Just attempted to create a new audio-template using fedora-43-xfce (I was using fedora-42-xfce before), but I saw no change so I swapped back to the out of date audio-template from my backup.
If anyone finds any solution to this, or has any suggestions, I would greatly appreciate it.
At this point, I am considering that it could be something with my “audio-app” and / or “sys-audio” qubes.
@can no idea, for me everything seems to work OK, when you have thoses errors, try to run a “journalctl -xe” and “sudo dmesg” to see if anything obvious popup. From your description, I would suspect that the latest version of a fedora driver is having a issue with your audio hardware, but more logs are needed.
And an issue I am having, I first attach the mic to the qubes I want: everything work. Then I click to attach the mic to another qubes, and time to time, the mic audio never reach the new qubes assigned mic. Didn’t try to debug it yet, but interested to know if someone have this issue too
Hello @neowutran I appreciate the help!
Opening sys-audio after setting it to the newer audio-template and running “journalctl -xe” gives me this:
Apr 30 11:26:13 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a21c6670> link failed: some node was destroyed before the link was created
Apr 30 11:26:13 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a2477990> link failed: some node was destroyed before the link was created
Apr 30 11:26:13 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a2493810> link failed: some node was destroyed before the link was created
Apr 30 11:26:13 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae80bc22e0 channel:80
Apr 30 11:26:13 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae801a94a0 channel:40
Apr 30 11:26:14 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae7f27dac0 channel:70
Apr 30 11:26:14 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a256ab90> link failed: some node was destroyed before the link was created
Apr 30 11:26:14 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae808587d0 channel:31
Apr 30 11:26:15 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a253fac0> link failed: some node was destroyed before the link was created
Apr 30 11:26:15 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a2204240> link failed: some node was destroyed before the link was created
Apr 30 11:26:15 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae80bb7fe0 channel:28
Apr 30 11:26:15 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a1f54980> link failed: some node was destroyed before the link was created
Apr 30 11:26:15 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae808f6390 channel:41
Apr 30 11:26:16 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a2223210> link failed: some node was destroyed before the link was created
Apr 30 11:26:16 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae7f253d60 channel:39
Apr 30 11:26:17 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae807e1360 channel:58
Apr 30 11:26:17 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae7f7ab520 channel:97
Apr 30 11:26:17 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a244fd70> link failed: some node was destroyed before the link was created
Apr 30 11:26:19 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a24a05d0> link failed: some node was destroyed before the link was created
Apr 30 11:26:19 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae80c20020 channel:48
Apr 30 11:26:19 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a2192730> link failed: some node was destroyed before the link was created
Apr 30 11:26:20 sys-audio pipewire-pulse[1067]: mod.protocol-pulse: [PulseAudio Volume Control] timeout on stream 0x56ae80289b80 channel:74
Apr 30 11:26:22 sys-audio wireplumber[659]: wp-event-dispatcher: <WpAsyncEventHook:0x5fa9a1ef5f10> failed: <WpSiStandardLink:0x5fa9a2583a30> link failed: some node was destroyed before the link was created
Running “sudo dmesg” gives me this:
[ 0.475782] hid: raw HID events driver (C) Jiri Kosina
[ 0.475803] usbcore: registered new interface driver usbhid
[ 0.475809] usbhid: USB HID core driver
[ 0.475864] drop_monitor: Initializing network drop monitor service
[ 0.475910] Initializing XFRM netlink socket
[ 0.475924] NET: Registered PF_INET6 protocol family
[ 0.483037] Segment Routing with IPv6
[ 0.483045] RPL Segment Routing with IPv6
[ 0.483053] In-situ OAM (IOAM) with IPv6
[ 0.483068] mip6: Mobile IPv6
[ 0.483074] NET: Registered PF_PACKET protocol family
[ 0.483234] IPI shorthand broadcast: enabled
[ 0.484248] sched_clock: Marking stable (329003167, 154414885)->(1084660233, -601242181)
[ 0.484369] registered taskstats version 1
[ 0.484443] Loading compiled-in X.509 certificates
[ 0.488595] Loaded X.509 cert 'Build time autogenerated kernel key: 23c28d7cb2b61c02d4d709cd4ea44cacfc2f6985'
[ 0.490624] Demotion targets for Node 0: null
[ 0.490632] page_owner is disabled
[ 0.490718] Key type .fscrypt registered
[ 0.490723] Key type fscrypt-provisioning registered
[ 0.490877] Btrfs loaded, zoned=yes, fsverity=yes
[ 0.490894] Key type big_key registered
[ 0.490979] Key type encrypted registered
[ 0.490988] ima: No TPM chip found, activating TPM-bypass!
[ 0.490995] Loading compiled-in module X.509 certificates
[ 0.491216] Loaded X.509 cert 'Build time autogenerated kernel key: 23c28d7cb2b61c02d4d709cd4ea44cacfc2f6985'
[ 0.491288] ima: Allocated hash algorithm: sha256
[ 0.491360] ima: No architecture policies found
[ 0.491373] evm: Initialising EVM extended attributes:
[ 0.491378] evm: security.selinux
[ 0.491383] evm: security.SMACK64 (disabled)
[ 0.491389] evm: security.SMACK64EXEC (disabled)
[ 0.660461] evm: security.SMACK64TRANSMUTE (disabled)
[ 0.660471] evm: security.SMACK64MMAP (disabled)
[ 0.660477] evm: security.apparmor
[ 0.660482] evm: security.ima
[ 0.660486] evm: security.capability
[ 0.660491] evm: HMAC attrs: 0x1
[ 0.662749] alg: No test for 842 (842-scomp)
[ 0.680591] xenbus_probe_frontend: Device with no driver: device/vbd/51712
[ 0.680601] xenbus_probe_frontend: Device with no driver: device/vbd/51728
[ 0.680609] xenbus_probe_frontend: Device with no driver: device/vbd/51744
[ 0.680616] xenbus_probe_frontend: Device with no driver: device/vbd/51760
[ 0.680705] PM: Magic number: 6:974:393
[ 0.680711] PM: hash matches drivers/base/power/main.c:1972
[ 0.680779] RAS: Correctable Errors collector initialized.
[ 0.680810] clk: Disabling unused clocks
[ 0.680817] PM: genpd: Disabling unused power domains
[ 0.691863] Freeing unused decrypted memory: 2028K
[ 0.692549] Freeing unused kernel image (initmem) memory: 5804K
[ 0.692576] Write protecting the kernel read-only data: 34816k
[ 0.693090] Freeing unused kernel image (text/rodata gap) memory: 1344K
[ 0.693388] Freeing unused kernel image (rodata/data gap) memory: 1808K
[ 0.693402] Run /init as init process
[ 0.693407] with arguments:
[ 0.693408] /init
[ 0.693408] rd_NO_PLYMOUTH
[ 0.693409] with environment:
[ 0.693409] HOME=/
[ 0.693410] TERM=linux
[ 0.697656] Invalid max_queues (4), will use default max: 2.
[ 0.702257] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[ 0.704245] xvda: xvda1 xvda2 xvda3
[ 0.705357] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[ 0.706097] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[ 0.707740] blkfront: xvdd: barrier or flush: disabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[ 1.069184] xvdc: xvdc1 xvdc3
[ 1.120061] EXT4-fs (xvda3): mounted filesystem 60b6a997-f057-44dc-a099-1f4ce427d61d r/w with ordered data mode. Quota mode: none.
[ 1.122500] EXT4-fs (xvdd): mounting ext3 file system using the ext4 subsystem
[ 1.122956] EXT4-fs (xvdd): mounted filesystem 0a88ee2d-de6c-406e-b4f6-ec799c8ec72c ro with ordered data mode. Quota mode: none.
[ 1.133995] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input4
[ 1.224129] audit: type=1404 audit(1777573338.247:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 enabled=1 old-enabled=1 lsm=selinux res=1
[ 1.240762] SELinux: Permission firmware_load in class system not defined in policy.
[ 1.240778] SELinux: Permission kexec_image_load in class system not defined in policy.
[ 1.240787] SELinux: Permission kexec_initramfs_load in class system not defined in policy.
[ 1.240797] SELinux: Permission policy_load in class system not defined in policy.
[ 1.240805] SELinux: Permission x509_certificate_load in class system not defined in policy.
[ 1.240842] SELinux: Permission allowed in class io_uring not defined in policy.
[ 1.240851] SELinux: the above unknown classes and permissions will be allowed
[ 1.241894] SELinux: policy capability network_peer_controls=1
[ 1.241905] SELinux: policy capability open_perms=1
[ 1.241911] SELinux: policy capability extended_socket_class=1
[ 1.241918] SELinux: policy capability always_check_network=0
[ 1.241925] SELinux: policy capability cgroup_seclabel=1
[ 1.241930] SELinux: policy capability nnp_nosuid_transition=1
[ 1.241937] SELinux: policy capability genfs_seclabel_symlinks=1
[ 1.241944] SELinux: policy capability ioctl_skip_cloexec=0
[ 1.241951] SELinux: policy capability userspace_initial_context=0
[ 1.241958] SELinux: policy capability netlink_xperm=0
[ 1.241964] SELinux: policy capability netif_wildcard=0
[ 1.241970] SELinux: policy capability genfs_seclabel_wildcard=0
[ 1.241977] SELinux: policy capability functionfs_seclabel=0
[ 1.257151] audit: type=1403 audit(1777573338.280:3): auid=4294967295 ses=4294967295 lsm=selinux res=1
[ 1.257539] systemd[1]: Successfully loaded SELinux policy in 33.347ms.
[ 1.670119] systemd[1]: Relabeled /dev/, /dev/shm/, /run/ in 1.900ms.
[ 2.008236] systemd[1]: systemd 258.7-1.fc43 running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA +IPE +SMACK +SECCOMP -GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN -IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP +SYSVINIT +LIBARCHIVE)
[ 2.008276] systemd[1]: Detected virtualization xen.
[ 2.008289] systemd[1]: Detected architecture x86-64.
[ 2.020461] systemd[1]: No hostname configured, using default hostname.
[ 2.020497] systemd[1]: Hostname set to <fedora>.
[ 2.051543] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
[ 2.081748] zram: Added device: zram0
[ 2.200912] systemd[1]: /usr/lib/systemd/system/qubes-gui-agent.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 2.211151] systemd[1]: Queued start job for default target multi-user.target.
[ 2.220553] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 2.220902] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 2.221132] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[ 2.221359] systemd[1]: Created slice system-systemd\x2dzram\x2dsetup.slice - Slice /system/systemd-zram-setup.
[ 2.221535] systemd[1]: Created slice user.slice - User and Session Slice.
[ 2.221609] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ 2.221666] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 2.221873] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 2.221924] systemd[1]: Expecting device dev-hvc0.device - /dev/hvc0...
[ 2.221956] systemd[1]: Expecting device dev-xvdc1.device - /dev/xvdc1...
[ 2.221984] systemd[1]: Expecting device dev-zram0.device - /dev/zram0...
[ 2.222014] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[ 2.222051] systemd[1]: Reached target imports.target - Image Downloads.
[ 2.222085] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 2.222128] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[ 2.222159] systemd[1]: Reached target slices.target - Slice Units.
[ 2.222198] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 2.222963] systemd[1]: Listening on systemd-ask-password.socket - Query the User Interactively for a Password.
[ 2.223995] systemd[1]: Listening on systemd-coredump.socket - Process Core Dump Socket.
[ 2.224604] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[ 2.225326] systemd[1]: Listening on systemd-factory-reset.socket - Factory Reset Management.
[ 2.225615] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ 2.225807] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 2.225956] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[ 2.226005] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[ 2.226027] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[ 2.226174] systemd[1]: Listening on systemd-resolved-monitor.socket - Resolve Monitor Varlink Socket.
[ 2.226260] systemd[1]: Listening on systemd-resolved-varlink.socket - Resolve Service Varlink Socket.
[ 2.416538] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 2.416759] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 2.416884] systemd[1]: Listening on systemd-udevd-varlink.socket - udev Varlink Socket.
[ 2.418282] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[ 2.418739] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[ 2.419141] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[ 2.419554] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[ 2.420074] systemd[1]: Starting dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early...
[ 2.420151] systemd[1]: fips-crypto-policy-overlay.service - Bind-mount FIPS crypto-policy in FIPS mode skipped, unmet condition check ConditionKernelCommandLine=fips=1
[ 2.420702] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[ 2.421457] systemd[1]: modprobe@configfs.service - Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[ 2.421845] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[ 2.422870] systemd[1]: modprobe@dm_mod.service - Load Kernel Module dm_mod skipped, unmet condition check ConditionKernelModuleLoaded=!dm_mod
[ 2.422905] systemd[1]: modprobe@drm.service - Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[ 2.424665] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[ 2.425214] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[ 2.425374] systemd[1]: systemd-boot-clear-sysfail.service - Clear SysFail Entry If The Boot Is Successful skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/LoaderEntrySysFail-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f
[ 2.425433] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[ 2.427484] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 2.433939] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 2.438866] Adding 1048572k swap on /dev/xvdc1. Priority:-2 extents:1 across:1048572k SS
[ 2.441012] systemd[1]: Starting systemd-network-generator.service - Generate Network Units from Kernel Command Line...
[ 2.441096] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[ 2.441175] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[ 2.441197] loop: module loaded
[ 2.444662] fuse: init (API version 7.45)
[ 2.446168] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[ 2.447370] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 2.450613] i2c_dev: i2c /dev entries driver
[ 2.451139] systemd[1]: Condition check resulted in dev-xvdc1.swap - /dev/xvdc1 being skipped.
[ 2.613555] systemd[1]: Unnecessary job was removed for dev-xvdc1.device - /dev/xvdc1.
[ 2.614623] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[ 2.614759] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 2.614841] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 2.614913] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 2.615022] systemd[1]: dev-xvdc1-swap.service: Deactivated successfully.
[ 2.615122] systemd[1]: Finished dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early.
[ 2.615303] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ 2.615390] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[ 2.615501] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.615583] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[ 2.615696] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 2.615763] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[ 2.616385] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[ 2.616459] systemd[1]: systemd-fsck-root.service - File System Check on Root Device skipped, unmet condition check ConditionPathIsReadWrite=!/
[ 2.617497] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[ 2.617563] systemd[1]: systemd-repart.service - Repartition Root Disk skipped, no trigger condition checks were met.
[ 2.619169] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[ 2.620435] xen:xen_evtchn: Event-channel device installed
[ 2.625325] systemd[1]: Finished systemd-network-generator.service - Generate Network Units from Kernel Command Line.
[ 2.625452] systemd-journald[239]: Collecting audit messages is enabled.
[ 2.631668] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[ 2.631758] audit: type=1130 audit(1777573339.655:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-udev-load-credentials comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.631987] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[ 2.818224] EXT4-fs (xvda3): re-mounted 60b6a997-f057-44dc-a099-1f4ce427d61d.
[ 2.837754] systemd[1]: Started systemd-journald.service - Journal Service.
[ 2.839424] audit: type=1130 audit(1777573339.861:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.839544] audit: type=1130 audit(1777573339.863:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.854125] systemd-journald[239]: Received client request to flush runtime journal.
[ 2.856798] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 2.856845] db_root: cannot open: /etc/target
[ 2.871490] audit: type=1130 audit(1777573339.895:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.881368] audit: type=1130 audit(1777573339.904:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-tmpfiles-setup-dev-early comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.885404] audit: type=1130 audit(1777573339.908:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.888577] audit: type=1130 audit(1777573339.912:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.000366] EXT4-fs (xvdb): mounted filesystem a77521cc-e5cd-42b5-9126-2537aa0e88b6 r/w without journal. Quota mode: none.
[ 3.084581] zram0: detected capacity change from 0 to 1439744
[ 3.111857] Adding 719868k swap on /dev/zram0. Priority:100 extents:1 across:719868k SSDsc
[ 3.188156] piix4_smbus 0000:00:01.3: SMBus Host Controller not enabled!
[ 3.201334] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 3.208561] FDC 0 is a S82078B
[ 3.211307] ehci-pci 0000:00:05.0: EHCI Host Controller
[ 3.211372] ehci-pci 0000:00:05.0: new USB bus registered, assigned bus number 1
[ 3.211929] ehci-pci 0000:00:05.0: irq 39, io mem 0xf2013000
[ 3.217490] ehci-pci 0000:00:05.0: USB 2.0 started, EHCI 1.00
[ 3.217550] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[ 3.217560] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.217569] usb usb1: Product: EHCI Host Controller
[ 3.217575] usb usb1: Manufacturer: Linux 6.18.19-1.qubes.fc37.x86_64 ehci_hcd
[ 3.217584] usb usb1: SerialNumber: 0000:00:05.0
[ 3.217659] hub 1-0:1.0: USB hub found
[ 3.217668] hub 1-0:1.0: 6 ports detected
[ 3.425688] intel_rapl_msr: PL4 support detected.
[ 3.458468] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 3.609343] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
[ 3.609372] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
[ 3.609395] usb 1-1: Product: QEMU USB Tablet
[ 3.609411] usb 1-1: Manufacturer: QEMU
[ 3.609443] usb 1-1: SerialNumber: 42
[ 3.629502] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:05.0/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input6
[ 3.629822] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:05.0-1/input0
[ 12.072931] vhci_hcd vhci_hcd.0: USB/IP Virtual Host Controller
[ 12.073029] vhci_hcd vhci_hcd.0: new USB bus registered, assigned bus number 2
[ 12.073044] vhci_hcd: created sysfs vhci_hcd.0
[ 12.073073] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[ 12.073083] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.073094] usb usb2: Product: USB/IP Virtual Host Controller
[ 12.073103] usb usb2: Manufacturer: Linux 6.18.19-1.qubes.fc37.x86_64 vhci_hcd
[ 12.073111] usb usb2: SerialNumber: vhci_hcd.0
[ 12.073192] hub 2-0:1.0: USB hub found
[ 12.073200] hub 2-0:1.0: 8 ports detected
[ 12.073296] vhci_hcd vhci_hcd.0: USB/IP Virtual Host Controller
[ 12.073331] vhci_hcd vhci_hcd.0: new USB bus registered, assigned bus number 3
[ 12.073347] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 12.073368] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
[ 12.073379] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.073389] usb usb3: Product: USB/IP Virtual Host Controller
[ 12.073397] usb usb3: Manufacturer: Linux 6.18.19-1.qubes.fc37.x86_64 vhci_hcd
[ 12.073407] usb usb3: SerialNumber: vhci_hcd.0
[ 12.074495] hub 3-0:1.0: USB hub found
[ 12.074505] hub 3-0:1.0: 8 ports detected
[ 12.132751] systemd-journald[239]: Time jumped backwards, rotating.
[ 12.317468] vhci_hcd vhci_hcd.0: pdev(0) rhport(0) sockfd(0)
[ 12.317484] vhci_hcd vhci_hcd.0: devid(131078) speed(3) speed_str(high-speed)
[ 12.317527] vhci_hcd vhci_hcd.0: Device attached
[ 12.530429] usb 2-1: new high-speed USB device number 2 using vhci_hcd
[ 12.642703] usb 2-1: SetAddress Request (2) to port 0
[ 12.658099] usb 2-1: New USB device found, idVendor=20b1, idProduct=3008, bcdDevice= 7.20
[ 12.658115] usb 2-1: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[ 12.658124] usb 2-1: Product: iFi (by AMR) HD USB Audio
[ 12.658130] usb 2-1: Manufacturer: iFi (by AMR)
[ 12.658135] usb 2-1: SerialNumber: 0003
[ 12.671194] hid-generic 0003:20B1:3008.0002: hiddev96,hidraw1: USB HID v1.10 Device [iFi (by AMR) iFi (by AMR) HD USB Audio] on usb-vhci_hcd.0-1/input3
[ 12.711844] mc: Linux media interface: v0.10
[ 12.819004] usbcore: registered new interface driver snd-usb-audio
[ 13.010689] usb usb2: Not yet implemented
[ 13.010704] usb usb2: Not yet implemented
[ 13.010711] usb usb2: Not yet implemented
[ 13.010717] usb usb2: Not yet implemented
[ 13.010723] usb usb2: Not yet implemented
[ 13.010729] usb usb2: Not yet implemented
[ 13.010736] usb usb2: Not yet implemented
[ 13.010742] usb usb2: Not yet implemented
[ 13.010748] usb usb2: Not yet implemented
[ 13.010754] usb usb2: Not yet implemented
[ 13.017985] vhci_hcd: unlink->seqnum 149
[ 13.017997] vhci_hcd: urb->status -104
[ 13.018003] vhci_hcd: unlink->seqnum 150
[ 13.018007] vhci_hcd: unlink->seqnum 151
[ 13.018012] vhci_hcd: urb->status -104
[ 13.018017] vhci_hcd: unlink->seqnum 150
[ 13.018022] vhci_hcd: unlink->seqnum 152
[ 13.018026] vhci_hcd: urb->status -104
[ 13.018031] vhci_hcd: unlink->seqnum 150
[ 13.018036] vhci_hcd: unlink->seqnum 153
[ 13.018040] vhci_hcd: urb->status -104
[ 13.018045] vhci_hcd: unlink->seqnum 150
[ 13.018049] vhci_hcd: unlink->seqnum 154
[ 13.018054] vhci_hcd: urb->status -104
[ 13.018058] vhci_hcd: unlink->seqnum 150
[ 13.018063] vhci_hcd: unlink->seqnum 155
[ 13.018067] vhci_hcd: urb->status -104
[ 13.018072] vhci_hcd: unlink->seqnum 150
[ 13.018076] vhci_hcd: unlink->seqnum 156
[ 13.018081] vhci_hcd: urb->status -104
[ 13.018085] vhci_hcd: unlink->seqnum 150
[ 13.018090] vhci_hcd: unlink->seqnum 157
[ 13.018094] vhci_hcd: urb->status -104
[ 13.018099] vhci_hcd: unlink->seqnum 150
[ 13.018103] vhci_hcd: unlink->seqnum 158
[ 13.018108] vhci_hcd: unlink->seqnum 159
[ 13.018112] vhci_hcd: urb->status -104
[ 13.018117] vhci_hcd: unlink->seqnum 150
[ 13.018121] vhci_hcd: unlink->seqnum 158
[ 13.018125] vhci_hcd: unlink->seqnum 160
[ 13.018130] vhci_hcd: urb->status -104
[ 13.018134] vhci_hcd: unlink->seqnum 150
[ 13.018139] vhci_hcd: unlink->seqnum 158
[ 13.018143] vhci_hcd: unlink->seqnum 161
[ 13.018148] vhci_hcd: urb->status -104
[ 13.018152] vhci_hcd: unlink->seqnum 150
[ 13.018157] vhci_hcd: unlink->seqnum 158
[ 13.018161] vhci_hcd: unlink->seqnum 162
[ 13.018165] vhci_hcd: urb->status -104
[ 13.018170] vhci_hcd: unlink->seqnum 150
[ 13.018174] vhci_hcd: unlink->seqnum 158
[ 13.018179] vhci_hcd: unlink->seqnum 163
[ 13.018183] vhci_hcd: urb->status -104
[ 13.018188] vhci_hcd: unlink->seqnum 150
[ 13.018192] vhci_hcd: unlink->seqnum 158
[ 13.018196] vhci_hcd: unlink->seqnum 164
[ 13.018201] vhci_hcd: urb->status -104
[ 13.018206] vhci_hcd: unlink->seqnum 150
[ 13.018211] vhci_hcd: urb->status -104
[ 13.018833] vhci_hcd: unlink->seqnum 158
[ 13.018839] vhci_hcd: urb->status -104
[ 18.012378] vhci_get_frame_number: 12807 callbacks suppressed
[ 18.012382] usb usb2: Not yet implemented
[ 18.012432] usb usb2: Not yet implemented
[ 18.013365] usb usb2: Not yet implemented
[ 18.013379] usb usb2: Not yet implemented
[ 18.013596] usb usb2: Not yet implemented
[ 18.014332] usb usb2: Not yet implemented
[ 18.014346] usb usb2: Not yet implemented
[ 18.014358] usb usb2: Not yet implemented
[ 18.014405] usb usb2: Not yet implemented
[ 18.014433] usb usb2: Not yet implemented
[ 23.013041] vhci_get_frame_number: 12882 callbacks suppressed
[ 23.013044] usb usb2: Not yet implemented
[ 23.013061] usb usb2: Not yet implemented
[ 23.013077] usb usb2: Not yet implemented
[ 23.013083] usb usb2: Not yet implemented
[ 23.014013] usb usb2: Not yet implemented
[ 23.014021] usb usb2: Not yet implemented
[ 23.015033] usb usb2: Not yet implemented
[ 23.015040] usb usb2: Not yet implemented
[ 23.016040] usb usb2: Not yet implemented
[ 23.016046] usb usb2: Not yet implemented
[ 28.014321] vhci_get_frame_number: 12885 callbacks suppressed
[ 28.014324] usb usb2: Not yet implemented
[ 28.014342] usb usb2: Not yet implemented
[ 28.015377] usb usb2: Not yet implemented
[ 28.015387] usb usb2: Not yet implemented
[ 28.016363] usb usb2: Not yet implemented
[ 28.016373] usb usb2: Not yet implemented
[ 28.016769] usb usb2: Not yet implemented
[ 28.016777] usb usb2: Not yet implemented
[ 28.017317] usb usb2: Not yet implemented
[ 28.017326] usb usb2: Not yet implemented
[ 33.015263] vhci_get_frame_number: 12884 callbacks suppressed
[ 33.015266] usb usb2: Not yet implemented
[ 33.015283] usb usb2: Not yet implemented
[ 33.016286] usb usb2: Not yet implemented
[ 33.016295] usb usb2: Not yet implemented
[ 33.017212] usb usb2: Not yet implemented
[ 33.017220] usb usb2: Not yet implemented
[ 33.017231] usb usb2: Not yet implemented
[ 33.017236] usb usb2: Not yet implemented
[ 33.018260] usb usb2: Not yet implemented
[ 33.018268] usb usb2: Not yet implemented
[ 38.016068] vhci_get_frame_number: 12883 callbacks suppressed
[ 38.016071] usb usb2: Not yet implemented
[ 38.016088] usb usb2: Not yet implemented
[ 38.017037] usb usb2: Not yet implemented
[ 38.017046] usb usb2: Not yet implemented
[ 38.018079] usb usb2: Not yet implemented
[ 38.018086] usb usb2: Not yet implemented
[ 38.019070] usb usb2: Not yet implemented
[ 38.019077] usb usb2: Not yet implemented
[ 38.019097] usb usb2: Not yet implemented
[ 38.019102] usb usb2: Not yet implemented
[ 42.509762] usb 2-1: seqnum max
[ 43.016490] vhci_get_frame_number: 12883 callbacks suppressed
[ 43.016494] usb usb2: Not yet implemented
[ 43.017061] usb usb2: Not yet implemented
[ 43.017068] usb usb2: Not yet implemented
[ 43.018107] usb usb2: Not yet implemented
[ 43.018114] usb usb2: Not yet implemented
[ 43.018144] usb usb2: Not yet implemented
[ 43.018149] usb usb2: Not yet implemented
[ 43.019170] usb usb2: Not yet implemented
[ 43.019177] usb usb2: Not yet implemented
[ 43.020104] usb usb2: Not yet implemented
[ 48.018033] vhci_get_frame_number: 12883 callbacks suppressed
[ 48.018037] usb usb2: Not yet implemented
[ 48.018054] usb usb2: Not yet implemented
[ 48.019074] usb usb2: Not yet implemented
[ 48.019082] usb usb2: Not yet implemented
[ 48.019087] usb usb2: Not yet implemented
[ 48.019116] usb usb2: Not yet implemented
[ 48.019121] usb usb2: Not yet implemented
[ 48.020093] usb usb2: Not yet implemented
[ 48.020099] usb usb2: Not yet implemented
[ 48.021107] usb usb2: Not yet implemented
[ 53.018461] vhci_get_frame_number: 12881 callbacks suppressed
[ 53.018466] usb usb2: Not yet implemented
[ 53.018497] usb usb2: Not yet implemented
[ 53.018510] usb usb2: Not yet implemented
[ 53.018520] usb usb2: Not yet implemented
[ 53.019464] usb usb2: Not yet implemented
[ 53.019477] usb usb2: Not yet implemented
[ 53.020479] usb usb2: Not yet implemented
[ 53.020491] usb usb2: Not yet implemented
[ 53.021471] usb usb2: Not yet implemented
[ 53.021482] usb usb2: Not yet implemented
[ 58.020433] vhci_get_frame_number: 12869 callbacks suppressed
[ 58.020437] usb usb2: Not yet implemented
[ 58.020468] usb usb2: Not yet implemented
[ 58.020478] usb usb2: Not yet implemented
[ 58.021238] usb usb2: Not yet implemented
[ 58.021253] usb usb2: Not yet implemented
[ 58.022243] usb usb2: Not yet implemented
[ 58.022256] usb usb2: Not yet implemented
[ 58.023294] usb usb2: Not yet implemented
[ 58.023306] usb usb2: Not yet implemented
[ 58.024298] usb usb2: Not yet implemented
[ 63.021460] vhci_get_frame_number: 12883 callbacks suppressed
[ 63.021464] usb usb2: Not yet implemented
[ 63.021483] usb usb2: Not yet implemented
[ 63.022811] usb usb2: Not yet implemented
[ 63.022820] usb usb2: Not yet implemented
[ 63.023467] usb usb2: Not yet implemented
[ 63.023475] usb usb2: Not yet implemented
[ 63.023481] usb usb2: Not yet implemented
[ 63.023490] usb usb2: Not yet implemented
[ 63.023495] usb usb2: Not yet implemented
[ 63.026133] usb usb2: Not yet implemented
[ 68.023324] vhci_get_frame_number: 12885 callbacks suppressed
[ 68.023328] usb usb2: Not yet implemented
[ 68.023345] usb usb2: Not yet implemented
[ 68.024310] usb usb2: Not yet implemented
[ 68.024318] usb usb2: Not yet implemented
[ 68.024334] usb usb2: Not yet implemented
[ 68.024339] usb usb2: Not yet implemented
[ 68.025438] usb usb2: Not yet implemented
[ 68.025447] usb usb2: Not yet implemented
[ 68.025453] usb usb2: Not yet implemented
[ 68.026053] usb usb2: Not yet implemented
[ 73.024291] vhci_get_frame_number: 12884 callbacks suppressed
[ 73.024295] usb usb2: Not yet implemented
[ 73.024312] usb usb2: Not yet implemented
[ 73.025318] usb usb2: Not yet implemented
[ 73.025324] usb usb2: Not yet implemented
[ 73.026311] usb usb2: Not yet implemented
[ 73.026316] usb usb2: Not yet implemented
[ 73.026323] usb usb2: Not yet implemented
[ 73.026328] usb usb2: Not yet implemented
[ 73.027320] usb usb2: Not yet implemented
[ 73.027325] usb usb2: Not yet implemented
[ 78.025017] vhci_get_frame_number: 12883 callbacks suppressed
[ 78.025020] usb usb2: Not yet implemented
[ 78.025037] usb usb2: Not yet implemented
[ 78.026009] usb usb2: Not yet implemented
[ 78.026017] usb usb2: Not yet implemented
[ 78.026162] usb usb2: Not yet implemented
[ 78.026167] usb usb2: Not yet implemented
[ 78.027272] usb usb2: Not yet implemented
[ 78.027278] usb usb2: Not yet implemented
[ 78.028281] usb usb2: Not yet implemented
[ 78.028286] usb usb2: Not yet implemented
[ 83.026112] vhci_get_frame_number: 12884 callbacks suppressed
[ 83.026116] usb usb2: Not yet implemented
[ 83.026132] usb usb2: Not yet implemented
[ 83.027082] usb usb2: Not yet implemented
[ 83.027090] usb usb2: Not yet implemented
[ 83.027107] usb usb2: Not yet implemented
[ 83.027112] usb usb2: Not yet implemented
[ 83.028153] usb usb2: Not yet implemented
[ 83.028159] usb usb2: Not yet implemented
[ 83.029130] usb usb2: Not yet implemented
[ 83.029135] usb usb2: Not yet implemented
[ 88.026708] vhci_get_frame_number: 12883 callbacks suppressed
[ 88.026711] usb usb2: Not yet implemented
[ 88.026729] usb usb2: Not yet implemented
[ 88.027727] usb usb2: Not yet implemented
[ 88.027736] usb usb2: Not yet implemented
[ 88.028708] usb usb2: Not yet implemented
[ 88.028716] usb usb2: Not yet implemented
[ 88.029725] usb usb2: Not yet implemented
[ 88.029732] usb usb2: Not yet implemented
[ 88.029753] usb usb2: Not yet implemented
[ 88.029758] usb usb2: Not yet implemented
[ 93.027820] vhci_get_frame_number: 12706 callbacks suppressed
[ 93.027823] usb usb2: Not yet implemented
[ 93.027840] usb usb2: Not yet implemented
[ 93.027860] usb usb2: Not yet implemented
[ 93.027865] usb usb2: Not yet implemented
[ 93.029140] usb usb2: Not yet implemented
[ 93.029148] usb usb2: Not yet implemented
[ 93.029794] usb usb2: Not yet implemented
[ 93.029801] usb usb2: Not yet implemented
[ 93.030860] usb usb2: Not yet implemented
[ 93.030865] usb usb2: Not yet implemented
[ 98.028658] vhci_get_frame_number: 12884 callbacks suppressed
[ 98.028661] usb usb2: Not yet implemented
[ 98.028678] usb usb2: Not yet implemented
[ 98.028704] usb usb2: Not yet implemented
[ 98.028709] usb usb2: Not yet implemented
[ 98.029996] usb usb2: Not yet implemented
[ 98.030004] usb usb2: Not yet implemented
[ 98.030646] usb usb2: Not yet implemented
[ 98.030654] usb usb2: Not yet implemented
[ 98.031670] usb usb2: Not yet implemented
[ 98.031676] usb usb2: Not yet implemented
[ 103.030296] vhci_get_frame_number: 12885 callbacks suppressed
[ 103.030301] usb usb2: Not yet implemented
[ 103.030332] usb usb2: Not yet implemented
[ 103.030405] usb usb2: Not yet implemented
[ 103.030416] usb usb2: Not yet implemented
[ 103.031304] usb usb2: Not yet implemented
[ 103.031316] usb usb2: Not yet implemented
[ 103.032262] usb usb2: Not yet implemented
[ 103.032274] usb usb2: Not yet implemented
[ 103.033343] usb usb2: Not yet implemented
[ 103.033355] usb usb2: Not yet implemented
[ 108.030460] vhci_get_frame_number: 12883 callbacks suppressed
[ 108.030463] usb usb2: Not yet implemented
[ 108.030493] usb usb2: Not yet implemented
[ 108.030514] usb usb2: Not yet implemented
[ 108.031485] usb usb2: Not yet implemented
[ 108.031491] usb usb2: Not yet implemented
[ 108.032478] usb usb2: Not yet implemented
[ 108.032485] usb usb2: Not yet implemented
[ 108.033658] usb usb2: Not yet implemented
[ 108.033665] usb usb2: Not yet implemented
[ 108.034642] usb usb2: Not yet implemented
[ 113.031997] vhci_get_frame_number: 12883 callbacks suppressed
[ 113.032015] usb usb2: Not yet implemented
[ 113.032149] usb usb2: Not yet implemented
[ 113.033088] usb usb2: Not yet implemented
[ 113.033138] usb usb2: Not yet implemented
[ 113.033176] usb usb2: Not yet implemented
[ 113.034565] usb usb2: Not yet implemented
[ 113.034620] usb usb2: Not yet implemented
[ 113.034672] usb usb2: Not yet implemented
[ 113.034712] usb usb2: Not yet implemented
[ 113.034930] usb usb2: Not yet implemented
[ 118.033366] vhci_get_frame_number: 12885 callbacks suppressed
[ 118.033370] usb usb2: Not yet implemented
[ 118.033388] usb usb2: Not yet implemented
[ 118.034334] usb usb2: Not yet implemented
[ 118.034355] usb usb2: Not yet implemented
[ 118.035390] usb usb2: Not yet implemented
[ 118.035397] usb usb2: Not yet implemented
[ 118.035402] usb usb2: Not yet implemented
[ 118.035409] usb usb2: Not yet implemented
[ 118.035414] usb usb2: Not yet implemented
[ 118.035442] usb usb2: Not yet implemented
[ 123.033565] vhci_get_frame_number: 12882 callbacks suppressed
[ 123.033584] usb usb2: Not yet implemented
[ 123.033722] usb usb2: Not yet implemented
[ 123.036423] usb usb2: Not yet implemented
[ 123.036478] usb usb2: Not yet implemented
[ 123.036541] usb usb2: Not yet implemented
[ 123.036580] usb usb2: Not yet implemented
[ 123.036629] usb usb2: Not yet implemented
[ 123.036668] usb usb2: Not yet implemented
[ 123.036710] usb usb2: Not yet implemented
[ 123.036749] usb usb2: Not yet implemented
[ 128.035298] vhci_get_frame_number: 12885 callbacks suppressed
[ 128.035302] usb usb2: Not yet implemented
[ 128.035319] usb usb2: Not yet implemented
[ 128.036333] usb usb2: Not yet implemented
[ 128.036342] usb usb2: Not yet implemented
[ 128.037272] usb usb2: Not yet implemented
[ 128.037279] usb usb2: Not yet implemented
[ 128.038324] usb usb2: Not yet implemented
[ 128.038331] usb usb2: Not yet implemented
[ 128.038340] usb usb2: Not yet implemented
[ 128.038345] usb usb2: Not yet implemented
[ 133.036079] vhci_get_frame_number: 12884 callbacks suppressed
[ 133.036083] usb usb2: Not yet implemented
[ 133.036100] usb usb2: Not yet implemented
[ 133.037129] usb usb2: Not yet implemented
[ 133.037139] usb usb2: Not yet implemented
[ 133.038124] usb usb2: Not yet implemented
[ 133.038132] usb usb2: Not yet implemented
[ 133.039121] usb usb2: Not yet implemented
[ 133.039128] usb usb2: Not yet implemented
[ 133.039148] usb usb2: Not yet implemented
[ 133.039153] usb usb2: Not yet implemented
[ 138.036572] vhci_get_frame_number: 12881 callbacks suppressed
[ 138.036577] usb usb2: Not yet implemented
[ 138.036595] usb usb2: Not yet implemented
[ 138.036615] usb usb2: Not yet implemented
[ 138.036620] usb usb2: Not yet implemented
[ 138.037625] usb usb2: Not yet implemented
[ 138.037633] usb usb2: Not yet implemented
[ 138.038667] usb usb2: Not yet implemented
[ 138.038677] usb usb2: Not yet implemented
[ 138.039136] usb usb2: Not yet implemented
[ 138.039142] usb usb2: Not yet implemented
[ 143.037462] vhci_get_frame_number: 12885 callbacks suppressed
[ 143.037466] usb usb2: Not yet implemented
[ 143.037572] usb usb2: Not yet implemented
[ 143.037580] usb usb2: Not yet implemented
[ 143.038584] usb usb2: Not yet implemented
[ 143.038591] usb usb2: Not yet implemented
[ 143.039594] usb usb2: Not yet implemented
[ 143.039601] usb usb2: Not yet implemented
[ 143.040596] usb usb2: Not yet implemented
[ 143.040603] usb usb2: Not yet implemented
[ 143.041613] usb usb2: Not yet implemented
[ 148.039322] vhci_get_frame_number: 12883 callbacks suppressed
[ 148.039326] usb usb2: Not yet implemented
[ 148.039343] usb usb2: Not yet implemented
[ 148.040326] usb usb2: Not yet implemented
[ 148.040336] usb usb2: Not yet implemented
[ 148.040341] usb usb2: Not yet implemented
[ 148.041132] usb usb2: Not yet implemented
[ 148.041139] usb usb2: Not yet implemented
[ 148.041303] usb usb2: Not yet implemented
[ 148.041310] usb usb2: Not yet implemented
[ 148.042376] usb usb2: Not yet implemented
[ 153.039691] vhci_get_frame_number: 12883 callbacks suppressed
[ 153.039696] usb usb2: Not yet implemented
[ 153.039726] usb usb2: Not yet implemented
[ 153.040694] usb usb2: Not yet implemented
[ 153.040709] usb usb2: Not yet implemented
[ 153.041807] usb usb2: Not yet implemented
[ 153.041820] usb usb2: Not yet implemented
[ 153.041839] usb usb2: Not yet implemented
[ 153.041849] usb usb2: Not yet implemented
[ 153.041858] usb usb2: Not yet implemented
[ 153.042563] usb usb2: Not yet implemented
[ 158.041373] vhci_get_frame_number: 12886 callbacks suppressed
[ 158.041377] usb usb2: Not yet implemented
[ 158.041394] usb usb2: Not yet implemented
[ 158.042335] usb usb2: Not yet implemented
[ 158.042452] usb usb2: Not yet implemented
[ 158.043336] usb usb2: Not yet implemented
[ 158.043348] usb usb2: Not yet implemented
[ 158.044349] usb usb2: Not yet implemented
[ 158.044355] usb usb2: Not yet implemented
[ 158.044370] usb usb2: Not yet implemented
[ 158.044376] usb usb2: Not yet implemented
[ 163.043319] vhci_get_frame_number: 12885 callbacks suppressed
[ 163.043323] usb usb2: Not yet implemented
[ 163.043381] usb usb2: Not yet implemented
[ 163.044324] usb usb2: Not yet implemented
[ 163.044433] usb usb2: Not yet implemented
[ 163.045395] usb usb2: Not yet implemented
[ 163.045408] usb usb2: Not yet implemented
[ 163.045423] usb usb2: Not yet implemented
[ 163.045433] usb usb2: Not yet implemented
[ 163.046517] usb usb2: Not yet implemented
[ 163.046530] usb usb2: Not yet implemented
[ 168.044035] vhci_get_frame_number: 12884 callbacks suppressed
[ 168.044041] usb usb2: Not yet implemented
[ 168.044078] usb usb2: Not yet implemented
[ 168.045072] usb usb2: Not yet implemented
[ 168.045085] usb usb2: Not yet implemented
[ 168.046031] usb usb2: Not yet implemented
[ 168.046050] usb usb2: Not yet implemented
[ 168.046073] usb usb2: Not yet implemented
[ 168.046083] usb usb2: Not yet implemented
[ 168.047410] usb usb2: Not yet implemented
[ 168.047424] usb usb2: Not yet implemented
[ 173.045252] vhci_get_frame_number: 12884 callbacks suppressed
[ 173.045258] usb usb2: Not yet implemented
[ 173.045287] usb usb2: Not yet implemented
[ 173.046275] usb usb2: Not yet implemented
[ 173.046289] usb usb2: Not yet implemented
[ 173.046304] usb usb2: Not yet implemented
[ 173.046314] usb usb2: Not yet implemented
[ 173.047289] usb usb2: Not yet implemented
[ 173.047353] usb usb2: Not yet implemented
[ 173.048239] usb usb2: Not yet implemented
[ 173.048252] usb usb2: Not yet implemented
[ 178.045392] vhci_get_frame_number: 12882 callbacks suppressed
[ 178.045395] usb usb2: Not yet implemented
[ 178.045412] usb usb2: Not yet implemented
[ 178.046750] usb usb2: Not yet implemented
[ 178.046758] usb usb2: Not yet implemented
[ 178.046765] usb usb2: Not yet implemented
[ 178.046770] usb usb2: Not yet implemented
[ 178.047762] usb usb2: Not yet implemented
[ 178.047769] usb usb2: Not yet implemented
[ 178.048583] usb usb2: Not yet implemented
[ 178.048588] usb usb2: Not yet implemented
[ 183.046750] vhci_get_frame_number: 12884 callbacks suppressed
[ 183.046754] usb usb2: Not yet implemented
[ 183.046771] usb usb2: Not yet implemented
[ 183.046776] usb usb2: Not yet implemented
[ 183.047899] usb usb2: Not yet implemented
[ 183.047908] usb usb2: Not yet implemented
[ 183.048727] usb usb2: Not yet implemented
[ 183.048735] usb usb2: Not yet implemented
[ 183.049731] usb usb2: Not yet implemented
[ 183.049738] usb usb2: Not yet implemented
[ 183.049753] usb usb2: Not yet implemented
[ 188.047341] vhci_get_frame_number: 12881 callbacks suppressed
[ 188.047345] usb usb2: Not yet implemented
[ 188.047363] usb usb2: Not yet implemented
[ 188.048960] usb usb2: Not yet implemented
[ 188.048970] usb usb2: Not yet implemented
[ 188.048981] usb usb2: Not yet implemented
[ 188.048986] usb usb2: Not yet implemented
[ 188.049288] usb usb2: Not yet implemented
[ 188.049296] usb usb2: Not yet implemented
[ 188.049301] usb usb2: Not yet implemented
[ 188.050020] usb usb2: Not yet implemented
[ 193.048809] vhci_get_frame_number: 12886 callbacks suppressed
[ 193.048813] usb usb2: Not yet implemented
[ 193.048831] usb usb2: Not yet implemented
[ 193.050082] usb usb2: Not yet implemented
[ 193.050093] usb usb2: Not yet implemented
[ 193.050823] usb usb2: Not yet implemented
[ 193.050831] usb usb2: Not yet implemented
[ 193.050842] usb usb2: Not yet implemented
[ 193.050847] usb usb2: Not yet implemented
[ 193.051816] usb usb2: Not yet implemented
[ 193.051824] usb usb2: Not yet implemented
[ 198.049387] vhci_get_frame_number: 12883 callbacks suppressed
[ 198.049391] usb usb2: Not yet implemented
[ 198.049407] usb usb2: Not yet implemented
[ 198.050379] usb usb2: Not yet implemented
[ 198.050386] usb usb2: Not yet implemented
[ 198.051377] usb usb2: Not yet implemented
[ 198.051384] usb usb2: Not yet implemented
[ 198.052391] usb usb2: Not yet implemented
[ 198.052398] usb usb2: Not yet implemented
[ 198.053392] usb usb2: Not yet implemented
[ 198.053397] usb usb2: Not yet implemented
[ 203.050362] vhci_get_frame_number: 12884 callbacks suppressed
[ 203.050367] usb usb2: Not yet implemented
[ 203.050395] usb usb2: Not yet implemented
[ 203.051440] usb usb2: Not yet implemented
[ 203.051453] usb usb2: Not yet implemented
[ 203.052425] usb usb2: Not yet implemented
[ 203.052440] usb usb2: Not yet implemented
[ 203.053389] usb usb2: Not yet implemented
[ 203.053404] usb usb2: Not yet implemented
[ 203.053418] usb usb2: Not yet implemented
[ 203.053428] usb usb2: Not yet implemented
[ 208.051614] vhci_get_frame_number: 12885 callbacks suppressed
[ 208.051617] usb usb2: Not yet implemented
[ 208.051633] usb usb2: Not yet implemented
[ 208.052641] usb usb2: Not yet implemented
[ 208.052650] usb usb2: Not yet implemented
[ 208.052681] usb usb2: Not yet implemented
[ 208.052687] usb usb2: Not yet implemented
[ 208.053656] usb usb2: Not yet implemented
[ 208.053665] usb usb2: Not yet implemented
[ 208.054670] usb usb2: Not yet implemented
[ 208.054679] usb usb2: Not yet implemented
[ 213.052525] vhci_get_frame_number: 12884 callbacks suppressed
[ 213.052530] usb usb2: Not yet implemented
[ 213.052560] usb usb2: Not yet implemented
[ 213.073403] usb usb2: Not yet implemented
[ 213.074843] usb usb2: Not yet implemented
[ 213.074860] usb usb2: Not yet implemented
[ 213.074978] usb usb2: Not yet implemented
[ 213.074989] usb usb2: Not yet implemented
[ 213.075018] usb usb2: Not yet implemented
[ 213.075029] usb usb2: Not yet implemented
[ 213.075137] usb usb2: Not yet implemented
[ 218.054012] vhci_get_frame_number: 12853 callbacks suppressed
[ 218.054017] usb usb2: Not yet implemented
[ 218.054048] usb usb2: Not yet implemented
[ 218.054521] usb usb2: Not yet implemented
[ 218.055017] usb usb2: Not yet implemented
[ 218.055032] usb usb2: Not yet implemented
[ 218.055096] usb usb2: Not yet implemented
[ 218.055107] usb usb2: Not yet implemented
[ 218.055119] usb usb2: Not yet implemented
[ 218.055998] usb usb2: Not yet implemented
[ 218.056012] usb usb2: Not yet implemented
[ 223.054447] vhci_get_frame_number: 12883 callbacks suppressed
[ 223.054450] usb usb2: Not yet implemented
[ 223.054467] usb usb2: Not yet implemented
[ 223.054488] usb usb2: Not yet implemented
[ 223.054493] usb usb2: Not yet implemented
[ 223.055909] usb usb2: Not yet implemented
[ 223.055917] usb usb2: Not yet implemented
[ 223.056594] usb usb2: Not yet implemented
[ 223.056601] usb usb2: Not yet implemented
[ 223.057559] usb usb2: Not yet implemented
[ 223.057566] usb usb2: Not yet implemented
[ 228.055808] vhci_get_frame_number: 12885 callbacks suppressed
[ 228.055812] usb usb2: Not yet implemented
[ 228.055828] usb usb2: Not yet implemented
[ 228.056791] usb usb2: Not yet implemented
[ 228.056799] usb usb2: Not yet implemented
[ 228.057809] usb usb2: Not yet implemented
[ 228.057816] usb usb2: Not yet implemented
[ 228.057835] usb usb2: Not yet implemented
[ 228.057840] usb usb2: Not yet implemented
[ 228.058827] usb usb2: Not yet implemented
[ 228.058838] usb usb2: Not yet implemented
[ 233.056368] vhci_get_frame_number: 12884 callbacks suppressed
[ 233.056372] usb usb2: Not yet implemented
[ 233.056389] usb usb2: Not yet implemented
[ 233.057719] usb usb2: Not yet implemented
[ 233.057728] usb usb2: Not yet implemented
[ 233.058566] usb usb2: Not yet implemented
[ 233.058572] usb usb2: Not yet implemented
[ 233.059558] usb usb2: Not yet implemented
[ 233.059563] usb usb2: Not yet implemented
[ 233.060540] usb usb2: Not yet implemented
[ 233.060546] usb usb2: Not yet implemented
[ 238.057317] vhci_get_frame_number: 12883 callbacks suppressed
[ 238.057321] usb usb2: Not yet implemented
[ 238.057351] usb usb2: Not yet implemented
[ 238.058319] usb usb2: Not yet implemented
[ 238.058332] usb usb2: Not yet implemented
[ 238.059277] usb usb2: Not yet implemented
[ 238.059289] usb usb2: Not yet implemented
[ 238.060322] usb usb2: Not yet implemented
[ 238.060333] usb usb2: Not yet implemented
[ 238.061327] usb usb2: Not yet implemented
[ 238.061337] usb usb2: Not yet implemented
[ 243.058652] vhci_get_frame_number: 12884 callbacks suppressed
[ 243.058656] usb usb2: Not yet implemented
[ 243.058673] usb usb2: Not yet implemented
[ 243.059825] usb usb2: Not yet implemented
[ 243.059834] usb usb2: Not yet implemented
[ 243.059842] usb usb2: Not yet implemented
[ 243.059847] usb usb2: Not yet implemented
[ 243.060772] usb usb2: Not yet implemented
[ 243.060780] usb usb2: Not yet implemented
[ 243.061239] usb usb2: Not yet implemented
[ 243.061247] usb usb2: Not yet implemented
[ 248.060310] vhci_get_frame_number: 12884 callbacks suppressed
[ 248.060316] usb usb2: Not yet implemented
[ 248.060434] usb usb2: Not yet implemented
[ 248.060462] usb usb2: Not yet implemented
[ 248.061265] usb usb2: Not yet implemented
[ 248.061278] usb usb2: Not yet implemented
[ 248.061370] usb usb2: Not yet implemented
[ 248.061382] usb usb2: Not yet implemented
[ 248.062340] usb usb2: Not yet implemented
[ 248.062354] usb usb2: Not yet implemented
[ 248.063259] usb usb2: Not yet implemented
[ 253.061582] vhci_get_frame_number: 12883 callbacks suppressed
[ 253.061586] usb usb2: Not yet implemented
[ 253.061603] usb usb2: Not yet implemented
[ 253.061612] usb usb2: Not yet implemented
[ 253.061617] usb usb2: Not yet implemented
[ 253.062939] usb usb2: Not yet implemented
[ 253.062947] usb usb2: Not yet implemented
[ 253.062953] usb usb2: Not yet implemented
[ 253.062988] usb usb2: Not yet implemented
[ 253.062994] usb usb2: Not yet implemented
[ 253.063075] usb usb2: Not yet implemented
[ 258.062382] vhci_get_frame_number: 12884 callbacks suppressed
[ 258.062388] usb usb2: Not yet implemented
[ 258.062419] usb usb2: Not yet implemented
[ 258.062583] usb usb2: Not yet implemented
[ 258.062596] usb usb2: Not yet implemented
[ 258.063393] usb usb2: Not yet implemented
[ 258.063407] usb usb2: Not yet implemented
[ 258.064903] usb usb2: Not yet implemented
[ 258.064918] usb usb2: Not yet implemented
[ 258.065376] usb usb2: Not yet implemented
[ 258.065390] usb usb2: Not yet implemented
[ 263.063857] vhci_get_frame_number: 12885 callbacks suppressed
[ 263.063861] usb usb2: Not yet implemented
[ 263.063878] usb usb2: Not yet implemented
[ 263.064840] usb usb2: Not yet implemented
[ 263.064848] usb usb2: Not yet implemented
[ 263.064864] usb usb2: Not yet implemented
[ 263.064869] usb usb2: Not yet implemented
[ 263.065911] usb usb2: Not yet implemented
[ 263.065917] usb usb2: Not yet implemented
[ 263.066940] usb usb2: Not yet implemented
[ 263.066946] usb usb2: Not yet implemented
[ 268.064870] vhci_get_frame_number: 12884 callbacks suppressed
[ 268.064873] usb usb2: Not yet implemented
[ 268.064891] usb usb2: Not yet implemented
[ 268.065870] usb usb2: Not yet implemented
[ 268.065877] usb usb2: Not yet implemented
[ 268.065891] usb usb2: Not yet implemented
[ 268.065896] usb usb2: Not yet implemented
[ 268.066922] usb usb2: Not yet implemented
[ 268.066927] usb usb2: Not yet implemented
[ 268.067956] usb usb2: Not yet implemented
[ 268.067963] usb usb2: Not yet implemented
[ 273.065348] vhci_get_frame_number: 12883 callbacks suppressed
[ 273.065352] usb usb2: Not yet implemented
[ 273.065369] usb usb2: Not yet implemented
[ 273.066404] usb usb2: Not yet implemented
[ 273.066411] usb usb2: Not yet implemented
[ 273.067327] usb usb2: Not yet implemented
[ 273.067335] usb usb2: Not yet implemented
[ 273.068347] usb usb2: Not yet implemented
[ 273.068353] usb usb2: Not yet implemented
[ 273.069354] usb usb2: Not yet implemented
[ 273.069359] usb usb2: Not yet implemented
[ 278.067023] vhci_get_frame_number: 12870 callbacks suppressed
[ 278.067027] usb usb2: Not yet implemented
[ 278.067259] usb usb2: Not yet implemented
[ 278.067266] usb usb2: Not yet implemented
[ 278.068306] usb usb2: Not yet implemented
[ 278.068313] usb usb2: Not yet implemented
[ 278.068321] usb usb2: Not yet implemented
[ 278.068334] usb usb2: Not yet implemented
[ 278.069337] usb usb2: Not yet implemented
[ 278.069343] usb usb2: Not yet implemented
[ 278.070339] usb usb2: Not yet implemented
[ 283.067490] vhci_get_frame_number: 12882 callbacks suppressed
[ 283.067494] usb usb2: Not yet implemented
[ 283.067510] usb usb2: Not yet implemented
[ 283.067542] usb usb2: Not yet implemented
[ 283.067547] usb usb2: Not yet implemented
[ 283.068899] usb usb2: Not yet implemented
[ 283.068907] usb usb2: Not yet implemented
[ 283.069457] usb usb2: Not yet implemented
[ 283.069464] usb usb2: Not yet implemented
[ 283.070474] usb usb2: Not yet implemented
[ 283.070480] usb usb2: Not yet implemented
[ 288.068619] vhci_get_frame_number: 12885 callbacks suppressed
[ 288.068623] usb usb2: Not yet implemented
[ 288.068639] usb usb2: Not yet implemented
[ 288.069742] usb usb2: Not yet implemented
[ 288.069750] usb usb2: Not yet implemented
[ 288.070596] usb usb2: Not yet implemented
[ 288.070602] usb usb2: Not yet implemented
[ 288.071579] usb usb2: Not yet implemented
[ 288.071585] usb usb2: Not yet implemented
[ 288.072746] usb usb2: Not yet implemented
[ 288.072755] usb usb2: Not yet implemented
[ 293.070181] vhci_get_frame_number: 12886 callbacks suppressed
[ 293.070184] usb usb2: Not yet implemented
[ 293.070201] usb usb2: Not yet implemented
[ 293.071314] usb usb2: Not yet implemented
[ 293.071323] usb usb2: Not yet implemented
[ 293.072311] usb usb2: Not yet implemented
[ 293.072318] usb usb2: Not yet implemented
[ 293.073342] usb usb2: Not yet implemented
[ 293.073349] usb usb2: Not yet implemented
[ 293.073357] usb usb2: Not yet implemented
[ 293.073362] usb usb2: Not yet implemented
[ 298.070927] vhci_get_frame_number: 12881 callbacks suppressed
[ 298.070935] usb usb2: Not yet implemented
[ 298.070951] usb usb2: Not yet implemented
[ 298.070962] usb usb2: Not yet implemented
[ 298.070967] usb usb2: Not yet implemented
[ 298.071937] usb usb2: Not yet implemented
[ 298.071945] usb usb2: Not yet implemented
[ 298.072953] usb usb2: Not yet implemented
[ 298.072960] usb usb2: Not yet implemented
[ 298.073895] usb usb2: Not yet implemented
[ 298.073900] usb usb2: Not yet implemented
[ 303.072203] vhci_get_frame_number: 12884 callbacks suppressed
[ 303.072206] usb usb2: Not yet implemented
[ 303.072222] usb usb2: Not yet implemented
[ 303.072228] usb usb2: Not yet implemented
[ 303.072564] usb usb2: Not yet implemented
[ 303.073186] usb usb2: Not yet implemented
[ 303.073193] usb usb2: Not yet implemented
[ 303.074212] usb usb2: Not yet implemented
[ 303.074218] usb usb2: Not yet implemented
[ 303.075217] usb usb2: Not yet implemented
[ 303.075223] usb usb2: Not yet implemented
[ 308.072392] vhci_get_frame_number: 12882 callbacks suppressed
[ 308.072395] usb usb2: Not yet implemented
[ 308.072411] usb usb2: Not yet implemented
[ 308.073698] usb usb2: Not yet implemented
[ 308.073705] usb usb2: Not yet implemented
[ 308.074637] usb usb2: Not yet implemented
[ 308.074646] usb usb2: Not yet implemented
[ 308.074657] usb usb2: Not yet implemented
[ 308.074662] usb usb2: Not yet implemented
[ 308.074667] usb usb2: Not yet implemented
[ 308.075814] usb usb2: Not yet implemented
[ 313.073863] vhci_get_frame_number: 12885 callbacks suppressed
[ 313.073866] usb usb2: Not yet implemented
[ 313.073882] usb usb2: Not yet implemented
[ 313.075299] usb usb2: Not yet implemented
[ 313.075308] usb usb2: Not yet implemented
[ 313.075327] usb usb2: Not yet implemented
[ 313.075332] usb usb2: Not yet implemented
[ 313.076664] usb usb2: Not yet implemented
[ 313.076671] usb usb2: Not yet implemented
[ 313.077525] usb usb2: Not yet implemented
[ 313.077531] usb usb2: Not yet implemented
[ 318.074949] vhci_get_frame_number: 12884 callbacks suppressed
[ 318.074952] usb usb2: Not yet implemented
[ 318.074968] usb usb2: Not yet implemented
[ 318.075929] usb usb2: Not yet implemented
[ 318.075936] usb usb2: Not yet implemented
[ 318.076938] usb usb2: Not yet implemented
[ 318.076950] usb usb2: Not yet implemented
[ 318.077974] usb usb2: Not yet implemented
[ 318.077985] usb usb2: Not yet implemented
[ 318.077996] usb usb2: Not yet implemented
[ 318.078000] usb usb2: Not yet implemented
Additionally, the playback sources are still flashing in and out.
Certainly looks like something is broken. Thanks again!
what is the USB device connected to your sys-audio ? from the logs it seems that a USB device is not handled correctly, or a usb PCI devic . can you do also do a qvm-prefs sys-audio
Here is the output of “qvm-prefs sys-audio” in dom0:
audiovm D sys-audio
auto_cleanup D False
autostart - True
backup_timestamp - 1776723903
debug D False
default_dispvm D audio-app
default_user D user
dispid - 9030
dns D
gateway D
gateway6 D
guivm D dom0
icon D dispvm-gray
include_in_backups D True
installed_by_rpm D False
ip D
ip6 D
kernel D 6.18.19-1.fc37
kernelopts D swiotlb=2048
keyboard_layout D us++
klass D DispVM
label - gray
mac D 00:16:3e:5e:6c:00
management_dispvm D default-mgmt-dvm
maxmem - 0
memory - 800
name - sys-audio
netvm - None
provides_network - False
qid - 78
qrexec_timeout D 60
shutdown_timeout D 60
start_time D 1777686987.01
stubdom_mem U
stubdom_xid D 47
template - audio-app
updateable D False
uuid - 14449ff6-fc86-4f2b-b1f4-16360fd503c0
vcpus D 2
virt_mode - hvm
visible_gateway D
visible_gateway6 D
visible_ip D
visible_ip6 D
visible_netmask D
xid D 46
Thanks once more! @neowutran
Somehow totally missed the initial question, or forgot while reading results.
It is an “Ifi zen dac v2”
Sorry about that and thank you.
Sadly, I can’t tell you the solution.
If I repeat everything:
You have a “sys-audio” dispvm based on a “audio-app” AppVM based on a “audio-template” TemplateVM.
And it work. If you just switch the “audio-template” to a more recent fedora template ( and installing the sames packages), then it doesn’t work anymore as you described. (If I am wrong, please tell).
Then the only thing I can think of, is a regression in the package handling USB / Audio for your specific hardware. If that the case, you should search what is the package responsible for that. You could try to upgrade/downgrade this specific package in the templateVM to confirm. And once you have identified the package+version, will need to create an issue for this package / find what modification have been made that cause your issue.
I see, so it might be an issue with the USB / Audio related software.
I will try to diagnose the situation at some point and open an issue related to it.
Take care! @neowutran
For anyone curious, I took the easy way out and tried just using Debian instead of Fedora and the issues are not present. Maybe sometime I will still submit a bug report…eventually…
This is a wonderful guide! I was only able to use this for Bluetooth due to PCI passthrough limitations but that’s OK for me.
And I didn’t see it mentioned anywhere how to disable this, but to disable, you can run the following in dom0:
qubes-prefs default_audiovm dom0
I’m a bit lost here… how would I be able to use Bluetooth headphones if my sys-usb uses the USB controller that’s tied to my Bluetooth (and I use a Bluetooth mouse with sys-usb too)? If I install an audio qube, would it still be practical for my use case?
You could make your sys-usb a sys-audio too, that would be the optimal solution for your setup I think. Or maybe a more custom setup where you keep the sys-usb, create a new sys-audio, pass the bluetooth adaptater to sys-audio (it is usually a “USB” device even when it is internal ), and give the mouse/keyboard permission to sys-audio
But this way I will lose the security of my audio and especially mic… no?
How would I use usb devices I connect to the laptop physically then?
Yes, a malicious USB device could have an impact on your other USB device.
But if you need bluetooth headphone, you don’t have much other choices. Except if you have another USB controller and another bluetooth controller to isolate them in another qube.
Same way, you would need to attach the “bluetooth” device to sys-audio. But that wouln’t solve the “malicious usb device” case either. It just should be better at isolating your other usb device from malicious bluetooth devices
sys-audio working locally but client qubes show Dummy Output (Qubes 4.3.1)
System Info
- Qubes OS: 4.3.1
- Audio hardware: Intel Raptor Lake High Definition Audio (ALC897), onboard
- GPU: NVIDIA GeForce RTX 5060
Setup
I followed the official community guide by @neowutran to set up sys-audio manually.
Qube structure:
audio-template: cloned fromfedora-44-minimalaudio-app: AppVM based onaudio-template, marked astemplate_for_dispvmssys-audio: named DispVM based onaudio-app, HVM, no network
Packages installed in audio-template:
pipewire-qubes qubes-audio-daemon pavucontrol qubes-core-admin-client qubes-usb-proxy alsa-utils pasystray
PCI passthrough in dom0:
qvm-pci attach --persistent sys-audio dom0:00_1f.3 --option no-strict-reset=True
Global setting:
qubes-prefs default_audiovm sys-audio
What works
sys-audiostarts successfully (Running, DispVM, HVM)aplay -lin sys-audio showscard 0: PCH [HDA Intel PCH], device 0: ALC897 Analogspeaker-test -t sine -f 440 -l 1in sys-audio produces audible soundsystemctl --user status pipewirein sys-audio: active (running)qubesdb-read /qubes-audio-domain-xidin client qube returns4qvm-ls sys-audioshows XID =4— XID matchespw-cli info all | grep qubesconfirmslibpipewire-module-qubesis loaded/usr/share/pipewire/pipewire.conf.d/30_qubes.confexists and is correct
The Problem
All client qubes (Kicksecure-18 based, fedora-44-xfce based) show Dummy Output in wpctl status:
Audio
├─ Devices:
├─ Sinks:
│ * 38. Dummy Output [vol: 1.00]
├─ Sources:
Running systemctl --user restart pipewire pipewire-pulse in client qubes does not help.
qubesdb-read /qubes-audio-domain-xid returns 4 in client qubes, matching sys-audio XID.
However, /etc/qubes/audio-vm-xid does not exist in client qubes.
The vchan connection appears to be silently failing — no errors in journalctl --user -u pipewire in client qubes.
Similar existing report
This appears identical to:
Question
Is this a known regression in Qubes 4.3 when using a non-dom0 AudioVM? Is there any workaround?
Thank you.
This worked great with a debian-13-minimal template and jack, thank you very much.
Just as addition:
After successful configuration of sys-audio, dom0 volume systray > Audio mixer > Output in menu bar from now on shows “Dummy Output” and has no function anymore. Instead the volume sys-tray from sys-audio should be used (if having pasystray installed). Hence it is best to remove dom0 volume systray entirely to avoid confusion.
How to re-bind keyboard multimedia keys
Unregister current shortcuts (dom0 volume systray → Properties)
General → Behavior → Enable keyboard shortcuts for volume control → Uncheck
Media Players → Control Playback of Media Players → Uncheck
Re-register shortcuts (Keyboard → Application shortcuts)
“Audio raise volume” key → qvm-run sys-audio -- amixer sset Master 2%+
“Audio lower volume” key → qvm-run sys-audio -- amixer sset Master 2%-
“Audio mute” key → qvm-run sys-audio -- amixer sset Master toggle
See also docs about qvm-run.
Just upgraded in place from 4.2 to 4.3 and my sys-audio wouldn’t want to work with my win 11 qube, so I had to drop in addition to existing entries this whole pile of entries to my 50-sys-audio policy:
admin.vm.feature.CheckWithTemplate +gui sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.CheckWithTemplate +gui-emulated sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.device.block.Available * sys-audio dom0 allow target=dom0
admin.label.Get +blue sys-audio dom0 allow target=dom0
admin.label.Index +blue sys-audio dom0 allow target=dom0
admin.vm.feature.CheckWithTemplate +rpc-clipboard sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.CheckWithTemplate +gui-allow-fullscreen sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.property.Get +virt_mode sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-allow-fullscreen sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-allow-fullscreen sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-allow-fullscreen sys-audio dom0 allow target=dom0
admin.vm.feature.Get +gui-default-override-redirect-protection sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-override-redirect-protection sys-audio dom0 allow target=dom0
admin.vm.feature.Get +gui-override-redirect-protection sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-override-redirect sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-override-redirect sys-audio dom0 allow target=dom0
admin.vm.feature.Get +gui-allow-utf8-titles sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-allow-utf8-titles sys-audio dom0 allow target=dom0
admin.vm.feature.Get +gui-secure-copy-sequence sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-secure-copy-sequence sys-audio dom0 allow target=dom0
admin.vm.feature.Get +gui-secure-paste-sequence sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-secure-paste-sequence sys-audio dom0 allow target=dom0
admin.vm.feature.Get +gui-windows-count-limit sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-windows-count-limit sys-audio dom0 allow target=dom0
admin.vm.feature.Get +gui-trayicon-mode sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-trayicon-mode sys-audio dom0 allow target=dom0
admin.vm.feature.Get +gui-startup-timeout sys-audio @tag:audiovm-sys-audio allow target=dom0
admin.vm.feature.Get +gui-default-startup-timeout sys-audio dom0 allow target=dom0
and after rebooting the Qubes, my win 11 qube got its audio. Unfortunately, during this I didn’t test if sys-audio worked for other non-gui qubes.
I am not sure if allowing was smart, or suppressing the messages would do the job too.
Also, maybe it was good idea to replace “… dom0 allow target=dom0” entries to “@adminVM allow target=dom0” since I have other adminVMs, sys-gui-gpu for example, but still haven’t tested, so you might want to consider this fact too.
Cheers
This works, but because qvm-run is what it it, it’s slow and prone to issues under load/when using a “knob” for changing the volume.
Instead, I’d recommend using qrexec-client. Here’s an example that uses pactl
qrexec-client -t -e -d sys-audio -- DEFAULT:'pactl set-sink-volume @DEFAULT_SINK@ +5%'
qrexec-client -t -e -d sys-audio -- DEFAULT:'pactl set-sink-volume @DEFAULT_SINK@ -5%'
qrexec-client -t -e -d sys-audio -- DEFAULT:'pactl set-sink-mute @DEFAULT_SINK@ toggle'
qrexec-client -t -e -d sys-audio -- DEFAULT:'pactl set-source-mute @DEFAULT_SOURCE@ toggle'
same here. clean 4.3.1 install, sys-audio created using instructions in this thread, which used to work fine on 4.2. now client qubes won’t connect to sys-audio, wpctl status only shows Dummy Output. setting dom0 as audiovm is still fine. does anyone know how to get this working?
