Hello,
Attempted an in-place upgrade from 4.0 to 4.1 but experiencing an issue booting any AppVM or TemplateVM other than dom0. The error message returned is:
“Cannot connect to qrexec agent for 60 seconds, see /var/log/xen/console/guest-sys-net.log for
details”
When checking the log file for errors, I see a systemd error message:
systemd: systemd-fsck-root.service: Main process exited, code=exited, status=1/FAILURE
systemd-fsck-root.service: Failed with result ‘exit-code’
Failed to start File System Check on Root Device
from reading some of the other forum posts regarding this upgrade, it seems there is an issue with
the qrexec-agent version of the VM as compared with the qrexec-daemon version running in dom0
This part in particular:
After reviewing what each stage does, I’m left with the impression that stage1 updates VM with 4.1 qrexec-agent, which fails to work with 4.0 qrexec-daemon, and that the 4.1 qrexec-daemon only gets installed in stage4.
Indeed this is exactly what happens. New qrexec-daemon works with old qrexec-agent, but not the other way around. The VM update is put before dom0 update only to allow saving one reboot during the process - otherwise VM can be updated after dom0. And in fact you can do that - proceed with subsequent stages and retry sage 2 at the end.
When attempting to run STAGE4, the same qrexec error returns and the stage fails.
Prior to attempting the upgrade I made a backup of all the VMs on an external media.
My question is… how best to proceed at this point? When I connect any external device using USB,
it’s not recognized by dom0 and the USB qube will not boot at all due to the fedora-33 template
dependency.
Thank You
