Fedora 39 Errors during downloading metadata for repository 'fedora': - Status code: 500
Hello fellow qubes users,
I’m running Qubes on version 4.2.1
I tried to install libreoffice and i get this error in fedora-39-xfce-clone-1 runing
[user@fedora-39-xfce-clone-1 ~]$ sudo dnf install libreoffice
Fedora 39 - x86_64                              267  B/s | 704  B     00:02
  - Status code: 500 for http://HTTPS///mirrors.fedoraproject.org/metalink?repo=fedora-39&arch=x86_64&protocol=http (IP: 127.0.0.1)
Error: Failed to download metadata for repo 'fedora': Cannot prepare internal mirrorlist: Status code: 500 for http://HTTPS///mirrors.fedoraproject.org/metalink?repo=fedora-39&arch=x86_64&protocol=http (IP: 127.0.0.1)
I find this issue that seemed similar https://discussion.fedoraproject.org/t/errors-during-downloading-metadata-for-repository-fedora/73771 so i tried to try to modify the /etc/yum.repos.d/fedora.repo file by changing the hostname.
Commenting metalink and adding :
baseurl=http://download.fedoraproject.org/
or
baseurl=http://download.fedoraproject.org/pub/fedora/linux/releases/$releasever/Everything/$basearch/os/
This issue seems to be similar to : Errors during downloading metadata for repository 'qubes-contrib-dom0-r4.2-current'
I’m stuck, please send help :slight_smile:
Do you use apt-cacher-ng?
Seems to be an issue with fedora+cacher:
Yes, i use apt-cacher-ng
I didn’t knew that there was an issue with fedora+cacher.
Thank you very much @apparatus
so what i did is edit the repository files :
$ sudo nano /etc/yum.repos.d/fedora-cisco-openh264.repo
$ sudo nano /etc/yum.repos.d/fedora-updates-testing.repo
$ sudo nano /etc/yum.repos.d/fedora-updates.repo
$ sudo nano /etc/yum.repos.d/fedora.repo
$ sudo nano /etc/yum.repos.d/qubes-r4.repo
and edit the repository definitions
replacing `http://HTTPS///` with `https://`
Status code 500 indicates an error at the server end. It’s relatively
common with Fedora mirrors for some reason.
If you are using the apt-cacher-ng package that I provide I try to keep
the package updated with extended fedora repository lists and
configuration changes. It works well for 40 and (most of the time) 39.
(didnt know how to reply to specific post)
I’m not sur if i use apt-cacher-ng,
because in dom0, when i run “cacher --help” or “apt-cacher-ng --help” i get “command not found”
what can i do to make sure is use apt-cacher-ng ?
It might be possible that i installed it and later deleted it
sould i try installing it again ?
You would please check one thing before reinstallation.
Check inside /etc/qubes-rpc and see if you have file named qubes.UpdatesProxy.rpmnew
You will also need to change the updates proxy used by this template -
you can do this in Qubes Global Config.
there is not this file, i have a similar one qubes.UpdateAppMenuFor
It’s not an application in dom0 - it’s an application that runs in a
qube.
You can see if you are using it from Qubes Global Config under the
Updates pane. If you installed the package from simple tools then
a qube called cacher would have been created, and the system configured
to use it.
ok, so i don’t have it installed @apparatus @unman
I missunterstood because i saw http://HTTPS/// in the repos files
I think my issue might come from when i installed an additional template provided by our generous and kind @unman here https://qubes.3isec.org/Templates/
I might have done something strange like starting to install cacher and don’t finish installing it. I don’t remember exactly it was a few weeks ago.
Is it correct to assume that if we use sys-whonix as our update-proxy, there is no benefit to using cacher ?
can i mark it as a solution ?
it solved the issue for me
Yes.
I guess so.
and for debian edit those files :
/etc/apt/sources.list
/etc/apt/sources.list.d/qubes-r4.list
