My search for a laptop to install qubes on has been a very bad experience.
I started by making a list of all potential laptops in my country. I’ve now completed going through the list and there are barely any laptops that have an ethernet port. The few sparse laptops that have it are on the other side of the country and those laptops have other downsides as well so no matter which laptop I look at there is always something that makes me frown but this topic is focused on the lack of ethernet in modern laptops.
All the potential laptops had to qualify the qubes os system requirement otherwise they wouldn’t be added to the list I went through.
What I would like to see a discussion about is giving up trying to find a laptop with ethernet support. Networking is something I’m not so good at but I know Wifi now days have equal security encryption as ethernet. The main problem with wifi is it’s easier for an adversary to attack but ethernet the adversary would need to use an ethernet cable which would be in my case impossible for them to do undetected.
I also know it’s popular in qubesos community to remove wifi from laptop.
What do you think about this situation? I know many of you are ok with buying second hand laptops or you trust the qubes-certified vendors and trust the anti-interdiction to be good enough tamper evidence, then you don’t have the problem of finding a laptop with ethernet but what if you only wanted to buy a new computer locally for cash and you discovered how rare it is to find a laptop with ethernet support?
What would you do then? Would you travel to another country and book a hotel and spend money on taxi to search for a laptop there and hope that country has laptops with ethernet? Or would you give up and accept having to use only wifi? I think if you give in to having to use only wifi then you would need to spend a lot of time to learn about networking and routers and have to buy a open source router and spend time learning how to make it as secure as possible. Maybe if you do that and you are the only person who will use the router then maybe it is not too far from being as secure as ethernet? what do you think? Like I said I know very little about networking that’s why I am starting this topic to see what those who know more about this will say.
It seems like ethernet support in laptops is becoming extinct. Everyone just uses wifi even if they are home and never travels with the laptop.
