Right now, I’m saving up for some high-capacity SSDs for my Thinkpad T440p.
I’ve set my eye on a 512GB Transcend M.2 SATA SSD Reference here!
to install the operating system (Maybe 32 to 128GB root partition with the rest used for redundancy overhead).
I do currently have a 1TB SATA SSD which I could use to store all my templates and VMs but, being a total beginner at QubesOS, I wonder if that’s going to be enough storage. How much do Qubes VMs usually take up? Should I get an SSD with a bigger capacity?
Is it possible to configure the installation so that the main operating system is in a separate partition from wherever I store them?
On a side note, is it possible to also create a seperate boot partition in a USB drive so I would have to plug it in when I boot my PC in order to start my OS? I did try it once but I wasn’t able to finish setting up Qubes that way.
100GB of disk space can easily accommodate 20+ linux templates, which offers decent isolation of installed softwares. Your user data are counted separately, because those are stored in the private volumes of you AppVMs, not in the root volumes of templateVMs that are shared.
What if I had a couple of matching SATA SSD’s (one in the main SATA slot and another in a caddy adapter).
Could I make them a RAID array in Qubes and store my templates and AppVMs in them?
If I do set my template and VM pool in a seperate drive,
how much GB do you recommend for the root partition?
