Will keyboard layouts horror be ever resolved
If I’m not the only one to have massive issues with switching keyboard layouts in dom0, of which the most horrifying are: it doesn’t work always, it works after tens of times switching cycles and the worst one that it causes massive lag response of a whole dom0 (not inside already opened qubes) nevertheless if it works or not but just on a switch attempt, may I then ask will this basic funcitonality be ever resolved after more than 10 years of Qubes?
Whenever I need to switch it I hesitate to do it, because very soon after that I’m getting pissed off of the lag response of dom0 measured in tens of seconds after any action taken, and the only solution is to reboot Qubes, which also takes time and I have a lot of opened qubes opened by default, so I need like 15-30 minutes to get where I was before the lag.
Jesus…
First of all I understand your frustration, I would also consider this issue to be a blocker and release nothing new until this basic functionality issue is completely solved.
About 10 years: no, it was working properly in R4.0, at least for me. So, it is a major regression (probably the biggest of all time Qubes OS exists). And the problem was not address for a long time. Layout switching was broken in R4.1 due to the new layout propagation approach and this dramatic change was not even mentioned in the R4.1 changelog.
On R4.1 there were at least 4 separate bugs in managing keyboard layout. Most of them has been fixed recently, not sure if they are already updated with dom0 updates, though. But the delay when switching is still not fixed, as I understand. I diagnosed the issue and reported, but it has not been not addressed yet.
You can post your concerns on github in the linked issues, because it seems that devs are not reading forum actively nowadays, or at least do not reply.
Read more about layout switching issues of R4.2 and the progress of solving them here:
I meant with this that after 10 years of developing a product the one mustn’t allow basic functionalities not to function for more than couple of (basic) time units. Like flying to the Moon, then gong back to the ship for every breath take.
Step aside it’s about basic functionality, if this forum serves as a stop-by for a github redirection, then it is a regression per se, because, then it can’t be considered as a “knowledge base” founded by the team.
Although aware of the github, grateful for the links, though
Just to be clear, I was not sending you to github as “you should not complain on forum”.
No, it was a polite saying that the solution for this issue can be archived more effectively there, that’s all.
You are welcome.
I am also concerned about these layout switching issues and even was helping to fix them.
Of course, of course. It’s the lack of live face to face communication that brought this possible misunderstanding when there was no room for it.
So, I left the computer without restart and it became absolutely unresponsive after a day. To me, it looks as an obvious memory leak in dom0 caused by keyboard layout switch.
Best regards
It is definitely a problem that can be reported, especially in case it is reproducible.
But why do you think it is caused by keyboard layout switch? The code processing layout change is invoked mostly only when XKLAVIER_ALLOW_SECONDARY event is fired (on layout change).
Main devs and contributors use only 1 layout I think, because of this we have this problem
The horror continues. Is this a horror or am I exaggerating?
Look, I don’t want to be personal. I don’t care. It’s basic functionality. You know what I mean? It’s not about sys-gpu, or complex things like that.
It’s horror over basic functionality.
Still not resolved even under 4.2x. JC…
… and it looks even more horrific under v4.2x. Now keyboard layout switching seems to occur randomly, without my interaction, causing massive lags (memory leaks?), so to end the horror, I had to remove all layouts except English default one.
I hope @alimirjamali will have time and strength to fight this as he promised to try, when for a decade and a half no one else didn’t want with this basic functionality.
:sweat_smile:
It took over one year :man_facepalming:
Hear, hear!
A billion thanks to @alimirjamali or anyone who worked on this issue, the multiple keyboard layout switching horror has finally ended in 4.3!
I’ve been testing it by adding four layouts and rapidly switching between them, and the system hasn’t picked the wrong one even once.
Great work!
Can you please check 2 layouts with capslock for the first, and shift+capslock for the last?
Just tested it with two layouts: Caps Lock reliably switches to the first layout, and Shift + Caps Lock to the last one. Also tested while rapidly switching between them, worked perfectly, no glitches at all!
Awesome. Thank you and thanks to @alimirjamali!
Has something changed in the keyboard layout mechanism? It recently started causing issues again. It wasn’t doing this before, but now switching layouts is unreliable, sometimes it works correctly, sometimes it doesn’t.
I’m wondering if changes elsewhere have broken this. The problem is specifically occurring in Whonix workstation based App qubes.
I have been using ‘Win+Space’ for switching layouts since I started using Qubes and it always results in the space being actually typed in the focused VM.
