Fedora 42 templates available for testing
Dear Qubes testers,
Fedora 42 templates (including standard, minimal, and Xfce versions) for Qubes OS 4.2 and 4.3 are now available for testing in the qubes-templates-itl-testing repositories for 4.2 and 4.3, respectively. Here’s the associated issue:
Your feedback will be invaluable in helping us determine whether there any bugs that need to be fixed before the stable release of this template. For more information about how to test and provide feedback, please see:
I’m missing packages related to sys-audio and qubes-video-companion but I suppose it’s normal?
Otherwise, it works perfectly fine for me. Thanks to everyone involved into making it great :star_struck:
Tested on 4.2
Do you have current-testing repo enabled?
I have this in the template
$ cat /etc/dnf/repos.override.d/99-config_manager.repo
# Generated by dnf5 config-manager.
# Do not modify this file manually, use dnf5 config-manager instead.
[qubes-builder-vm-r4.2-current-testing]
enabled=1
[google-chrome]
enabled=0
[rpmfusion-free]
enabled=0
[rpmfusion-free-debuginfo]
enabled=0
[rpmfusion-free-source]
enabled=0
[rpmfusion-free-updates]
enabled=0
[rpmfusion-free-updates-debuginfo]
enabled=0
[rpmfusion-free-updates-source]
enabled=0
[rpmfusion-free-updates-testing]
enabled=0
[rpmfusion-free-updates-testing-debuginfo]
enabled=0
[rpmfusion-free-updates-testing-source]
enabled=0
[rpmfusion-nonfree]
enabled=0
[rpmfusion-nonfree-debuginfo]
enabled=0
[rpmfusion-nonfree-source]
enabled=0
[rpmfusion-nonfree-updates]
enabled=0
[rpmfusion-nonfree-updates-debuginfo]
enabled=0
[rpmfusion-nonfree-updates-source]
enabled=0
[rpmfusion-nonfree-updates-testing]
enabled=0
[rpmfusion-nonfree-updates-testing-debuginfo]
enabled=0
[rpmfusion-nonfree-updates-testing-source]
enabled=0
I dont recognise this. The packages are available in the stock
current-testing repositories.
