Gigabyte g7 md
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  GIGABYTE
model: |
  G7 MD
bios: |
  FB07
cpu: |
  11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a36] (rev 05)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation TigerLake-H GT1 [UHD Graphics] [8086:9a60] (rev 01) (prog-if 00 [VGA controller])
  NVIDIA Corporation GA107M [GeForce RTX 3050 Ti Mobile] [10de:25a0] (rev a1) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Tiger Lake PCH CNVi WiFi [8086:43f0] (rev 11)
  Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
memory: |
  16163
scsi: |
usb: |
  1
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      4.2.0-rc3
    xen: |
      4.17.2
    kernel: |
      6.1.43-1
    remark: |
      FIXME
    credit: |
      rarez
    link: |
      rarez
Remarks
Everything works out of the box, WiFi, ethernet, battery, keyboard. I only had to disable secure boot in the bios to get Qubes release 4.2.0-rc3 to work fine.
ping @Sven are you still maintainer of the HCL?
Yes, and he works on it with occasional delays.
Thanks @fsflover I didn’t see this post of Sven’s until now.
Moving cross country (continent really). Will be well into next week before I get to HCL reports.
Thank you @rarez for your HCL report, which is online now!
