How to install Obsidian with snap
I unsuccessfully try to install Obsidian with the QubesOs Documentation .
In the Fedora-39-template I install snapd and qubes-snapd-helper and in the folder of the AppVM where I downloaded the snap-package I run:
snap install obsidian_1.5.12_amd64.snap --dangerous --classic
The Option –user was not accepted.
Following Error appears:
error: cannot install snap file: classic confinement requires snaps under /snap or symlink from /snap to /var/lib/snapd/snap
How to solve?
What if you create the required symlink in AppVM?
sudo ln -s /var/lib/snapd/snap /snap
Will the error disappear?
If it’ll work then you can add this command in AppVM’s /rw/config/rc.local.
The same error occurs again.
I created the folder /snap and executed the symlink in my AppVM.
You didn’t have to create a /snap directory, only symlink.
Remove the directory and create only symlink.
Perfect, that was the clue! :ok_hand:
