I did it again with sudo as you suggested, here are some outputs:
sudo lspci in dom0
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 05)
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31)
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
00:17.0 SATA controller: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] (rev 31)
00:1b.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #17 (rev f1)
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #1 (rev f1)
00:1c.1 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #2 (rev f1)
00:1c.4 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #5 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Z170 Chipset LPC/eSPI Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
00:1f.3 Audio device: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller (rev 31)
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] (rev c5)
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a806
03:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43602 802.11ac Wireless LAN SoC (rev 01)
04:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM57766 Gigabit Ethernet PCIe (rev 01)
04:00.1 SD Host controller: Broadcom Inc. and subsidiaries BCM57765/57785 SDXC/MMC Card Reader (rev 01)
05:00.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] (rev 02)
06:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
06:01.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
06:02.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
06:04.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
07:00.0 System peripheral: Intel Corporation JHL6540 Thunderbolt 3 NHI (C step) [Alpine Ridge 4C 2016] (rev 02)
08:00.0 USB controller: Intel Corporation JHL6540 Thunderbolt 3 USB Controller (C step) [Alpine Ridge 4C 2016] (rev 02)
sudo lspci -v in dom0 (for better overview I only post the ethernet device)
Subsystem: Broadcom Inc. and subsidiaries NetXtreme BCM57766 Gigabit Ethernet PCIe
Flags: fast devsel, IRQ 17
Memory at d0200000 (64-bit, prefetchable) [size=64K]
Memory at d0210000 (64-bit, prefetchable) [size=64K]
Capabilities: [48] Power Management version 3
Capabilities: [50] Vital Product Data
Capabilities: [58] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [a0] MSI-X: Enable- Count=6 Masked-
Capabilities: [ac] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [13c] Device Serial Number 00-00-78-7b-8a-be-01-09
Capabilities: [150] Power Budgeting <?>
Capabilities: [160] Virtual Channel
Capabilities: [1b0] Latency Tolerance Reporting
Kernel driver in use: pciback
Kernel modules: tg3
sudo lspci in sys-net
00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
00:01.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II]
00:01.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 03)
00:02.0 Unassigned class [ff80]: XenSource, Inc. Xen Platform Device (rev 01)
00:04.0 VGA compatible controller: Device 1234:1111 (rev 02)
00:05.0 USB controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 10)
00:06.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM57766 Gigabit Ethernet PCIe (rev 01)
sudo lspci -v in sys-net
Physical Slot: 6
Flags: fast devsel, IRQ 40
Memory at f2010000 (64-bit, prefetchable) [size=64K]
Memory at f2020000 (64-bit, prefetchable) [size=64K]
Capabilities: [58] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel modules: tg3
sudo journalctl | grep 'tg3' in sys-net
Dec 25 08:33:34 sys-net kernel: tg3 0000:00:06.0: tg3_test_dma: Buffer write failed. err = -19
Dec 25 08:33:34 sys-net kernel: tg3 0000:00:06.0: DMA engine test failed, aborting
I also tried to attach the ethernet PCI device with sudo xl pci-attach sys-net '04:00.0,permissive=1 in dom0 instead of qvm-pci attach --persistent --option permissive=true --option no-strict-reset=true sys-net dom0:04_00.0 but this is the output when I do it:
libxl: error: libxl_pci.c:1608:libxl__device_pci_add: Domain 14:PCI device 0000:04:00.0 cannot be assigned - no IOMMU?
libxl: error: libxl_pci.c:1774:device_pci_add_done: Domain 14:libxl__device_pci_add failed for PCI device 0:4:0.0 (rc -1)
libxl: error: libxl_device.c:1450:device_addrm_aocomplete: unable to add device
when attaching with the previous method, the attaching apparently works, as the logs I posted above with sudo.
Also, I tried to switch sys-net from HVM to PV, but this doesn’t work at all. When I switch it to PV mode (while ethernet device attached) and try to start sys-net, I get following error:
Start failed: internal error: Unable to reset PCI device 0000:04:00.0: internal error: Active 0000:04:00.1 devices on bus with 0000:04:00.0 not doing bus reset, see /var/log/libvirt/libxl/libxl-driver.log
Content of the log from the PV mode failure:
2022-12-24 13:19:07.963+0000: libxl: libxl_pci.c:1484:libxl__device_pci_reset: write to /sys/bus/pci/devices/0000:04:00.0/reset returned -1: Inappropriate ioctl for device
2022-12-24 13:21:23.626+0000: libxl: libxl_pci.c:1484:libxl__device_pci_reset: write to /sys/bus/pci/devices/0000:04:00.0/reset returned -1: Inappropriate ioctl for device
2022-12-24 13:21:24.519+0000: libxl: libxl_pci.c:1484:libxl__device_pci_reset: write to /sys/bus/pci/devices/0000:04:00.0/reset returned -1: Inappropriate ioctl for device
2022-12-24 13:21:34.619+0000: libxl: libxl_device.c:1434:libxl__wait_for_backend: Backend /local/domain/0/backend/pci/28/0 not ready
2022-12-24 13:21:51.866+0000: libxl: libxl_pci.c:1484:libxl__device_pci_reset: write to /sys/bus/pci/devices/0000:04:00.0/reset returned -1: Inappropriate ioctl for device
2022-12-24 13:21:52.760+0000: libxl: libxl_pci.c:1484:libxl__device_pci_reset: write to /sys/bus/pci/devices/0000:04:00.0/reset returned -1: Inappropriate ioctl for device
2022-12-24 13:22:02.870+0000: libxl: libxl_device.c:1434:libxl__wait_for_backend: Backend /local/domain/0/backend/pci/29/0 not ready
But PV mode isn’t needed I guess, because in HVM I can attach the device with the command I mentioned earlier, so I think this particular error can be neglected? Main thing is to find out why the network manager only gives me No networking devices available as option with an apparently working and attached ethernet device :-/
