Continuing the discussion from Can't Access SSD as Secondary Storage:
@jamesfr can you explain what you’ve tried already and in what step you got stuck? Also have you read the community doc on this, yet? (doc: network printer)
Moving @51lieal’s reply here so we keep therads organized
Quoting from the other thread:
For the printer issue : I am using a Brother MFC-L8690CDW, which is plugged on Ethernet to my router, but Qubes is on another Internet Provider router… I tried to install the packages for Brother with a file that does install scanner and printer drivers, but it cannot connect to the IP address, and I noticed some failures during the installation.
So you want connect to brother that attached to A network with your PC (qubes os) within B network right? for that case you should set up vpn on printer server and the PC (qubes os) connect to A network with vpn. It should work.
