GPU Passthrough
Hey,
I am relatively new to Qubes and haven’t found a explanation that suits my knowledge.
So, from my understanding no Qube uses the GPU besides the gui-vm? This mean’s I can’t take advantage of my GPU in my Qubes.
But because of an interesting project of mine (I want to run my own ml models), I need a good GPU to run certain things. I am using the Nvidia RTX 3070 & noveau driver.
So, to achive that I need to do the following:
  1. Check if IOMMU is activated in Bios for pci passthrough
  2. Create a HVM qube
  3. Find pci-id of my GPU with lspci | grep -i nvidia
  4. qvm-pci attach dom0:
  5. install nvidia-drivers in the qubes with apt install nvidia-driver firmware-misc-nonfree or sudo dnf install akmod-nvidia xorg-x11-drv-nvidia
Is this all? Did I forget / oversee things? and while writing I recognized is it probably not a good idea to have noveau in dom0 and the properitary driver in the qubes, so i will have to stick to one of them, right?
thanks in advance!
It doesn’t matter since dom0 won’t use this GPU because it’s passthrough to another qube.
So this means only one qube can use the gpu at a time?
Thanks for the guide, i will definitely read into it.
Yes.
