mila
November 10, 2022, 12:27pm
1
Hi all.
I’d like to report latest malfunction, but this time it’s related to a managed one:
2 qubes-os:
first with cacher is unable to update fedora 36 templates, because it says there’s a unmatching sign in xml of repos
second without cacher updates same fedora template without any problem
Any idea?
Thanks anyway…
M.
enmus
November 10, 2022, 7:49pm
2
@unman I have the same
fedora-cisco-openh264 error
same Unable to validate zchunk checksums error
First error is warning, but will obviously never reach repo nor update packages.
Second error I have annoying workaround of removing unreferenced files from apt-cacher-ng webgui. But is there a tweak to have files in sync? Reading documentation of apt-cacher-ng, I do not get how fetching Package list doesn’t update pointed files as of now.
or please copy paste exact error
mila
November 10, 2022, 9:12pm
3
Hi there,
Attaching latest ones.
Please let me know if You need other…
Thanks.
Cheers,
M.
mgmt-fedora-36_latest.log (4.0 KB)
enmus
November 11, 2022, 1:51pm
4
Thanks. Can you please give us full output of, for example,
# dnf upgrade --refresh
from within fedora template?
unman
November 11, 2022, 2:43pm
5
@deeplow , @Sven
Can we split this, and replies, to a new thread named "cacher (Apt-cacher-ng), issues with fedora updates "
mila
November 11, 2022, 5:29pm
6
Hi enmus.
Attached session log.
Please let me know if other ones are needed.
Thanks,
M.
dnf_update_full.log (3.5 KB)
enmus
November 11, 2022, 7:07pm
7
what is your updateVM for fedora? Does it work with debian/whonix?
mila
November 11, 2022, 9:26pm
8
it’s cacher for all (on first one).
And yes, of course debian and whonix are fine…
Just tested, right now and got old dear “System is already up-to-date” !
Thanks,
M.
enmus
November 11, 2022, 11:06pm
9
Yes, usually it’s enough to be patient and try again every a while. It happens to me regularly.
mila
November 12, 2022, 12:39pm
10
Hi enmus,
thanks for your suggestion.
I’ll go on with it, but I’d like to let You know that’s a week it’s going in this way…
Thanks,
M.
enmus
November 12, 2022, 1:25pm
11
unman already told you that in order to use cacher your repositories should be redirected to http://HTTPS///
and reading your dnf log we see
https://codecs.fedoraproject.org/openh264/36/x86_64/os/repodata/repomd.xml
For the other error:
Downloading successful, but checksum doesn’t match.
check the link to the topic I posted above.
mila
November 12, 2022, 2:05pm
12
Hi enmus.
Thanks for your help in troubleshooting my problem.
I’ve just checked back in yum.repos.d/fedora-cisco-openh264.repo because almost sure to haven’t messed them up; perhaps I think it’s exactly how salt has configured them; follows first 10 raws:
[fedora-cisco-openh264]
name=Fedora $releasever openh264 (From Cisco) - $basearch
metalink=http://HTTPS///mirrors.fedoraproject.org/metalink?repo=fedora-cisco-openh264-$releasever&arch=$basearch&protocol=http
type=rpm
enabled=1
metadata_expire=14d
repo_gpgcheck=0
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora-$releasever-$basearch
skip_if_unavailable=True
So now?
(checking other post now…)
I think You were talking about this:
From memory:
Doing a sudo dnf clean all in template sometimes helps
but I’ve got no luck…
dnf_update_cleaned_up.log (1.7 KB)
Thanks.
Cheers,
M.
enmus
November 13, 2022, 12:51am
13
Nope, I was talking to read all the way down from the point, meaning to try to clean cacher’s cache if nothing else helps.
mila
November 13, 2022, 3:58pm
14
Hi there,
I’ve searched a bit, but it seems to be missing the cacher “cache manager”: distkill.pl
https://www.unix-ag.uni-kl.de/~bloch/acng/html/maint.html#distkill
Do You suggest me to delete manually directory and files inside /var/cache/apt-cacher-ng ?
And in this case, only fedora directory?
Or *fedora* dirs?
Maybe something is moving… let me check…
Thanks,
M.
enmus
November 13, 2022, 7:22pm
15
This is the only other thing I can suggest and I meant on
Cleaning cache instantly created the issue:
[user@fedora-36-current ~]$ sudo dnf clean all
24 files removed
[user@fedora-36-current ~]$ sudo dnf update
Fedora 36 - x86_64 2.2 MB/s | 81 MB 00:36
Fedora 36 openh264 (From Cisco) - x86_64 0.0 B/s | 0 B 00:00
Errors duri…
I’m sure someone else will have another suggestion.
mila
November 13, 2022, 7:49pm
16
Hi there,
probably I solved, but I’d like to have feedback from anyone else, before mark it as (possible) solution.
Briefly:
also thanks to:
I’ve searched in cache for repo references and found in mirrors.fedoraproject.org the metalink repo of my broken repositories.
So I removed by hand that (2) metalinks (all occurrences), and relauched upgrade and now it works…
Please let me know if anyone found same way to unlock fedora “not upgrading” issue…
Thanks,
M.
enmus
November 13, 2022, 7:59pm
17
So doing it via webui as @Insurgo explained above didn’t help?
Doing scan and/or Expiration shows some zck being automatically tagged for removal.
Selecting delete selected files:
Cleaning Fedora-36 cache caused zck mismatch error, which required to clean cacher’s cache.
Please respond so it could help others too.
mila
November 14, 2022, 8:08am
18
Hi enmus,
honestly I don’t know why, but in my cacher deploy there isn’t a browser and I haven’t installed one.
So webgui is unuseful for me…
But I can say that I runned many times acngtool, before last trick by hand, starting it from the /etc/cron.daily/<invocation> and each time I haven’t see any update working…
So I don’t think acngtool may be really useful in this matter…
Cheers,
M.
deeplow
November 14, 2022, 12:33pm
19
unman:
@deeplow , @Sven
Done. Hopefully it’s as you intended.
