Problem
You can’t paste from a qube into dom0. For good reason: security
So you use workarounds:
[me@dom0 ~]$ qvm-run --pass-io $fromQube "cat $fromFile" > ~/fromQube.txt
Thereby you do transfer to dom0 and execute it (after review, obviously).
Solution
A script that fetches the global clipboard in dom0, but safely:
- Sanitize input: only ASCII printable characters, tab, newline, and carriage return
- Strip everything else, including control characters and non-ASCII bytes
- Minimize exploit surface:by never feeding the raw clipboard content into anything other than
tr - Show notification just as the normal global clipboard
- Warn or refuse if bytes were stripped
- Wipe the global clipboard afterwards, just as the normal global clipboard
Bind it to an unique & long shortcut like Ctrl+Shift+Alt+V to avoid accidental activation.
Limitations
- You can still paste harmful commands. Make sure you check anything before executing in dom0
- Pastejacking can’t be prevented: https://security.love/Pastejacking
How it works
- Reads the clipboard from
/run/qubes/qubes-clipboard.binand the source qube name from/var/run/qubes/qubes-clipboard-source - Uses
trwithLC_ALL=Cand a whitelist: tab, newline, carriage return, and bytes 0x20–0x7E (space through tilde). Everything else is dropped - Counts sanitized size and characters with
wc - Compares sizes; if bytes were removed, it:
- Either refuses to copy (strict mode), or
- Copies anyway but notifies user
- Passes sanitized text to xclip
Usage
- Place the script in dom0
- Make it executable:
chmod +x qvm-clipboard-to-dom0.sh - Needs
xclipin dom0:sudo qubes-dom0-update xclip - Bind to a keyboard shortcut in dom0
Over to you
Curious to get security reviews & critical feedback. I accept that pasting into dom0 is risky, if done wrong (directly into shell, for example). But is this script safe? Can you exploit it?
#!/bin/sh
# Read the last Qubes global clipboard contents in dom0 from
# /run/qubes/qubes-clipboard.bin, strip everything except basic ASCII
# and copy the sanitized result into the dom0 X clipboard via xclip.
# Keeps user informed via notify-send (same as qubes clipboard)
# Security considerations:
# - Script removes EVERYTHING except for these allowed characters:
# tab, newline, carriage return, ASCII printable chars 0x20-0x7E
# - Removal includes all terminal control / escape sequences and non-ASCII bytes
# - Removes trailing newline (helps avoid immediate execution)
# - Verifies the source clipboard file exists and is non-empty, checks
# that xclip is available, and refuses to proceed if sanitization
# yields an empty result
# - Keeps user informed via notify-send and warns if filtering was performed
# Remaining risks:
# - The tr utility handles the unfiltered clipboard. It could have a vulnerability.
# Care is taken to not feed other tools with unfiltered content
# - This script won't save you from copying malicious commands. It only ensures
# that you receive only visible ASCII in dom0 clipboard.
# Further reading:
# - Demo site showing danger of copy-pasting from browser:
# https://thejh.net/misc/website-terminal-copy-paste
CLIPFILE=/run/qubes/qubes-clipboard.bin
SOURCEFILE=/run/qubes/qubes-clipboard.bin.source
NOTIFY_TIMEOUT=7500 # Notification duration (in ms). Long enough to keep user informed
MAX_CLIPBOARD_SIZE=$((10*1024*1024)) # 10 MiB
# Behavior when filtering removed any characters:
# 0 - Abort with error
# 1 - warn and copy sanitized content (content might be incomplete)
ALLOW_FILTERED=1
# Check that xclip is available
if ! command -v xclip >/dev/null 2>&1; then
notify-send -t $NOTIFY_TIMEOUT "Dom0 clipboard" "ERROR: Package xclip is not installed in dom0"
exit 1
fi
# Check if clipboard file exists and is non-empty
if [ ! -f "$CLIPFILE" ] || [ ! -s "$CLIPFILE" ]; then
notify-send -t $NOTIFY_TIMEOUT "Dom0 clipboard" "Global clipboard empty"
exit 1
fi
# Sanitize source qube name, even though it's set by dom0 (trusted). We don't want any fancy chars in our notification
source_qube=$(LC_ALL=C tr -cd '\t -~' < "$SOURCEFILE")
# Original size in bytes from filesystem metadata, avoid feeding it to a tool such as wc
orig_bytes=$(stat -c '%s' -- "$CLIPFILE") || exit 1
if [ "$orig_bytes" -gt "$MAX_CLIPBOARD_SIZE" ]; then
notify-send -t $NOTIFY_TIMEOUT "Dom0 clipboard" "ERROR: Clipboard from '$source_qube' is too large ($orig_bytes bytes)"
exit 1
fi
# Sanitize clipboard. Keep only:
# \t = tab 0x09, octal 011
# \n = newline 0x0A, octal 012
# \r = carriage ret 0x0D, octal 015
# Safe ASCII Range space (0x20, octal 040) to tilde (0x7E, octal 176)
sanitized=$(LC_ALL=C tr -cd '\t\n\r -~' < "$CLIPFILE")
# Check if anything is left after filtering
if [ -z "$sanitized" ]; then
notify-send -t $NOTIFY_TIMEOUT "Dom0 clipboard" "Clipboard from '$source_qube' contained no safe ASCII characters after filtering"
exit 1
fi
# Size of sanitized content in bytes
sanitized_bytes=$(printf '%s' "$sanitized" | LC_ALL=C wc -c)
# Detect if any bytes were removed (sanitization changed content size)
# Note: This detects any removal, not just non-ASCII; but thats what we want.
removed_bytes=$((orig_bytes - sanitized_bytes))
if [ "$removed_bytes" -gt 0 ]; then
# Abort if filtering occurred?
if [ "$ALLOW_FILTERED" -ne 1 ]; then
notify-send -t $NOTIFY_TIMEOUT "Dom0 clipboard" "ERROR: Clipboard from '$source_qube' contained unsafe characters. You can set ALLOW_FILTERED=1"
exit 0
fi
# Show the warning longer, it's important to read
notify-send -t $((NOTIFY_TIMEOUT*2)) "Dom0 clipboard" "WARNING: $removed_bytes unsafe bytes from '$source_qube' removed. Copied content is incomplete, check before use"
fi
# For information only (does not affect behavior)
chars=$(printf '%s' "$sanitized" | LC_ALL=C wc -m)
# Copy sanitized content into dom0 clipboard
printf '%s' "$sanitized" | xclip -rmlastnl -selection clipboard
notify-send -t $NOTIFY_TIMEOUT "Dom0 clipboard" "Copied $chars safe ASCII chars from '$source_qube'"
# Wipe the global clipboard like qubes does
: > "$CLIPFILE"
: > "$SOURCEFILE"
exit 0
