Help regarding setting up the pihole and split gpg with mutt
Hello qubers,
I need your thoughts on below:
  1. I have installed qubes-task-gui and then set up Pi-hole using the 3isec tools. After installation, I changed the NetVM of all my AppVMs to the Pi-hole VM. However, none of the VMs have internet access now. I reviewed the Qubes OS documentation on networking for HVMs, and while I can view the connection details of the Pi-hole standalone VM, I’m unsure how to correctly configure the netmask, gateway, or IP settings as described. Could you guide me through properly setting up networking for the Pi-hole VM?
  2. How can I correctly configure Split GPG and mutt (from the 3isec repo) to work with my Nitrokey 3A Mini, which I’m already using for HOTP-based verification in Heads?
  3. Since my Nitrokey already contains my GPG key, can I reuse this same key for Split GPG and mutt in Qubes, or do I need to generate and use a different key?
Thanks in advance for your help!
The code from the following guide may be useful, or you may find Blocky preferable to Pi-hole…
Thanks for your suggestion. I will go with this approach.
