Hello,
I am trying to restore my backup from 4.2 onto a fresh 4.3.1 install. Backup total size is a bit under 300gb. It is located on an external drive mounted to the stock vault qube. The first attempt completely froze the system and required a hard shutdown. Upon restart, I found all my qubes there, but most of them did not run. I only found one that successfully restored. I also noticed that dom0 only had about 500mb of space remaining. It appears that the backup file chunks are filling dom0’s root volume and may be freezing the system.
When re-attempting, the restore program (gui) would just give an error about the tmp files in the QubesIncoming/backup#restore/ directory within dom0. Unsure how to proceed, I simply deleted the directory and then painstakingly deleted each restored qube so as not to make a further mess.
I then tried to restore qubes individually and had enough success to get a rough working copy of my 4.2 install. I was even able to restore a vault qube that was about 45gb, but my largest qube (150gb) simply fails and freezes the system, requiring hard shutdowns, with 2 failed attempts so far.
here is the final output before the last freeze from journalctl:
Jul 22 15:26:46 dom0 systemd[9258]: Created slice background.slice - User Background Tasks Slice.
Jul 22 15:26:46 dom0 systemd[9258]: Starting systemd-tmpfiles-clean.service - Cleanup of User’s Temporary Files and Directories…
Jul 22 15:26:46 dom0 systemd[9258]: Finished systemd-tmpfiles-clean.service - Cleanup of User’s Temporary Files and Directories.
Jul 22 15:28:46 dom0 dmeventd[3611]: WARNING: Thin pool qubes_dom0-root–pool-tpool data is now 80.99% full.
Jul 22 15:29:26 dom0 dmeventd[3611]: WARNING: Thin pool qubes_dom0-root–pool-tpool data is now 85.02% full.
Jul 22 15:30:16 dom0 dmeventd[3611]: WARNING: Thin pool qubes_dom0-root–pool-tpool data is now 91.31% full.
Jul 22 15:35:58 dom0 systemd[6961]: Started dbus-:1.1-org.xfce.Xfconf@1.service.
Currently dom0 has about 13gb available. I can watch the disk space go down during the process with watch df -k and fluctuate between 400-650mb of avail space. This lasts for about 30 mins, and then the system completely freezes.
Searching the forum didn’t produce too many similar issues to mine, the closest one I found is Q 4.3 Backup Restore process running out of space, but where/why? but his marked solution was to reinstall the OS using btrfs? which I am really not keen on experimenting with right now. And unlike his system mine has not shown any gracefulness in handling this issue lol.
I have not applied any dom0 or template updates yet, nor completed the 4.2 → 4.3 qubes-dist-upgrade etc final steps, so I consider it a half completed install for now.
Any help is greatly appreciated!
