs if it isn’t included yet.
I believe it’s also CPU-related. Increasing the vcpu count helped, I think.
You may find that this stuttering recurs despite your increasing sys-usb’s memory assignment. If so, next time you could restart just sys-usb rather than your whole system- a less disruptive mitigation.
I could bet it’s not about memory assigned. Because I thought so too and gave it over 1,5GB, but that didn’t resolve it. The only thing that helped was (and still is) to shutdown and start sys-usb again (not only to restart in my case).
Which makes me think it’s some kind of memory leak, actually. The same happens when I switch keyboard layout, but this time to whole Qubes.
