Custom Installation /boot in USB with FDE
After booting your installation media until ‘choose your language’, switch to shell with ctrl + alt + f2
Look your block device to make sure your device.
[anaconda root@localhost /]# lsblk
Reformat USB Devices.
##EFI PARTITION /dev/sdb1
[anaconda root@localhost /]# gdisk /dev/sdb
n
1
2048
1230845
EF00
##BOOT PARTITION /dev/sdb2
n
2
1230848
3278842
8300
##Write changes to disk
Preparing LUKS on /dev/sda
In this step we will using twofish-xts-plain64 chiper with sha512 hash and 512B keysize.
[anaconda root@localhost /]# cryptsetup -c twofish-xts-plain64 -h sha512 -s 512 --use-random -y -i 10000 luksFormat /dev/sda
Override data and enter your disk passphrase, then open your encrypted disk.
[anaconda root@localhost /]# crypsetup luksOpen /dev/sda luks
Create LVM
[anaconda root@localhost /]# pvcreate /dev/mapper/luks
[anaconda root@localhost /]# vgcreate qubes_dom0 /dev/mapper/luks
[anaconda root@localhost /]# lvcreate -n swap -L 8G qubes_dom0 ## You can change size value according to your need, I use 8G
[anaconda root@localhost /]# lvcreate -T -L 20G qubes_dom0/root-pool ## 20G is enough for dom0 and I use LVM Thin Provisioning
[anaconda root@localhost /]# lvcreate -T -l +100%FREE qubes_dom0/vm-pool ## +100%FREE means I use the rest of disk spaces to vm pool
[anaconda root@localhost /]# lvs ## Verified if pool is created or not
[anaconda root@localhost /]# lvcreate -V20G -T qubes_dom0/root-pool -n root
[anaconda root@localhost /]# lvcreate -V51.84G -T qubes_dom0/vm-pool -n vm
[anaconda root@localhost /]# mkfs.ext4 /dev/qubes_dom0/vm ## Create a file system on vm LVM because *remember* we can't reformat this volume at installer gui
Back to installation gui with ctrl + alt + f6 and choose your language installation then follow the guide inside.
Setup Disk
Go to installation destination, click refresh on bottom right, after wait for sometime, click on your 2 disk and click done in top left.
There are some partition we created before, but in here you need to reformat the partition and select mount point.
qubes_dom0-root click reformat, ext4 FS, / mount point, then update settings.
qubes_dom0-swap reformat, swap mount point, update.
sdb1 reformat efi, /boot/efi mount point, update.
sdb2 reformat ext4, /boot mount point, update.
don’t configure anything on qubes_dom0-vm.
click done on top left.
and there will be summary of your changes just click accept changes.
Installation
Click begin and grab coffe, my installation would take long because i use hdd in this step and with vmware. Patient is a key ![]()
And when the loading screen isn’t animate it’s okay just wait.
Reboot when it’s finished and enter your disk passphrase and configure how you want to use qubes.
Just use default if you haven’t experienced with creating qube system.
YOU’VE BEEN WARNED
DON’T CREATE SYS-USB! YOUR USB DRIVE WILL GET REMOVED AND YOUR SYSTEM WILL CRASH BECAUSE YOU NEED TO FIGURE IT OUT HOW TO TWEAKS.
The reason I choose installing all template and just create critical system is to make sure if anything is okay and i’m planning to make an Minimal Template setup guide later.
Click done and make another cup of coffe ![]()
After long time wait here there come our lovely os :3
I normally use current-security repo, because it’s latest and stable for my device, well i can say that if you have modern device, you really need 4.1 with latest kernel if possible.
And here’s some log about the system.
LUKS header information
Version: 2
Epoch: 3
Metadata area: 16384 [bytes]
Keyslots area: 16744448 [bytes]
UUID: 77807f8c-6be8-435e-be23-b645c272745e
Label: (no label)
Subsystem: (no subsystem)
Flags: (no flags)
Data segments:
0: crypt
offset: 16777216 [bytes]
length: (whole device)
cipher: twofish-xts-plain64
sector: 512 [bytes]
Keyslots:
0: luks2
Key: 512 bits
Priority: normal
Cipher: twofish-xts-plain64
Cipher key: 512 bits
PBKDF: argon2i
Time cost: 5
Memory: 1048576
Threads: 2
Salt: b5 3f 58 4a 20 17 df c9 f2 89 1d 50 7a ef 17 58
82 8e de 01 e7 bc 6e 93 3b ac da 2d 61 56 12 39
AF stripes: 4000
AF hash: sha512
Area offset:32768 [bytes]
Area length:258048 [bytes]
Digest ID: 0
Tokens:
Digests:
0: pbkdf2
Hash: sha512
Iterations: 146122
Salt: 5c 74 f5 3d 0e 51 89 36 f3 82 c6 95 27 db 70 58
bf e3 f9 5d a9 7f 3d 6e b1 08 fb 35 67 bf 08 af
Digest: 92 2c f2 6b 57 ef 62 a9 33 49 cc a4 9b d9 dc 26
89 59 e6 c3 e0 13 d3 bd 42 51 ef 28 30 1f 4d 80
2e 09 0d 4d 16 5a 6b 14 08 1f 2a 5c 39 a7 5c b9
04 af 32 f9 48 06 7b d3 80 f6 26 a4 54 86 4e 29
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 80G 0 disk
└─luks-77807f8c-6be8-435e-be23-b645c272745e 253:0 0 80G 0 crypt
├─qubes_dom0-root--pool_tmeta 253:1 0 20M 0 lvm
│ └─qubes_dom0-root--pool-tpool 253:3 0 20G 0 lvm
│ ├─qubes_dom0-root 253:4 0 20G 0 lvm /
│ └─qubes_dom0-root--pool 253:6 0 20G 1 lvm
├─qubes_dom0-root--pool_tdata 253:2 0 20G 0 lvm
├─qubes_dom0-swap 253:5 0 8G 0 lvm [SWAP]
├─qubes_dom0-vm--pool_tmeta 253:7 0 52M 0 lvm
│ └─qubes_dom0-vm--pool-tpool 253:9 0 51.9G 0 lvm
│ ├─qubes_dom0-vm--pool 253:10 0 51.9G 1 lvm
│ ├─qubes_dom0-vm 253:11 0 51.9G 0 lvm
│ ├─qubes_dom0-vm--sys--net--private--1625290080--back 253:12 0 2G 0 lvm
│ ├─qubes_dom0-vm--fedora--33--root--1625288095--back 253:13 0 10G 0 lvm
│ ├─qubes_dom0-vm--fedora--33--root--1625288169--back 253:14 0 10G 0 lvm
│ ├─qubes_dom0-vm--fedora--33--root 253:15 0 10G 0 lvm
│ ├─qubes_dom0-vm--debian--10--root--1625288707--back 253:16 0 10G 0 lvm
│ ├─qubes_dom0-vm--fedora--33--private 253:17 0 2G 0 lvm
│ ├─qubes_dom0-vm--debian--10--root--1625288783--back 253:18 0 10G 0 lvm
│ ├─qubes_dom0-vm--whonix--gw--15--root--1625289127--back 253:19 0 10G 0 lvm
│ ├─qubes_dom0-vm--debian--10--private 253:20 0 2G 0 lvm
│ ├─qubes_dom0-vm--debian--10--root 253:21 0 10G 0 lvm
│ ├─qubes_dom0-vm--whonix--gw--15--root--1625289200--back 253:22 0 10G 0 lvm
│ ├─qubes_dom0-vm--whonix--ws--15--root--1625289651--back 253:23 0 10G 0 lvm
│ ├─qubes_dom0-vm--whonix--gw--15--root 253:24 0 10G 0 lvm
│ ├─qubes_dom0-vm--whonix--gw--15--private 253:25 0 2G 0 lvm
│ ├─qubes_dom0-vm--whonix--ws--15--root--1625289726--back 253:26 0 10G 0 lvm
│ ├─qubes_dom0-vm--fedora--33--dvm--private 253:27 0 2G 0 lvm
│ ├─qubes_dom0-vm--whonix--ws--15--private 253:28 0 2G 0 lvm
│ ├─qubes_dom0-vm--whonix--ws--15--root 253:29 0 10G 0 lvm
│ ├─qubes_dom0-vm--sys--firewall--private--1625289951--back 253:30 0 2G 0 lvm
│ ├─qubes_dom0-vm--default--mgmt--dvm--private 253:31 0 2G 0 lvm
│ ├─qubes_dom0-vm--sys--net--private 253:33 0 2G 0 lvm
│ └─qubes_dom0-vm--sys--firewall--private 253:35 0 2G 0 lvm
└─qubes_dom0-vm--pool_tdata 253:8 0 51.9G 0 lvm
sdb 8:16 0 4G 0 disk
├─sdb1 8:17 0 600M 0 part /boot/efi
└─sdb2 8:18 0 1000M 0 part /boot
sr0 11:0 1 5.4G 0 rom
Linux dom0 5.12.10-1.fc32.qubes.x86_64 #1 SMP Wed Jun 16 14:35:48 CEST 2021 x86_64 x86_64 x86_64 GNU/Linux
