clammy
March 7, 2026, 12:04am
1
I’m obsessed with my task manager - I feel I get the most out of my machine when I carefully manage memory & CPU consumption
The native task manager is domain-specific. It’ll graph activity within a given qube, but even at the dom0 level, it won’t graph consumption across domains
So I find myself spamming ‘xl list’ in the dom0 terminal to get a realtime-esque system memory feed. I havent found an existing GUI to graph it, though it feels as though one would be pretty straightforward to cobble together…
Does such a program already exist somewhere? Or should I get to coding?
otter2
March 7, 2026, 1:43am
2
Hey @random_user , any updates? (Sorry if I missed your post or something)
I have a python script running in dom0 that runs various qubes and xen utilities in dom0, as well as using qvm-run into the running qubes to issue OS commands to generate an image, which it then sets as the desktop background. It runs regularly (every 10 seconds or so) to regenerate the image.
[image]
And you can make conky.
But be aware, if you go into cairo graphics you will have memory leaks.
I’ve managed to trim it down to 20MiB/h
I created a Widget for detailed memory usage
For your usecase still no CPU usage …
And not as wholesome as @random_user approach, but it is available
You can use xentop or xentop -b in dom0 if you want a printout of the current CPU and memory usage of each qube.
This is an amazing conky for Qubes-OS that give you full of content
a conky configuration for Qubes OS
qubist
March 7, 2026, 2:52pm
7
@clammy
I have set a 5s generic monitor in my panel that calls this script:
#!/bin/bash
set -euo pipefail
/usr/bin/renice -n 19 $$ > /dev/null 2>&1
pattern='s/Mem:(\s*[0-9.a-zA-Z]+){2}\s*([0-9\.a-zA-Z]+).*/\2/g'
free_mem=$(/usr/bin/free --human \
| head --lines=2 \
| tail --lines=1 \
| sed -r "${pattern}")
pattern='s/Swap:(\s*[0-9.a-zA-Z]+){1}\s*([0-9\.a-zA-Z]+).*/\2/g'
used_swap=$(/usr/bin/free --human \
| head --lines=3 \
| tail --lines=1 \
printf "%s [%s] %s" "$(xl info free_memory)" "${free_mem}" "${used_swap}"
Pasting here too, because the forum started to mess up code recently and I don’t know if it is fixed:
https://paste.opensuse.org/pastes/72fc5534923d
The above code displays Xen’s free memory, then dom0’s (in brackets), then swap.
For CPU load, I use this in another 5 sec generic monitor:
Thanks!
#!/usr/bin/env bash
# Measure physical CPU load in Xen
# https://forum.qubes-os.org/t/what-is-the-best-way-to-get-the-physical-cpu-load-value/27277/14
set -euo pipefail
renice --priority 19 $$ > /dev/null 2>&1
# Prevent two processes from trying to create the same qube
readonly pidfile="/run/user/${UID}/${0##*/}.pid"
[ -f "${pidfile}" ] && exit 1
touch "${pidfile}"
load=$(xenpm start 1 \
| awk 'BEGIN { sum=0; tot=0 } \
/^ C0/ { tot++; sum+=$2 } \
END { printf("%3.2f%%…
I had to modify your codeblock to match your pasted one.
qubist
March 8, 2026, 7:51am
10
@FranklyFlawless
Thanks.
I wonder if I should start adding a checksum to warn the reader in case of such bugs.
