I’ve read through this similar forum thread about VMs that disappeared. The user’s VMs’ logical volumes were somehow deactivated and thus wouldn’t boot, though dom0 was fully accessible.
I seem to have a similar issue.
Output of lvs:
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
root qubes_dom0 Vwi-aotz-- 20.00g root-pool 49.85
root-pool . twi-aotz-- 20.00g 49.85 29.62
swap . -wi-ao---- 3.75g
vm-1-private . Vwi---tz-- 2.00g vm-pool ...
vm-1-root . Vwi---tz-- 10.00g vm-pool ...
vm-1-date-back . Vwi---tz-- 10.00g vm-pool
vm-2-private . Vwi---tz-- 10.00g vm-pool ...
vm-pool . twi---tz-- 339.55g
vm-n-date-back . Vwi---tz-- 2.00g vm-pool
Output of pvs:
PV VG Fmt Attr PSize PFree
/dev/mapper/luks-... qubes_dom0 lvm2 a-- 455.24g 90.84g
Output of vgs:
VG #PV #LV #SN Attr VSize VFree
qubes_dom0 1 216 0 wz--n- 455.25g 90.84g
Output of vgscan:
Found volume group "qubes_dom0" using metadata type lvm2
Output of lvscan --all:
inactive '/dev/qubes_dom0/vm-pool' [339.55 GiB] inherit
ACTIVE '/dev/qubes_dom0/root-pool' [20.00 GiB] inherit
ACTIVE '/dev/qubes_dom0/root' [20.00 GiB] inherit
ACTIVE '/dev/qubes_dom0/swap' [3.75 GiB] inherit
inactive '/dev/qubes_dom0/vm-...-{private,private-snap,date-back,root,root-snap,volatile,}' [XX.00GiB] inherit
ACTIVE '/dev/qubes_dom0/root-pool_tmeta' [24.00 MiB] inherit
ACTIVE '/dev/qubes_dom0/root-pool_tdata' [20.00 GiB] inherit
Seeing as my qubes’ thin volumes were inactive, and seemingly not missing (as they were in the linked thread), I tried to activate a private volume using the command given in the thread.
Output of lvchange -a y /dev/qubes_dom0/vm-1-private:
Thin pool qubes_dom0-vm--pool-tpool (253:9) transaction_id is 39358, while expected 39360.
I made a backup of my volume group configs using vgcfgbackup and examined the file for transaction IDs. Interestingly, the transaction id for the vm-pool logical volume is 39358, and the last transaction id to apparenty occur for a VM (succeeded by transaction IDs for lvol0_pmspare, vm-pool_tmeta, vm-pool_tdata, root-pool_tmeta, and root-pool_tdata) is 39357
qubes_dom0 {
id ...
status = ["RESIZEABLE", "READ", "WRITE"]
flags = []
physical_volumes {
pv0 { ...
logical_volumes {
vm-pool {
id ...
status = ["READ", "WRITE", "VISIBLE"]
flags = []
creation_time ...
creation_host ...
segment_count = 1
segment1 {
type = "thin-pool"
metadata = "thin-pool_tmeta"
pool = "vm-pool_tdata"
# Look here transaction_id = 39358
vm-1-private-snap {
id ...
flags = []
creation_time ...
creation_host ...
segment_count = 1
segment1 {
type = "thin"
thin_pool = "vm-pool"
# Look here transaction_id = 39357
Maybe something is wrong with the order of my transaction IDs? As noted above, lvchange expected an ID of 39360, but the metadata backup only goes as high as 39358 (in the 39xxx range).
I should add that I tried to add some space for metadata before editing my lvm.conf by following the instructions linked in this forum comment. Based on my ~/.bash_history, I ran these commands:
swapoff -a
lvresize -L -200M qubes_dom0/swap
swapon -a
swapoff -a
swapon -a
mkswap /dev/qubes_dom0/swap
swapon -a
lvextend --poolmetadatasize +200M qubes_dom0/vm-pool
