Autostart program in specific workspace
I use autstart as outlined in the documentation. All programs start in the first workspace. Is there a way to specify a different workspace on a per program basis? Thank you!
With KDE it’s possible:
And also with XFCE (the default desktop environment). But I’m not sure how.
Use devilspie2, which can be installed via sudo qubes-dom0-update devilspie2
Then under ~/.config/devilspie2/ create ws.lua
In it write this:
qube = get_window_property("_QUBES_VMNAME");
ws = 0;
if qube == "personal" then ws = 1;
if qube == "work" then ws = 2;
if ws > 0 then
	set_window_workspace(ws);
	change_workspace(ws);
end
Duplicate discussion here:
Thank you very much for pointing me to devilspie2! I did not know that such a good thing exists. What I was looking for was for instance placing a “personal” firefox in workspace 1, a “personal” thunderbird in 2 and a “vault” keepassxc in 4. I will look into lua scripts for that.
Thanks again.
I was searching for “autostart” so I overlooked it. Sorry!
No worries :slight_smile:
You may find this useful:
workspace_associations = {};
workspace_associations["personal-signal"] = 1;
workspace_associations["personal-email"] = 2;
workspace_associations["personal-vault"] = 3;
fullscreen_apps = {"Signal", "Thunderbird", "KeePassXC", "Firefox"}
domain = get_window_property('_QUBES_VMNAME');
if (domain == "") then
	domain = "dom0";
elseif (string.find(string.lower(domain), "disp")) then
	domain = "disp";
end
application = get_application_name();
window = get_window_name();
debug_print("Domain: " .. domain);
debug_print("Application: " .. application);
debug_print("Window: " .. window);
-- If the domain has a workspace association, then move the window to that workspace.
if (workspace_associations[domain] ~= nil and workspace_associations[domain] <= get_workspace_count()) then
	workspace_number = workspace_associations[domain];
	debug_print("Moving " .. application .. " to workspace " .. workspace_number .. "\n");
	set_window_workspace(workspace_number);
end
-- Maximize all fullscreen applications.
for _, fullscreen_app in ipairs(fullscreen_apps) do
	if (string.find(string.lower(window), string.lower(fullscreen_app))) then
		debug_print("Maximizing " .. application  .. "\n");
		maximize();
	end
end
Thank you very much. I will try it out and report back.
I am sorry I do not fully understand this.
The .lua file should be created at the Dom0? Or the template?
If I try to autostart an .AppImage file when a Qube is starting where do I have to include the filepath to the .AppImage?
In dom0:
  • sudo qubes-dom0-update devilspie2
  • add devilspie2 under “Application Autostart | Session and Startup” in the XFCE Settings app
  • put the .lua file under ~/.config/devilspie2
  • make sure the .lua file contains the code you need, what I posted was just an example how to make sure a window of a specific qube shows on a specific workspace
You would create a .desktop file for it and locate it under ~/.config/autostart in that qube.
What code would be a way to include dipsxxx based on template-yyy in this? Or per application name started, regardless of the VM name (vlc, for instance)?
Here some inspirations for you to play with:
      w_screen, h_screen = get_screen_geometry();
                win_name = get_window_name();
                win_type = get_window_type();
                win_role = get_window_role();
               win_class = get_class_instance_name();
Checkout devilspie2 documentation and search for some samples. There is nothing qubes specific here (except for the _QUBES_VMNAME window property).
local function compare(t, s, n)
   if n==1 then
     return t:sub(n, s:len())==s;
   else
     return t:sub(-s:len())==s;
   end
end
if compare(win_class, "keepassxc", 0) or
    compare(win_class, "evince", 0)   then
   elseif compare(win_class, "Msgcompose", 0) then
(“Msgcompose” is Thunderbirds compose window)
Have fun!
Indeed, Obviously the pie looked too devilish and tempting enough to overlooked it, but thanks a lot and please apologize! :slight_smile:
Fix your “ error and format your code
ws = 0;
      ws = 1
elseif qube == "work" then
      ws = 2
end
if ws > 0 then
end
If you want to put many qubes at same window
ws = 0;
local function has_value (array, val)
    for index, value in ipairs(array) do
        if value == val then
            return true
        end
    end
    return false
end
if has_value({'work, personal'}, qube) then
      ws = 1
elseif has_value({'vault'}, qube) then
      ws = 2
end
if ws > 0 then
end
Seems devilspie2 is now depreciated in Fedora 41 and beyond. What’s the best way to migrate to xdotool?
xdotool doesn’t have a feature that allows you to run code when a window is created, I don’t think there is any replacement for devilspie2 with that specific feature.
I ran into the same issue when I upgraded to 4.3, and I ended up just compiling devilspie2 myself. The make file allows you to specify what version of lua to use as an argument, and I didn’t need to make any change to the code.
After upgrading Qubes OS to 4.3 I’m now using xdotool, wmctrl and xprop and put everything I did with devilspie2 before in a single script, with a keyboard shortcut assigned. So it’s just a single keyboard shortcut to move all windows to the desired workspace, position, size, etc.
Examples can be found e.g. in the following forum topics:
xdotool also has a behave command which can run a command or script automatically, like
xdotool search --class <searchstring> behave %@ focus sleep 3 exec --sync /path/to/your/script
This way the script runs every time a window is focused, though, and not only when a window is created.
Adding for others: Devilspie2 in dom0 on Qubes 4.3
