I have a hard time figuring out what the best latest (2023 or newer) ThinkPads are for Qubes, can someone help me or advise me, please?
Topic update: Dell XPS ended up having my attention , thanks for your replies. I hadn’t thought of the XPS line but I have a solid experience with other Dell laptops (non XPS) in the past and I think I should just stick with that
Well, if you are looking for an older model I can recommend the t480. It is supported by coreboot (not merged yet, WiP) but already went to Heads master branch. Specs are very similar to the NV41 64 gb of RAM, works with Qubes quite well. Price tag is around 250$ on used market. I published HCL couple of weeks ago. Lenovo ThinkPad T480 with Heads
the downside is EOL in terms of microcode updates.
Done looking at Thinkpads for today. I can investigate more over the next weeks and month.
How about Dells , I just have Lattitude experience but the XPS sounds very promising. Are they good for Qubes , better than Lenovo?
Intel 12gen+ aren’t supported by XEN, so vcpu are constantly shuffled between e-core and p-core no matter the load. And they lack of cpu governors drivers.
Intel 12th generation works fine. Indeed Xen does not care about the core topology (efficient Vs performance) but this does not mean it doesn’t work. In practice, it’s just slightly slower because load is spread over all cores without caring about the context (performance or energy saving on battery). I’ve been using an i7 1260P for a year and I’m happy of it.
On battery I have 3 to 4 hours of battery life depending what I’m doing.
