I followed the comment by @dom0 here: Debian-minimal template for sys-audio - #47 by dom0
At the end of it I was able to setup a sys-audio VM without any issues (I didn’t make it a disposable VM however, just a regular AppVM). Passthrough works although I had some difficulty in getting it to work at first.
However there’s no sound and videos don’t play on say Firefox in any VM. When I run pavucontrol from sys-audio I do see the VMs name in Playback, but for some reason no sound is going through.
I tried to add this line to /etc/modprobe.d/50-alsa.conf in dom0 as suggested in Setting up an audio VM - #24 by hamenarin but still no sound.
options snd_hda_intel enable=1 index=0 power_save=0
Would really appreciate it if someone could help me debug this issue.
dom0
June 14, 2022, 10:45pm
2
What do you see in Output Devices?
When I wrote about needing to start and shutdown sys-audio for it to work, I always checked Output Devices in pavucontrol.
If it shows:
Built-in Audio Analog Stereo
then I know that sys-audio can play sound.
If it instead shows:
then I know that sys-audio cannot play sound.
When Output Devices shows Dummy Output,
Input Devices shows:
No input devices available
and Configuration shows:
No cards available for configuration
So for me on my Librem 14, this issue was only fixed by rebooting until it worked.
Output Devices shows: Qubes vchan Output (plugged in).
I did reboot many times but it didn’t work.
Edit: Also the audio device is detected correctly in sys-audio:
user@sys-audio:~$ lspci -v | grep "Audio"
00:06.0 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
Here’s the output of journalctl PrivateBin
