Distrobox Guide — Run Any Linux Distribution in Qubes Without Pain
Original Russian guide by Гайд на distrobox и как можно запускать любые дистрибутивы в Qubes без боли . English translation by me.
Introduction
Qubes has several problems when it comes to supporting alternative distributions:
  • (Primary) Dependence on the Qubes repositories and their updates, which complicates the use of rolling release distributions and generally reduces stability. Qubes developers don’t always manage to update them in time.
  • Distributions running as TemplateVMs depend on Qubes and do many things in the background — for example, they execute hooks to display newly installed applications in the application list, and this takes time. Obviously, not every installed application needs to be exported.
To solve these problems, you can use distrobox (https://distrobox.it/). It’s a lightweight container environment that runs on top of podman or docker, allowing you to run other Linux distributions. The host system is already mounted into the container and configured for launching any applications. Distrobox supports the full functionality of a regular Linux distribution (systemd, dbus, etc.), enabling seamless application launching.
How does distrobox solve these problems:
  • Since it runs inside a container, it doesn’t depend on the VM system at all. You can use any distribution as a base, but we’ll use debian-13.
  • It doesn’t trigger Qubes hooks when performing package update operations, and generally tries not to touch things that Qubes developers added to Guest VMs.
Installation
I’ll demonstrate the process using kali, which is a rolling release and currently difficult to use as a TemplateVM in Qubes — it’s not available in the repositories.
Creating a VM
Set the configuration as shown in the screenshot below and click Create new qube:
After that, a settings window will appear where you can configure the memory to your preference. I’ll use these settings:
Click OK.
Configuration
Installing Dependencies
Open a terminal and run:
sudo apt install distrobox -y
Installing kali
You can find other distributions here: https://github.com/toolbx-images/images, or via the GUI app: https://flathub.org/en/apps/com.ranfdev.DistroShelf
The installation will take some time:
distrobox create --root --image docker.io/kalilinux/kali-rolling:latest --name kali --init --hostname kali
distrobox enter --root kali
During installation, distrobox failed to automatically configure the user, so we’ll do it manually. In the prompt that appears, enter a password (we’ll get rid of it later):
After entering the new password, we end up inside the container. Exit it immediately using the exit command:
At this point, the user is not in the sudo group and therefore cannot execute commands as an administrator. To fix this password issue, we need to go through a few steps.
This command lets us enter the container as the root user:
sudo podman exec -it kali /bin/bash
As root, execute:
apt install -y nano     # kali repositories are blocked in Russia
nano /etc/sudoers
Scroll to the end of the file and, under the line root ALL=(ALL:ALL) ALL, add:
user ALL=(ALL) NOPASSWD: ALL
Press Ctrl+S, Ctrl+X to save the changes, then exit the environment with exit.
Verify everything works with:
This is already enough for minimal container usage, but we’ll also configure the terminal for a better user experience.
Additional Configuration for Convenience
Install a terminal inside the container and exit:
sudo apt install xfce4-terminal -y
exit   # exit the container environment
In the VM environment, run:
distrobox generate-entry --root kali   # create .desktop file
nano .local/share/applications/kali.desktop   # configure it
Write:
Exec=/usr/bin/distrobox enter --root kali -- xfce4-terminal
Terminal=false
Open the VM settings and click Refresh applications:
Then add Kali to the application list:
Now launch Kali and the container terminal opens:
It’s also worth configuring it to run /bin/bash instead of /bin/sh. This can be done in the xfce4-terminal settings:
Result:
Conclusion
This approach simplifies using distributions in Qubes that are not officially supported. NixOS users use an identical method to run programs that aren’t in the repositories and depend on LFS.
Join the Telegram channel: https://t.me/qubesru
Arch Linux with AUR works well in Distrobox?
should works well, I didn’t test it in Qubes, but on Nix it worked well
Why did you decide to create it as a standalone VM? - Are there any advantages over installing ‘distrobox’ directly into a template VM?
Will regular Qubes updates update Distrobox containers?
No, Qubes updates will update VM only, internal distrobox containers you have to update separetely.
I got my hopes too high then. I did the same thing you did in your guide. Except I made it using minimal template and I downloaded the podman container not into template but into app vm. I also used minimal template since minimal templates update way faster
Never tried to use TemplateVM with distrobox. In my case I wanted to use Standalone VM. By default containers and their data stored in /var/lib/containers, so you need configure bind-dirs for mount them in your AppVMs
You also compromise the security when giving template vm unlimited internet access. There has to be a way to force distrobox to go through 127.0.0.1:8082 proxy
Maybe i don’t understand but how it will compromise security? All you network requests will be sent through NetVM.
From Qubes official documentation file
2.17.5 Why don’t templates have normal network access?
In order to protect you from performing risky activities in templates, they do not have normal network access by default.
Instead, templates use an Updates proxy which allows you to install and update software using the distribution’s package
manager over the proxy connection
Security: Each qube has read-only access to the template on which it’s based, so if a qube is compromised, it
cannot infect its template or any of the other qubes based on that template
Probably you can use http_proxy env inside container. Container network have an access to host, you have a chance that will works
P.S. I’ve tested access to localhost from container to VM. It works well
You don’t have to give the template vm internet access, since the ‘distrobox’ package is offered by the Debian as well as the Fedora repository.
I have both variants running on my system w/o any issues.
Shouldn’t many distros run smoothly in a StandaloneVM anyway?
Don’t think so, QubesOS have a guest softwaree which depend on packages in distro repos. And sometimes it just got broken Recent update to upstream sudo broke Archlinux template updates · Issue #9395 · QubesOS/qubes-issues · GitHub
Well, updates break even Qubes (especially Linux kernels), but those are exceptions.
Can you clarify with an example of what good would be to use such a concept in a Qubes OS environment?
Did you read the guide? I’ve already answered your questions. Its just fix problems with packages conflicts.
Also you can you different distros inside the same VM. For example you can create a Linux Gaming Qube and simple change container distro for different games. And still have same security level. Anyways right now that is a good way how to run rolling releases without have any issues with updates.
all containers
BoxBuddy
Install Arch
distrobox create --image quay.io/toolbx/arch-toolbox:latest --name arch --root
Exactly. This is how I did it. And I suggest the author to change the guide to reflect that
