layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
Acer
model: |
Swift SFG16-71
bios: |
V1.10
cpu: |
13th Gen Intel(R) Core(TM) i5-13420H
cpu-short: |
FIXME
chipset: |
00.0 Host bridge [0600]: Intel Corporation Device [8086:a716]
chipset-short: |
FIXME
gpu: |
02.0 VGA compatible controller [0300]: Intel Corporation Raptor Lake-P [UHD Graphics] [8086:a7a8] (rev 04) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
14.3 Network controller [0280]: Intel Corporation Raptor Lake PCH CNVi WiFi [8086:51f1] (rev 01)
memory: |
16071
scsi: |
usb: |
4
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.3-alpha
xen: |
4.19.1
kernel: |
6.12.16-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
While using 4.3 alpha, I had no problems using basic functionality of Qubes OS (running Linux qubes for work, using qubesctl command for salting corrupted default qubes such as sys-whonix, etc). However, I was hoping to use my Yubikey C Bio for multi-factor login in Qubes OS 4.3, since there was no existing Yubikey support until today (but Iβm not sure whether I can use it anyways because this is the FIDO2 edition).
(second paragraph moved into appropriate category β /Sven)
qubes4.3alphaacerswiftgosfg1671by.yml (884 Bytes)
