Each time I launch a new QVM I am prompted to enter keyring login details. Is there anyway to disable the keyring logins? I did a brief search of the forum and have not found this addressed. Thank you, kindly.
You could start up the disposable template, click “Continue” while leaving the password fields empty, then shut down the disposable template. This should result in each disposable inheriting the disposable template’s empty-password keyring and therefore not prompting you.
Remove gnome-keyring from your template. Not sure what its job is apart from being annoying.
thanks! I’ll give that a try
