Hi
Adding my feedback/experience on new 5.4 kernel in dom0. Not sure this is right place as only just joined forum
tl:dr
- Kernel 5.4 causes my “Daily” and “Backup” PC’s to freeze.
- Have discounted hardware issues (checked and reseated/swapped DDR RAM)
- Disabling “C-States” setting in BIOS solves issue in my “backup” laptop. Could not find any BIOS settings that would solve in for my “Daily use” laptop.
- Would welcome guidance on what else to explore.
Detail
Have been using Qubes as my main OS for over two years. More than happy with it. THANK YOU. It’s installed on two laptops
Daily Use: Dell E7490 laptop : i5: 32 GB RAM : R4.0.3 + upgrades : often running 15-25 AppVM’s
Backup : Dell E6420 laptop : i5: 16 GB RAM : R4.0.3 + upgrades : essential subset of AppVM’s
TemplateVM’s are based on Fedora-32 and Debian-10
I upgrade Templates as soon as updates are available.
Last Thursday I updated dom0 on the E7490 using standard upgrade process (sudo qubes-dom0-update). Main change => Kernel upgraded from 4.19.155-1.pvops.x86_64 to 5.4.88-1.x86_64
After rebooting, the laptop would randomly freeze within 30 seconds to 3 minutes. Sometimes it would freeze during the startup sequence (before sys-net and sys-usb etc had started), other times I could complete user login but screen would freeze as soon as I touched curser and very rarely I could get about 3 minutes of use out of it before it would freeze,… so overall pretty random and have to power cycle laptop to recover.
Switched out NVMe drive, installed R4.0.4 rc2 and got same result with Kernel 5.4.90-1.
Checked and reseated all DDR rams.
Switched to reserve PC (E6420) => upgraded dom0 => found same issue.
This post suggested disabling CPU management settings in BIOS to solve similar issue on Lenovo laptop. OP found it also solved similar problem of screen freezing when running Tails and Ubuntu Live from USB sticks,… encouraging as I had same problem with Tails on my E6420.
Dell BIOS has two sections influencing CPU management, (“Performance” and “Power Management”), with a combined 11 options. The “Performance” Section has 5 options:-
- Multicore support
- Intel Speedstep
- C-States Control
- Intel TurboBoost
- HyperThread Control)
…Testing: … hours of… boot => mod BIOS => reboot into Qubes => sigh => repeat…
Results:
E6420: BIOS ver A25
- Disabling “C-state Control” option fixed the issue. Is able to run Kernel 5.4.xx without freezing
- Bonus: Tails and Ubunutu Live USB sticks now work on this laptop with C-State Contol disabled.
E7490: BIOS ver 1.17
- Disabling “C-State Control” had no impact. => extensive testing of other BIOS options could not resolve laptop freezing when running 5.4.88-1 and 5.4.90-1 kernals.
Any (constructive) Suggestions
Q: Would welcome any other suggestions on how to explore machine freezing with latest dom0 stable kernal (5.4.xx ).
Q: Is there any significance/clue in the name change of the kernel?
(4.19.155-1.pvops.x86_64 => 5.4.88-1.x86_64). … ie pvops? …(ps… this is what grasping at straws looks like!)
