I get the following error:
qrexec-daemon startup failed: 2024-05-31 19:35:50.215 qrexec-daemon[10354]:
qrexec-daemon.c:144:sigchld_parent_handler: Connection to the VM failed
I’ve already tried to install it several times, it only works on my main storage disk.
How did you setup your secondary storage?
How are you trying to create template/standalone there?
Can you create app qube in your secondary storage?
did you look at this documentation?
Yes, I can create an AppVM, but not a template or standalone.
When I try to create a template or a standalone, I put my vpn in the NetVM, debian-xfce template, and qubes2storage in the storage pool
What’s your secondary storage disk sector size?
Check it in dom0 terminal with sudo fdisk -l command.
When I put the command on, a lot of things come out
Sector size: 512 bytes / 4096 bytes
That’s is of my secondary storage
Are you getting these errors:
When you try to create the template/standalone or when you try to start the created template/standalone?
Are you creating the standalone/template using GUI tool “Create New Qube” or “Create Qubes VM” or using the terminal command e.g.:
qvm-create -P poolhd0_qubes --standalone --label red unstrusted-hdd
You’re right, I was wrong, that’s when I try to start a template/standalone
I create the template/standalone from the GUI, and when I start it I get that error.
MaiseyEllie:
Are you trying to creating template or app qube? If template then you shouldn’t set NetVM for it.
Try to clone the template (e.g. debian-12-xfce) to the second storage pool and start this template.
You can clone it in template Settings or using qvm-clone command.
Check the logs in dom0 of Xen and the standalone/template that is failing to start.
/var/log/xen/console/hypervisor.log
/var/log/xen/console/guest-VMNAME.log
The cube app lets me start, but when I try to start a template or standalone, I get that error. I want now is to start a standalone
Try to clone the template and start it for a test first.
[ 0.266762] ACPI Error: No handler or method for GPE 07, disabling event (20230628/evgpe-839)
And in the end
[2024-06-01 13:40:02] [ 1.477104] Code: c3 12 00 48 8b 35 6a c3 12 00 48 8b 05 7b c3 12 00 e9 7c fe ff ff 66 0f 1f 44 00 00 f3 0f 1e fa 48 63 ff b8 e7 00 00 00 0f 05 <ba> 3c 00 00 00 0f 1f 44 00 00 48 89 d0 0f 05 eb f9 90 41 56 41 55
[2024-06-01 13:40:02] [ 1.477173] RSP: 002b:00007ffd3301b208 EFLAGS: 00000246 ORIG_RAX: 00000000000000e7
[2024-06-01 13:40:02] [ 1.477206] RAX: ffffffffffffffda RBX: 0000000000000001 RCX: 0000000000423f5e
[2024-06-01 13:40:02] [ 1.477237] RDX: 6f2e73776472ff09 RSI: 0000000000000000 RDI: 0000000000000001
[2024-06-01 13:40:02] [ 1.477267] RBP: 00007ffd3301b460 R08: 0000000000000000 R09: 0000000000000000
[2024-06-01 13:40:02] [ 1.477298] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000517a7f
[2024-06-01 13:40:02] [ 1.477328] R13: 000000000051f671 R14: 0000000000000002 R15: 0000000000000000
[2024-06-01 13:40:02] [ 1.477362] </TASK>
[2024-06-01 13:40:02] [ 1.477504] Kernel Offset: disabled
Can you upload the full log?
