When i run software update for Dom0 (qubes → qubes tools → qubes update) or use dom0 terminal the process occurs - i download a ton of updates (i am currently on 4.1) and then when it is time to install them (click y confirmation) and then i get
Running 'usr/lib/qubes-qubes-download-dom0-update.sh --doit – nogui ‘–exclude=qubes-template*’ ‘–quiet ’ ‘-y’ ‘–clean’ ‘–action-upgrade’’ on sys-firewall
Error: Transaction test error
file /usr/lib.build-id/10/426e215ebe20c86b885515b0c3a93284e0a68 from install of kernel-devel-1000:5.10.96.1.fc32.qubes.x86_64 conflicts with file from package kernel-devel-1000:5.10.76-1.fc32.qubes-x86_64
^^ i get the above for about 20 other files
and then a big fat x next to dom0 indicating a failed update.
