When I tried to build archlinux template from fedora-30,I ran “make get-sources” it said that "unknown optional ‘show current’ ".And I tried to skip this step to run “make qubes-vm”. After that the command “make template” returned that qubes-src/linux-template-builder:No such a file or directory.
Is there a solution?
Is your f30-template up to date?
Did you follow the building guide for archlinux?
I don’t have a f30-template at the moment so I just tried with a f32-template and this is working (at least the steps until ‘make template’). Maybe you could try building with f32?
Hi @PPTP,
as @Raphael_Balthazar said, Fedora 30 is End Of Life, see the announcement and how to update:
And Fedora 31 is now also End Of Life, see the announcement and how to upgrade:
