Background
Hello, after a pretty horrid experience attempting to install CachyOS (Failed to run pacstrap will haunt me in my dreams), I have decided to try and install QubesOS onto my currently bricked PC. Before this it was running Windows 11 and I could arguably go back, but I’d rather try this first.
I said before I thought it was too complicated to try and use QubesOS for gaming, but it should be an interesting learning experience none the less.
Install Set-up
My set-up is a corsair DIY build kit, similar to this one from their site:
CPU: Intel i9-14900k
GPU: Nvidia RTX 4080
RAM: 32GB DDR5 5600MHz
USB with QubesOS 4.3 ISO flashed with BalenaEtcher
Wired connection to router
ISO drive plugged into motherboard
Monitor plugged into GPU (Did not detect from motherboard)
Installation Attempts
First Attempt: Normal Run
Tried install normally, turned off secure boot and attempted to install with option “Test this media and install QubesOS”. Installation failed.
Errors
- Firmware Bug: CPU APIC ID mismatch
- ACPI BIOS Error (bug):
- I had this issue when installing another OS, possible related to issues with MSI motherboards not conforming to UEFI specifications which fails in GRUB boot loader
- From the look of the code line, it looks like QubesOS might use the systemd work around, but I cannot confirm this
- tmpfs: Unsupported parameter ‘huge’
- 2 nouveau errors
- These are issues already mentioned with the documentation, issue is with Nvidia card with known work arounds
Second Attempt: BIOS edits
Tried to install after changing the BIOS mode, of which I have the option of UEFI which I used in previous attempt, and CSM which from what I read should be ‘legacy mode’. Installation failed.
Errors
- Same as above
- I had hoped the BIOS mode change would fix the ACPI error, but it did not
Third Attempt: Working on it
This is the part where the guide suggests handling nouveau errors.
From the documents:
These errors may also occur due to an incompatible Nvidia graphics card. If you have one, follow the following instructions:
- Disable secure/fast boot and use legacy mode
- Enter GRUB, move the selection to the first choice, and then press the Tab key.
- Now, you are in edit mode. Move the text cursor with your arrow key and after
kernel=line, add:
nouveau.modeset=0 rd.driver.blacklist=nouveau video=vesa:offIf the above code doesn’t fix the problem, replace it with:
noexitboot=1 modprobe.blacklist=nouveau rd.driver.blacklist=nouveau --- intitrd.img
The documents also direct you to a community guide.
Errors
I haven’t attempted it yet and am looking for feedback.
- I’m assuming all of this is done from the live version running from the USB and not installed yet on my drive
- From the documentation, it says to use the
Tabkey, I’m assuming this is outdated and is now theekey, unless there is something I’m missing - After hitting the
ekey, I do not see anykernel=line, I’m assuming place these above the lastmodule2line. - From the community guide, in the EFI section, is this while GRUB is up, or after attempting install than using a TTY? Somewhat confusing usage of dom0 to me as I am not officially in QubesOS, just the image
Notes and Thoughts
So far hasn’t been anything too unexpected, but I do want to say how much I love the quality documentation of QubesOS. They really do a good job of solving issues and keeping the information easy to find, even if I’m not always smart enough to use it ![]()
Any and all help appreciated, otherwise I might have to tuck tail and return to Windows. Also considering the issues with other OS installs, I performed hardware checks on RAM and my drive to make sure there were no issues.
