I have a Kali HVM successfully running with LAN and internet access. I’ve confirmed this by successfully browsing the internet and connecting via LAN to other machines on the local network.
I need to set up my Qubes system so that i can start a netcat session on my Kali HVM and connect to it from other computers on my LAN network.
If you are not able to allocate a specific NIC to Kali, then you can use this script to open a port on sys-net and forward traffic through the
Qubes networking stack to Kali.
I just plugged it in and assigned via the USB devices taskbar item and receive the following error:
Error: QubesVMError - Domain ‘kali’ qrexec not connected
Installed by downloading the ISO and installing much like a regular ISO based install.
Could i be missing some extra steps in the qube settings for the HVM?
I might just ditch the HVM and stick with the template. Thanks for the assistance all.
The instructions from @BEBF738VD and script from @unman will prove extremely useful going forward, much appreciated!
Also to confirm, is this the correct way to fix the key issues for the Kali template to be able to update?
