Desktop hidden
My qubes desktop does not a have a toolbar out of the blue.
I cannot see wifi connections, appvm, etc.
Whats happend?
Kind Regards,
Luke.
You can try this if you are missing the panel
Same thing happened to me yesterday. Here’s how you can solve that inconvenience:
  1. Right click on the desktop wallpaper.
  2. Click on Open Terminal Here.
  3. Run the command xfce4-panel, then close the terminal, it should appear again.
If you want to close the terminal emulator window afterward while keeping the panel, you might need to do xfce4-panel & (i.e., add the & in order to run the process in the background so that it doesn’t end when you close the terminal emulator window).
