I need to use both a USB mouse and keyboard for carpal tunnel, even though they are not ideal from a security perspective.
Reading the docs, I would like to have more clarity on the most ‘harm reduced’ way of attaching both.
I’ll start by describing my manual config edits, and post-boot process:
I needed to do the manual setup for keyboards in dom0 as described here, so in my /etc/qubes-rpc/policy/qubes.InputKeyboard, the first line is:
sys-usb dom0 ask,default_target=dom0
Unfortunately, when it is set as follows, I never receive a ‘Operation execution’ prompt. Would this perhaps be because non-input functionality is recognized with my keyboard model?
sys-usb dom0 ask,default_target=dom0,usbcore.authorized_default=0
After unlocking LUKS/ user account login with the laptop keyboard, I plug in the USB keyboard. I am prompted with 3 identical ‘Operation execution’ permission dialogs for operation: Input.Keyboard from sys-usb to dom0 (I OK all 3) and 1 permission dialog for Input.Mouse to dom0 (I press cancel).
I plug in my mouse. I am prompted with 1 ‘Operation execution’ permission dialog for operation: Input.Mouse from sys-usb to dom0 (OK), and 6 identical prompts for Input.Keyboard (I press cancel).
Is there room for improvement here, either in config or process?
My X230 does not have a PS/2 port, and even if it did I doubt the ability to find an ergonomic keyboard that isn’t USB.
" How to enable a USB keyboard on a separate USB controller" is recommended for a system with multiple USB controllers, but am I correct that a Thinkpad X230 would only have one?
Any help/insight is incredibly appreciated
