Fix slow Libreoffice
Since the corresponding information is buried in a couple of long threads, here’s a quick summary of how to make LibreOffice reasonably fast in Qubes. Use it, if you experience high CPU usage when using LibreOffice and/or LibreOffice to be extremely slow, lag when scrolling, etc.
launch LibreOffice like that:
SAL_USE_VCLPLUGIN=gen libreoffice
Furthermore, in LibreOffice, Tools → Options → View
  • Disable hardware acceleration
  • Disable anti-aliasing
  • Enable “Use Skia for all rendering”
  • Enable "Force Skia software rendering”
kf5 works better than gen. The rest doesn’t matter.
At least on my 4.2.4 system.
Never had issues in LibreOffice even on modest old hardware. Will try this if I do though.
Also --nologo:
Aliases:
alias libreoffice='SAL_USE_VCLPLUGIN=gen libreoffice --nologo'
alias lo='SAL_USE_VCLPLUGIN=gen libreoffice --nologo'
Is there a way to save these settings somehow in /etc/ so it works for every VM?
In Qubes 4.3, with Debian 13 trixie, update template like this:
# Install the LibreOffice Qt6 plugin
sudo apt install libreoffice-qt6
# See the existing Exec commands for LibreOffice XDG Desktop Entries:
grep Exec /usr/share/applications/libreoffice-*desktop
# Update all the LibreOffice XDG Desktop Entries to use Qt6
sudo sed -i 's/Exec=l/Exec=env SAL_USE_VCLPLUGIN=qt6 SAL_VCL_QT6_USE_CAIRO=1 l/g' /usr/share/applications/libreoffice-*desktop
That and disabling the hardware acceleration seems to work. Skia doesn’t appear to exist on GNU/Linux.
Or in Qubes 4.3, with Debian 13 trixie, if you have a lot of KDE packages already, use kf6 instead of qt6:
# Install the LibreOffice kf6 plugin
sudo apt install libreoffice-kf6
sudo sed -i 's/Exec=l/Exec=env SAL_USE_VCLPLUGIN=kf6 l/g' /usr/share/applications/libreoffice-*desktop
# If you already ran the above Qt6 replace, use this instead to replace with kf6:
# sudo sed -i 's/Exec=env SAL_USE_VCLPLUGIN=qt6 SAL_VCL_QT6_USE_CAIRO=1 l/Exec=env SAL_USE_VCLPLUGIN=kf6 l/g' /usr/share/applications/libreoffice-*desktop
@bagel
You can use a simple conf file instead of modifying package-provided files (that might get overwritten e.g. during update):
# /etc/profile.d/98-libreoffice.sh
export SAL_USE_VCLPLUGIN=kf6
Maybe give ONLYOFFICE a try? I don’t know how it performs on Qubes OS, but (performance aside) I find it way better than Libreoffice. If it also performs better on Qubes OS, that’s a win-win.
I gave it a try…
this was a good hint :wink:
I installed it as flatpak from flathub,
and in works out of the box.
Changes Menu to 125% for better readability :wink:
Scrolling, Using Page Up and Page down, with no stutter, changeing the fields in a table works smooth.
Not compareable to Libreoffice, way better.
I never got Libreoffice running so smooth and responsible.
@solene Thanks for this hint.
Will use it for the next weeks. And will also check the “network communication” of the app
