Dom0 OS Selection
If dom0 were to move away from Fedora as the OS for dom0; what would be the criteria for choosing an alternative?
https://www.hardenedbsd.com/content/easy-feature-comparison
https://www.gnu.org/distros/free-distros.html
https://trustworthy.systems/projects/TS/makatea
SeL4 is a microkernel. Any thoughts on using a Rust-based hypervisor like Gramine? or Occulum?
(or are these projects just to take advantage of Intel SGX enclaves).
What about a unikernel (LibraryOS) like mirageOS for dom0?
Please familiarize yourself with Qubes OS architecture and then see these threads:
and also
These discussions should give you a comprehensive idea of all the ideas that have been discussed, the reasoning behind them and links to plenty of material relevant to this question.
Heh. I was about to link to them before I saw your response :slight_smile:
Yeah, this is a very good candidate for an FAQ entry. Something along the lines of…
  • it doesn’t really matter, because offline / no user interaction / hardware isolation
  • it’ll be even less important in the future or go away anyway, because more hardware isolation (net, usb, audio, gui domains)
  • if an attacker reaches dom0 your hardening / favorite distro won’t save you
Is this the canonical thread for the “other distribution for dom0” conversation? I’m thinking no?
I noticed the Github issue was set to “this is not the best place to discuss this”, but it’s not immediately clear to me where to go to follow or participate in that discussion
The issue links to this Discourse group URL, but that fails to load for me
Though I don’t have much currently, I would be happy to contribute whatever time I do have to development or testing. I’m capable of (at least) building, developing glue and testing
… from the Github issue though, it seems to me there’s still considerable work and discussion required just to determine what distribution would be suitable, and why
My interest is backed by a pretty weak case - would be very happy to be rid of Fedora (or any RHEL-based distributions) simply because I don’t like using them, as a function of not knowing their tools and conventions well in the way that I know those used by Debian. Not reason enough to make a serious argument for all Qubes developers and users, I admit :slight_smile:
Is the best place for this discussion in the real-time chat app used by Qubes devs? (Forgetting the name but I have a Qube set up for it that I just haven’t yet actually used)
I’ve considered it’s very possible this isn’t really “a thing” anymore, due to priorities and a possible lack of substantial “pain” from Fedora
That’s because the issue tracker is not intended to be a discussion forum.
This is the discussion forum, so the best place is either here or one of the mailing lists.
You have to replace qubes-os.discourse.group with forum.qubes-os.org, because the forum changed domains a long time ago.
It’s supposed to redirect automatically, but it looks like that’s no longer working for some reason.
A post was split to a new topic: Why are qubes-os.discourse.group links broken
There’s a GitHub PR stating that “basic functionality” works for NixOS as Dom0. I haven’t tried it myself though.
I often encounter Alpine Docker images when deploying and administrating software on my servers:
These bullet points don’t completely cover all the worries. When I first read the rationale for QubesOS, I was quickly convinced and installed it. However, upon daily use I soon found that dom0 was being updated much more frequently than I had expected it to be, at least several times in a month. In my observation, this is often because of updates to the linux kernel itself. I realize that hardware developments themselves necessitate some updates to the linux kernel. However, it might be helpful if people willing to restrict themselves to hardware options from a limited list might at least have the option of basing dom0 on an OS that doesn’t require so many updates. I wish I could be more certain that all OS updates to come will completely preserve VM isolation properties, and other properties that QubesOS depends on.
Isn’t the isolation achieved with Xen and hardware-assisted virtualization, so the kernel updates should not be relevant?
Correct.
