Devilspie2 in dom0 on Qubes 4.3
Recent releases of Fedora do not package devilspie2 because the packager retired and no one has stepped up to take their place, and therefore it is not available in dom0 through the regular channel. The downstream program is still maintained, though. I use devilspie2 fairly extensively to isolate VMs to workspaces, manipulate window placement and geometry, help launch apps- so I wanted it back in 4.3.
(a) Simplest way to get devilspie2 in dom0:
Download & install one of the ‘recent’ RPMs available here:
I tried the one for fc38 and it worked in dom0’s fc41. But the source of these RPMs is 3+ years old and there have been a fair number of changes to devilspie2 in the meantime.
(b) Harder way, up-to-date devilspie2 in dom0:
Build and install HEAD of the source repo (caveat emptor)
Or, the most recent release: http://download.savannah.nongnu.org/releases/devilspie2/devilspie2_0.45-src.tar.gz
Probably best to build the binary in Fedora 41, as dom0 runs Fedora 41 and I want to sidestep any runtime library/linking issues.[1] And maybe it would be useful into the future to have available a build/test template that roughly matches dom0. The fedora-41 templates are obsolete and unavailable in 4.3, but still installable in 4.2.
Steps:
  • Append to /etc/qubes/repo-templates/qubes-templates.repo (temporarily):
[qubes-templates-itl-42]
name = Qubes Templates repository 4.2
# if using sys-whonix as updatevm
baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/templates-itl
# otherwise:
# baseurl = https://yum.qubes-os.org/r4.2/templates-itl
enabled = 1
fastestmirror = 1
metadata_expire = 7d
gpgcheck = 1
gpgkey = file:///etc/qubes/repo-templates/keys/RPM-GPG-KEY-qubes-4.2-primary
  • Obtain the 4.2 GPG key (available many ways, e.g. qubes-builder-rpm/keys/RPM-GPG-KEY-qubes-4.2-primary at 0bbc53e345eb455d50e0a1553b817dffdbff95bb · QubesOS/qubes-builder-rpm · GitHub)
  • [user@dom0 ~]$ qvm-template --refresh list
    # (everything looks ok, fedora-41 templates now available from the 4.2 repo)
  • [user@dom0 ~]$ qvm-template install fedora-41-xfce
    # wait.
  • (Now remove or comment out the [qubes-templates-itl-42] repo we added, as we aren’t going to need it again)
  • [user@dom0 ~]$ qubes-vm-update --force-update --targets fedora-41-xfce
    # (expect a long upgrade)
  • Create a new network-accessing qube based on fedora-41-xfce:
    [user@dom0 ~]$ qvm-create --class AppVM --template fedora-41-xfce --label red build-devilspie2
Then, on the VM:
# Install build deps named in the README
[user@build-devilspie2 ~]$ sudo dnf install --assumeyes pkgconf-pkg-config glib2-devel lua-devel libwnck3-devel gtk3-devel gettext gettext-devel libXrandr libXrandr-devel
# Get the devilspie2 source code.
# Could use devilspie2_0.45-src.tar.gz linked above, or HEAD:
[user@build-devilspie2 ~]$ git clone --depth 1 https://https.git.savannah.gnu.org/git/devilspie2.git
# Build the binary:
[user@build-devilspie2 ~]$ cd devilspie2 && make
Transfer the binary to dom0 (caveat emptor), put it somewhere that makes sense.
[user@dom0 ~]$ qvm-run -p build-devilspie2 'cat devilspie2/bin/devilspie2' > ./devilspie2
[user@dom0 ~]$ chmod u+x devilspie2
Autostart at login:
Create an entry for it in System Settings → Session and Startup → Application Autostart. Or create a file like this:
/home/user/.config/autostart/devilspie2.desktop:
[Desktop Entry]
Encoding=UTF-8
Version=0.9.4
Type=Application
Name=devilspie2
Comment=
Exec=/PATH/TO/devilspie2
OnlyShowIn=XFCE;
RunHook=0
StartupNotify=false
Terminal=false
Hidden=false
(Remember to fix the path)
  1. But see the post below by @anon40243023; no Fedora 41 required. ↩︎
You don’t need to use Fedora 41. I used Debian 12 to compile, and the binary worked just fine in dom0.
I only had to use make LUA=lua5.4 to force it to build with the same lib as dom0.
Thank you for the article.
  • So, devilspie2 is not officially provided for Fedora anymore (like 41 and later)?
  • Is there any easy way to install and update it without building by my own?
P.S. I really hope that DE which cannot even remember windows positions (xfce), will be replaced back by KDE with fine windows management settings in Qubes OS.
Correct. The project is alive/maintained but there have been no new Fedora RPMs for some time now as no one is on the hook for the job.
I don’t know of an unofficial Fedora RPM channel that provides new builds. You can manually install the old Fedora-provided RPMs though, they still work.
