Despite adding mem_sleep_default=deep to my GRUB_CMDLINE_LINUX in /etc/default/grub, when I try to suspend, the screen turns off but I am unable to wake it back up without fully shutting off the system.
I’m looking at Qubes on my XPS 15. I have the same on-board graphics as your model but can’t see to get the screen working during install, is this something you ran into as well?
I’ve had some significant issues getting the laptop to to take another operating system in general but was finally able to get pop onto it. Any tips for manipulation to get qubes working?
Are you using 4.1? One thing I should’ve mentioned in this HCL report was that my laptop would not boot 4.0 due to kernel version, I’m pretty sure.
You’ll learn quite a bit as long as you’re willing to spend a bit of time troubleshooting. I’m sure you’re capable Brave to start with Qubes in anycase.
Luckily you’re joining the 4.1 train at a point where it is starting to stabilize. It’s not nearly as unstable as it was a year ago.
I have also an XPS 13 7390… You post isn’t recent but maybe you can help me a bit … I’m trying to boot on an USB with Qubes 4.1 installed with Rufus. I’m struggling with the BIOS/UEFI configuration. The system doesn’t see the USB when booting. It enters in Dell Assist Mode or just propose the PCI internal disk. I have tried numerous option following guides on the intenet but nothing seems working.
Legacy boot doesn’t work
EFI mode, with Secure Boot disabled doesn’t work.
