My working way to set up NetVM via VLESS protocol on sing-box to bypass restrictions:
ISP → sys-firewall → sys-vless → other cubes/NetVMs
Create an AppVM named “sys-vless”, which we want to turn into a NetVM for other cubes. This part is simple, let’s continue inside this VM…
Step 1: Download the archive with the appropriate binary here: Releases · SagerNet/sing-box · GitHub
I used the latest stable release, v1.12.8, at the time of publication.
For later alpha versions of sing-box, you will need to refactor the config file as its structure changes.
wget https://github.com/SagerNet/sing-box/releases/download/v1.12.8/sing-box-1.12.8-linux-amd64.tar.gz
sha256sum sing-box-1.12.8-linux-amd64.tar.gz
b41d9ae438a4367e5fd5c4aa36fe040d0c1bfe5f91f96a072eef31f61d46670c sing-box-1.12.8-linux-amd64.tar.gz
tar -xf sing-box-1.12.8-linux-amd64.tar.gz
mv sing-box-1.12.8-linux-amd64.tar.gz .
Step 2: Extract the sing-box binary from the downloaded archive and move it here:
/usr/local/bin/sing-box
Step 3:
Create the config file at:
/rw/home/user/config.json
config.json
"log": {
"disabled": true,
"level": "warn",
"output": "box.log",
"timestamp": true
"experimental": {
"cache_file": {
"enabled": true,
"path": "clash.db",
"store_fakeip": false,
"store_rdrc": false
"dns": {
"rules": [
"query_type": [
"A",
"AAAA"
"server": "fakeip"
"clash_mode": "Proxy",
"server": "remote"
"clash_mode": "Direct",
"server": "local"
"server": "remote"
"servers": [
"type": "https",
"server": "1.1.1.1",
"detour": "proxy",
"tag": "remote"
"type": "https",
"server": "223.5.5.5",
"tag": "local"
"type": "hosts",
"path": [],
"predefined": {},
"tag": "block"
"type": "local"
"type": "fakeip",
"inet4_range": "198.18.0.0/15",
"inet6_range": "fc00::/18",
"tag": "fakeip"
"strategy": "prefer_ipv4"
"inbounds": [
"address": [
"10.139.1.0/30",
"fdfe:dcba:9876::1/126"
"route_address": [
"0.0.0.0/1",
"128.0.0.0/1",
"::/1",
"8000::/1"
"route_exclude_address": [
"192.168.0.0/16",
"172.16.0.0/12",
"fc00::/7",
"10.137.0.0/16",
"10.138.0.0/16",
"fd09:24ef:4179::a89:0/112",
"fd09:24ef:4179::a8a:0/112"
"stack": "gvisor",
"auto_route": true,
"strict_route": true,
"sniff": true,
"type": "tun"
"listen": "127.0.0.1",
"listen_port": 2333,
"tag": "mixed-in",
"type": "mixed",
"users": []
"outbounds": [
"tag": "proxy",
"type": "selector",
"outbounds": [
"auto",
"direct",
"VLESS"
"tag": "auto",
"type": "urltest",
"outbounds": [
"VLESS"
"url": "http://www.gstatic.com/generate_204",
"interval": "10m",
"tolerance": 50
"type": "vless",
"tag": "VLESS",
"server": "YOUR_VLESS_SERVER_DOMAIN",
"server_port": YOUR_PORT,
"uuid": "YOUR_UUID",
"flow": "xtls-rprx-vision",
"tls": {
"enabled": true,
"server_name": "google.com",
"utls": {
"enabled": true,
"fingerprint": "chrome"
"reality": {
"enabled": true,
"public_key": "YOUR_PUBLIC_KEY",
"short_id": "YOUR_SHORT_ID"
"packet_encoding": "xudp"
"type": "direct",
"tag": "direct"
"route": {
"auto_detect_interface": true,
"default_domain_resolver": "local",
"final": "proxy",
"rules": [
"action": "sniff"
"protocol": "dns",
"action": "hijack-dns"
"outbound": "direct"
"outbound": "proxy"
"ip_is_private": true,
Replace the following lines with those provided by your VLESS provider:
YOUR_PORT
YOUR_UUID
YOUR_PUBLIC_KEY
YOUR_SHORT_ID
Step 4: Run Vasya, run:
sudo sing-box run -c /rw/home/user/config.json
Step 5:
Set up sing-box to auto-start with the current NetVM:
Add the following line to bottom of /rw/config/rc.local:
sing-box run -c /rw/home/user/config.json &
Step 6:
The traffic will go to IP 223.5.5.5 and the IP associated with your VLESS server, so configure access only to them through qvm-firewall, everything else should be dropped.
Example firewall rule configuration:
NO ACTION HOST PROTOCOL PORT(S) SPECIAL TARGET ICMP TYPE EXPIRE COMMENT
0 accept 223.5.5.5/32 - - - - - -
1 accept 1.2.3.4/32 - - - - - -
2 drop - - - - - - -
VLESS will work!
If anyone has specific suggestions for improving the config, security, or approach, I would be happy to see your comments. Thanks!
