How to configure GUI for built-in HDPI display of laptop
I need help for setting up GUI parameters for the built-in HDPI-display of laptop.
I want to control the font-size, the icon-size and vertical height of
  • the menu of the screen,
  • the window title bar of the title like dom0, work, personal,
  • the title of the application,
  • the menu of the application,
  • the contents of the window of the application.
My laptop is Zenbook UX8402ZE.
It has two displays.
  • Main Screen: 2880 x 1800
  • Second Screen: 2880 x 864
For an external display of size like 24 inches, this might not mean too small fonts/icons. But the built-in display is for A4-notebook PC.
My current configuration of GUI is scattered around various settings-applications.
Dom0 (Applications)---->System Tools —> Appearance
Style: Greybird-dark
Icon: Gnome (default Gnome Theme)
Font: Sans Regular 10, Monospace Regular 10
Custom DPI settings: 92
Settings: Enlarge windows (2 x)
I am trying two themes by switching them time to time.
Dom0 (Applications)---->System Tools —> Window Manager
Theme: Default-hdipi or Default-xhdip
I enable adjustment of icon-size in the menu-bar of the screen.
Dom0 (Applications)---->System Tools —> Panel (Xfce4-panel ?)
Appearance:
    Icon: Automatically Adjusting Size (Enabled)
I also use Dom0 (Applications)---->System Tools —> Desktop for controlling the height of the title-bar, menu-bar of the applications.
But there remain several issues.
  • The font and the icon of the menu-bar of the screen is too large so that the number of items on the menubar is very limited. I would like to tray the scaling like 1.4.
  • The font, the icon of applications Qube-Manager and Qubes-*** are still too small. The vertical height of the title and the menu are also too small.
  • I have difficulty in controlling the size of some of the icons at the top right of the menu-bar of the screen. (Two of them are controlled by automatic adjustment of size. The others do not follow this control.) Indeed, this is why I cannot use custom DPI for solving the issues.
These issues still remain after the solution I learned in the following topic.
There are more topics for the issues. However, some of them mentions X-something instead of Wayland. I am eager to know the solution for Wayland+Xfce.
For now, I want to concentrate on the main screen. (I have a project of using the second display for a specific purpose. But I must postpone it to February because of the lack of time.)
Thank you Atrate.
I’d like to know which file actually controls sizes.
I could not reproduce it. Maybe I misunderstood something.
I am trying a temporal workaround.
  • Give up HDPI while using Qube Manager and Qubes-applications.
  • Change the resolution of the main screen to 1920x1200.
  • Appearance-Settings->Enlargement Scaling 1x.
  • Appearance-Fonts->Custom DPI->144.
  • Window Manager->Theme->Default.
  • Window Manager->Title Font->12pts.
I would not call it a solution. But it is a workaround for the task of configuration of qubes.
Hi Tofu,
Thanks for the explanation; I was able to reproduce the issue you’re facing.
After examining the problem, I see that it needs to be resolved; however, despite my best efforts, I haven’t been able to fix it. This is because Qubes OS handles the user interface in a unique way, making the issue extremely complex and difficult to solve.
To be honest, I overpromised when I said I would solve your problem; it turned out to be beyond my capabilities.
I believe the solution you are currently using is the most realistic one available right now.
I apologize for not being able to help.
Thank you Ahmed_iMafraid!
Reproducing the symptom is a great step.
I think some other people know the issue. But I did not find the topic which gathers symptoms.
The next step is to call for more people who experienced the issues I listed.
Or more issues which are relavent.
