Improving video playback speed?
I am looking for the proper “qubes way” to have decent video playback performance inside a qube (DispVM or AppVM). I am aware of the lack of hardware video acceleration in Qubes OS.
What I have tried so far:
  • mpv
  • mplayer
  • vlc
  • playing a file in browser (Firefox or Tor Browser)
Results (on a 2K screen, tested with a 480p MP4 file, CPU i7-10610U, no external GPU):
  • mplayer can play the video smoothly, as long as it is not full screen (then video lags after audio). Usually having it cover 1/4 of the screen surface ensures proper playback speed. If I speed it up though (e.g. x1.5 or more), it starts to choke.
  • mpv - worse
  • vlc - slightly better performance. Full screen playback is possible at 1x but not really smooth.
  • browser - best so far. No problem to play full screen at x1.5 speed. It feels awkward to use a browser for this though (and the player is not really full featured).
What is your experience with that?
How do you play HD videos in full screen?
I’m sure you’ve tried this, but just for completeness’ sake: assigning all CPU cores and enough RAM to the VM in which the video is supposed to be played, as well as playing it “locally”, i.e. the video file resides in that VM is going to improve performance. Note that if the number of assigned cores is changed on a running VM the VM needs to be restarted for those changes to take effect.
Personally I’ve had no troubles so far with both YT (if disabling “Ambient Mode” in the player) and local video files using VLC and Totem, but I do notice problems if I don’t assign all cores to the VM and it’s a Full HD high bitrate video.
Try mpv --vo=x11 --profile=sw-fast
--vo=x11 is the most important part.
This is what worked for me in fedora-38 template:
Install these packages, one line per command
# install vlc vlc-extras python3-vlc vlc-core vlc-devel phonon-qt5-backend-vlc libvlcpp-devel
# install pulseaudio-qubes --allowerasing
# install qubes-audio-daemon
As for browser, brave works best for me.
Thanks for the info!
@Bearillo
Re. “locally” and the rest: the whole DispVM is in RAM, including the MP4 file. So, that should not be a bottleneck.
I am reading the man page of qvm-prefs which says:
       vcpus  Accepted values: no of CPUs
              Number of CPU (cores) available to VM. Some VM types (eg DispVM) will
              not work properly with more than one CPU.
What does “properly” mean though?
I have just tried what you suggest with mplayer and the result in full screen is still the same.
@rustybird
Without --profile=sw-fast (only --vo=x11) mpv is still not so good.
However, with both options 1080p flies in full screen, even at x4 speed!
Thank you!
@tempmail
I am running a minimal debian template. From the packages you recommend, I have only pulseaudio-qubes and it seems sufficient for mpv.
What is “–allowerasing” for?
Good question, I didn’t even know about that warning :smile:
For me it definitely improves playback if I assign more cores to the VM and I’ve so far always used disposables for playback (setting the core number higher in the dvm-template beforehand…one could also create a separate dvm-template for that, but I don’t watch videos often).
Ah, you’re probably on Debian 11? That would explain it, because I just noticed that before Debian 12 they used to build mpv without the zimg library for scaling, and --profile=sw-fast seems to make a bigger difference without it.
Enjoy, mpv is awesome.
@Bearillo
What is your CPU?
@rustybird
I am on Debian 12 minimal (cloned + mpv installed).
It is! I have enjoyed it on GPU accelerated Linux distros. Now, on Qubes OS too :slight_smile:
i7-1260P, so 12 physical cores and I’m not using SMT, but Turbo is on, though the cores do scale very well (using hwp). I noticed early on that having only 1 or 2 cores for a VM would lead to the laptop running hot and the fans being loud quite often, presumably because those cores then go to P1 and switch Turbo on; so I usually give 6-8 cores to each VM, with one exception being in case of video playback, where I make it 12.
Interesting. 2 vcpus work fine on the much weaker CPU here with the mpv settings @rustybird shared.
Huh…I guess I gotta give mpv a try then!
Edit: ok wow so mpv even without the two aforementioned options is already 20% lower in CPU usage than totem and with the two options it’s a whopping 4 times better! (uses 4-5 times less CPU as per qubes widget)
And all without any noticeable drop in quality, though this was only a quick test with one HD video.
Is there a way to pass parameters via qvm-open-in-dvm so that when I play a video in a disposable and have mpv set as mime-default there it will use the two parameters automatically?
Edit2: never mind, I just added the params to the desktop file in the template and for some reason it performs even better now in a second test (5-7 times less CPU!!!). Awesome.
I recommend using smplayer with mpv backend with x11 output driver selected in its settings for video output.
Also related topic about youtube playback (maybe you find something useful there):
It is a shame, that Qubes OS provides default templates with some mediocre players that are several times slower than mpv/mplayer/smplayer, that is crucial in Qubes OS with no hardware acceleration.
And 99% of Qubes OS users have garbage video experience out of the box, maybe even losing interest in Qubes OS as it looks like it is not able to play 1080p on their PC.
(Part of) the reason may be the fact that mplayer and smplayer are not on default template’s (Fedora’s) default repos. mpv is though, so I don’t know.
Have you tried submitting an issue about that?
Do I correctly recall unman had some multimedia template?
Of course it is. Nonetheless, something should be done about it. Because these mediocre out of box players do work good enough on GNU/Linux, so it is much more drastic problem for Qubes OS.
I did not submit enhancement issue on the tracker about that, if I recall correctly, because the team is overwhelmed with other things. Maybe it should be done, though, to be useful in the future.
I am personally waiting more for my qubes completion contribution being reviewed and possibly added to the system upstream.
So, we can hopefully help with useful suggestions:
qubes completion
Do you have a forum thread about it?
Yes
Summarized setting up mpv as recommended here and also ytfzf in my guide.
Thanks for the tips that lead to it!
