This is a custom ISO with KDE in Dom0, Debian, Fedora, and Whonix templates.
It seems that the default partition size for /dev/qubes-dom0/root is 20G. I can’t see in the qubes-builder where this parameter can be changed (or indeed how this automatic partitioning is being fed to Anaconda)
Doing a kickstart installation with autopart --type thinp returns
Not enough space in file systems for the current software selection. An additional XXXX MiB is needed
Thank you, I’m trying to do an unattended install with Kickstart. So I shouldn’t be using autopart and need to create those LVM volumes in the *.ks…got it. Will post the working config if I can figure it out.
Ideally I’d like 1 big ISO which installs KDE and most of the possible templates (whonix, debian, fedora and the minimals) without running into disk issues. Couldn’t see where in qubes-builder the default was set at 20G (for root).
Thanks, I’m working off your great examples, problem is whenever my ISO file goes over about 5GB I’m getting that “not enough space” error in the installer.
Qubes 4.1 has limited the size of dom0 to 20G by default.
This means that when installing some templates, the install will fail with the message error an extra X required .
Can this 20G default be changed when building an ISO? Grepped around but couldn’t find the code which sets it.
If not, is it possible to run that resizing command as part of a Kickstart file for an unattended install?
