Guide: Kicksecure for DISP-sys*
Introduction:
I will explain how I created a disposable sys-usb, sys-net, sys-firewall off a debian-11 minimal template with Kicksecure and other hardening features from the Kicksecure checklist.
Assumptions:
  • Qubes R4.1.1
  • Comfortable with bash
  • This guide wasn’t meant to be introduction to kicksecure and the features installed. It is expected you have read up on kicksecure and understand, LKRG, tirdad, malloc hardening and appamor. There are various settings you have for all of these. This is the setup I’m happy with and works for me. You may need to change it to suit your setup.
  • Using the latest debian bullseye-backports kernel for the LKRG and tirdad. You could use the standard kernel and headers in bullseye but its rather old and I haven’t tested it. It’s older than the standard Qubes kernels used in Dom0 and VMs so I opted for a newer one.
Recommended reading:
Requirements:
  • Using Dom0 for generating templates
  • Using @Sven method for creating templates ( thanks Sven)
  • Using a USB qube for deb-11-sysusb
Note:
You are adding another repository with a number of software packages to be installed. You need to consider the risks associated with this, and consider how well you trust the sources of the software. Like always if you have the ability and time it is recommended to review the code before using it.
Kicksecure is new and I haven’t done extensive testing, so I can’t guarantee this won’t break anything. That being said i’ve had no problems since I’ve set it up.
Creating Debian minimal templates
This is nothing more than @sven method. Look here for more details.
Note: I strongly suggest reading through that guide and understanding it. I’ve attached my deb-11-min template. As you can see it has parts commented out. These sections won’t work unless you have followed the guide for dark themes.
Steps:
  1. Create the deb-11-min template in a folder on your dom0. I have mine in ~/scripts/
#!/bin/bash
SOURCE_TEMPLATE=debian-11-minimal
TARGET_TEMPLATE=deb-11-min
# download, clone
# I commented out remove as it will be used many times.
# Up to you if you want to remove it after each template is generated.
qvm-template install $SOURCE_TEMPLATE
qvm-clone $SOURCE_TEMPLATE $TARGET_TEMPLATE
#qvm-remove -f $SOURCE_TEMPLATE
qvm-run --pass-io -u root $TARGET_TEMPLATE "rm -Rf /home/user/QubesIncoming"
# copy themes ( I'm using dark themes, i use both Yaru-dark and Arc-Dark
# you will need to have them installed in dom0 if you want to use.
#Commented out for that reason. If you want dark themes
#qvm-copy-to-vm $TARGET_TEMPLATE /usr/share/themes/Yaru*
#qvm-copy-to-vm $TARGET_TEMPLATE /usr/share/themes/Arc*
#qvm-run --pass-io -u root $TARGET_TEMPLATE "rm -Rf /usr/share/themes/Yaru*"
#qvm-run --pass-io -u root $TARGET_TEMPLATE "mv /home/user/QubesIncoming/dom0/Yaru* /usr/share/themes/"
#qvm-run --pass-io -u root $TARGET_TEMPLATE "mv /home/user/QubesIncoming/dom0/Arc* /usr/share/themes/"
#qvm-run --pass-io -u root $TARGET_TEMPLATE "rm -Rf /home/user/QubesIncoming"
# copy icons (i'm using themes, if you want to use dark themes look at the qubes post and
# uncomment
#qvm-copy-to-vm $TARGET_TEMPLATE /usr/share/icons/Yaru
#qvm-run --pass-io -u root $TARGET_TEMPLATE "rm -Rf /usr/share/icons/Yaru*"
#qvm-run --pass-io -u root $TARGET_TEMPLATE "mv /home/user/QubesIncoming/dom0/Yaru /usr/share/icons/"
# copy fonts
#qvm-copy-to-vm $TARGET_TEMPLATE /usr/share/fonts/ubuntu
#qvm-run --pass-io -u root $TARGET_TEMPLATE "rm -Rf /usr/share/fonts/truetype/ubuntu"
#qvm-run --pass-io -u root $TARGET_TEMPLATE "mv /home/user/QubesIncoming/dom0/ubuntu /usr/share/fonts/truetype/"
# setup /etc/X11/Xresources/x11-common
qvm-run --pass-io -u root $TARGET_TEMPLATE 'echo "Xft.dpi: 96" >> /etc/X11/Xresources/x11-common'
qvm-run --pass-io -u root $TARGET_TEMPLATE 'echo "XTerm*faceName: Ubuntu Mono" >> /etc/X11/Xresources/x11-common'
qvm-run --pass-io -u root $TARGET_TEMPLATE 'echo "XTerm*faceSize: 12" >> /etc/X11/Xresources/x11-common'
qvm-run --pass-io -u root $TARGET_TEMPLATE 'echo "XTerm*background: #300a24" >> /etc/X11/Xresources/x11-common'
qvm-run --pass-io -u root $TARGET_TEMPLATE 'echo "XTerm*foreground: linen" >> /etc/X11/Xresources/x11-common'
qvm-run --pass-io -u root $TARGET_TEMPLATE 'echo "XTerm*selectToClipboard: true" >> /etc/X11/Xresources/x11-common'
# install basic packages
qvm-run --pass-io -u root $TARGET_TEMPLATE "apt update && apt full-upgrade -y"
qvm-run --pass-io -u root $TARGET_TEMPLATE "apt install qubes-core-agent-passwordless-root qubes-app-shutdown-idle -y"
# set Xterm as default
qvm-run --pass-io -u root $TARGET_TEMPLATE "update-alternatives --set x-terminal-emulator /usr/bin/xterm"
# copy GTK configs and desktop shortcuts into /etc/skel
# you need to have these file in your Dom0. I'm using them for
# to have consistency between my themes. I've commeted out. If you want to do this look
# at dark themes guide on the qubes forum.
#qvm-copy-to-vm $TARGET_TEMPLATE ~/scripts/.gtkrc-2.0
#qvm-copy-to-vm $TARGET_TEMPLATE ~/scripts/settings.ini
#qvm-copy-to-vm $TARGET_TEMPLATE ~/scripts/qvm-open-in-vm-desktop.desktop
#qvm-run --pass-io $TARGET_TEMPLATE "sudo mkdir -p /etc/skel/.config/gtk-3.0"
#qvm-run --pass-io $TARGET_TEMPLATE "sudo mkdir -p /etc/skel/.local/share/applications"
#qvm-run --pass-io $TARGET_TEMPLATE "sudo mv ~/QubesIncoming/dom0/.gtkrc-2.0 /etc/skel"
#qvm-run --pass-io $TARGET_TEMPLATE "sudo mv ~/QubesIncoming/dom0/settings.ini /etc/skel/.config/gtk-3.0"
#qvm-run --pass-io $TARGET_TEMPLATE "sudo mv ~/QubesIncoming/dom0/qvm-open-in-vm-desktop.desktop /etc/skel/.local/share/applications"
#qvm-run --pass-io $TARGET_TEMPLATE "rm -Rf ~/QubesIncoming"
#qvm-run --pass-io -u root $TARGET_TEMPLATE 'echo "xdg-settings set default-web-browser #qvm-open-in-vm-desktop.desktop" >> /etc/skel/.bashrc'
# shutdown
qvm-shutdown --wait $TARGET_TEMPLATE
qvm-prefs $TARGET_TEMPLATE memory 400
qvm-prefs $TARGET_TEMPLATE maxmem 0
  1. Create add-feature-kicksecure
#!/bin/bash
# kicksecure.sh
# Distro morphing debian-11-minimal to Kicksecure
# URL: https://www.whonix.org/wiki/Kicksecure/Debian
qvm-run --pass-io --no-gui --user=root $1 'apt-get -y update && apt-get dist-upgrade'
# Some packages needed for kicksecure to install
qvm-run --pass-io --no-gui --user=root $1 'apt-get -y install zenity pulseaudio-qubes qubes-menus qubes-core-agent-networking qubes-mgmt-salt-vm-connector  grub2 qubes-kernel-vm-support'
# The next steps are straight from the kicksecure website but in a bash script
# This copies over their key and created the apt repo for kicksecure then installs kicksecure-cli
qvm-run --pass-io --no-gui --user=root $1 'apt-get -y install --no-install-recommends sudo adduser'
qvm-run --pass-io --no-gui --user=root $1 'addgroup -system console && adduser user console && adduser user sudo'
qvm-run --pass-io --no-gui --user=root $1 'apt-get -y install --no-install-recommends curl'
qvm-run --pass-io --no-gui --user=root $1 'curl --proxy http://127.0.0.1:8082/ --output derivative.asc https://www.kicksecure.com/derivative.asc'
qvm-run --pass-io --no-gui --user=root $1 'cp derivative.asc /usr/share/keyrings/derivative.asc'
qvm-run --pass-io --no-gui --user=root $1 'echo "deb [signed-by=/usr/share/keyrings/derivative.asc] https://deb.kicksecure.com bullseye main contrib non-free" | sudo tee /etc/apt/sources.list.d/derivative.list'
qvm-run --pass-io --no-gui --user=root $1 'apt-get update'
qvm-run --pass-io --no-gui --user=root $1 'apt-get dist-upgrade'
qvm-run --pass-io --no-gui --user=root $1 'apt-get -y install --no-install-recommends kicksecure-qubes-cli'
qvm-run --pass-io --no-gui --user=root $1 'mv /etc/apt/sources.list ~/'
qvm-run --pass-io --no-gui --user=root $1 'touch /etc/apt/sources.list'
# Installing latest kernel to be used by LKRG triad and other kernel hardening mods
qvm-run --pass-io --no-gui --user=root $1 'apt-get -t bullseye-backports -y --no-install-recommends install linux-image-amd64 linux-headers-amd64'
qvm-run --pass-io --no-gui --user=root $1 'grub-install /dev/xvda'
  1. Create add-feature-sysfirewall
#!/bin/bash
# Adding sys-firewall  support
echo +++ installing sys-firewall packages into  $1
qvm-run --pass-io -u root $1 "apt install --no-install-recommends qubes-core-agent-networking qubes-core-agent-dom0-updates -y"
  1. Creating the sys-firewall template
#!/bin/bash
 SOURCE_TEMPLATE=deb-11-min
 TARGET_TEMPLATE=deb-11-sysfirewall
 #clone
 #add features
 $(pwd)/add-feature-sysfirewall          $TARGET_TEMPLATE
 $(pwd)/add-feature-kicksecure          $TARGET_TEMPLATE
 #shutdown
 qvm-prefs $TARGET_TEMPLATE maxmem 4000
  1. After you have created those three files. You need to make them executable sudo chmod +x file
  2. run ./deb-11-sysfirewall this will create a deb-11-sysfirewall template that installs the features in the add-feature-sysfirewall and add-feature-kicksecure.
Install LKRG, tirdad, malloc and enabling apparmor
  1. We are using the Linux VM kernel from bullseye-backports this requires installing pvgrub2-pvh in dom0 as the deb-11-sysfirewall is PVH virtualisation. sudo qubes-dom0-update grub2-xenpvh
  2. Go to Qubes Manager and find the deb-11-sysfirewall. Click on settings → Advanced and change the kernel to pvgrub2-pvh, Then start the deb-11-sysfirewall. This will now boot with the latest kernel
  3. Open a xterm on deb-11-sysfirewall then check you are on the latest kernel uname -a
  4. Install Linux Kernel runtime guard (LKRG) sudo apt install --no-install-recommends lkrg-dkms
  5. Install tirdad sudo apt-get install tirdad
  6. restart deb-11-sysfirewall
  7. Check LKRG and tirdad is installed by sudo dkms status
  8. Install hardened Malloc echo "/usr/lib/libhardened_malloc.so/libhardened_malloc.so" | sudo tee /etc/ld.so.preload
  9. Enabling apparmor in Dom0. qvm-prefs -s deb-11-sysfirewall kernelopts "apparmor=1 security=apparmor"
These steps are the same for sysnet and sys-usb. However, sys-net and sys-usb should be set to HVM due to attachments of devices (ethernet and usb controller). Therefore you will have to make a slight change to step 2. Instead of pvgrub2-pvh you will need to put (none).
add-feature-sys-net
#!/bin/bash
# Adding sys-net support
echo +++ installing sys-net packages into  $1
# Note I have a Intel iwl wifi adapter if you don't you can remove this.
qvm-run --pass-io -u root $1 "apt install --no-install-recommends qubes-core-agent-networking qubes-core-agent-network-manager gnome-keyring firmware-iwlwifi -y"
add-feature-sys-usb
#!/bin/bash
# Adding sys-usb support
echo +++ installing sys-usb packages into  $1
qvm-run --pass-io -u root $1 "apt install --no-install-recommends qubes-usb-proxy qubes-input-proxy-sender qubes-core-agent-nautilus nautilus zenity gnome-keyring policykit-1 libblockdev-crypto2 ntfs-3g -y"
deb-11-sysusb
#!/bin/bash
 TARGET_TEMPLATE=deb-11-sysusb
 #clone
 #add features
 $(pwd)/add-feature-sysusb          $TARGET_TEMPLATE
 #shutdown
 qvm-prefs $TARGET_TEMPLATE maxmem 600
deb-11-sysnet
#!/bin/bash
 TARGET_TEMPLATE=deb-11-sysnet
 #clone
 #add features
 $(pwd)/add-feature-sysnet          $TARGET_TEMPLATE
 #shutdown
Creating DISP-Sys*
  1. the template are currently just that. Templates with kicksecure installed and setup. You still need to create disposable templates from them. I will expand on section later but the details for doing this in already at Disposable customization | Qubes OS
    You will need to follow that but use the deb-11-sysfirewall, deb-11-sysusb, deb-11-sysnet for these.
Known Issues:
Thank you for the effort you put in to making this.
No worries. I’m going to expand on the creating DISP-sys section so it isn’t just referencing the disposable customization document.
I’ve also expanded kicksecure testing with a thunderbird qube and a general browser qube with librewolf and firefox-esr installed. Both seem to work fine.
Thank you for your contribution @thewanderer. Moved to Guides.
Thanks for taking the time to make this guide @thewanderer
One thing thats changed in the script, and it took me a while to work out the issue:
qvm-run --pass-io --no-gui --user=root $1 ‘curl --proxy http://127.0.0.1:8082/ --output derivative.asc https://www.kicksecure.com/derivative.asc’
The url has changed to “https://www.kicksecure.com/keys/derivative.asc”
It redirects to the new url, but the html 301 response saves to the local keystore.
great guide
thanks
wouldnt distro-morphing be an easier option?
For anyone more knowledgeable than myself, why are we distro-morphing from debian rather than just installing a kicksecure template directly, like so? Kicksecure for Qubes
And is there anything that would need to be updated if one were to follow this guide, aside from the url mentioned above?
Dude, check the dates. The guide is like four years old, and even the last reply is one and a half years old. The Kicksecure template for Qubes didn’t exist back then.
Okay, I know this thread is like four or so years old now but I wanna post here anyway. Recently, I set up the Qubes OS Live Mode which, if you have the Kicksecure-18 template installed, creates a disposable RAM-based AppVM based on it.
And I just simply set that DispVM as the template for my service qubes.
I repeat, my service qubes template is a Kicksecure-based disposable RAM qube and, so far, they’ve been working just fine.
I take that back.
