Is there any recent guide on dwm implementation for qubes?
This one is 3 years old, maybe still relevant.
https://github.com/3o14r473/GUIDE_how-to-install-dwm-in-qubesos
Tried this but it is outdated and the patches are not applicable.
Did this and followed all the steps and here is what I got after rebooting and login:
No any menus nor any thing is accessible.
I can’t help you, I am not using dwm. You can try i3 or qtile.
https://github.com/3hhh/qubes-qtile
Can you check the topic I opened here: Unable to setup GUI domian
If you can provide any help.
Hello again @quber , I am trying to follow this guide so I made a GPU GUI VM successfully but for the first step in Installation procedures I do not know if should I run it in dom0 or GPU GUI VM but whenever I start the VM the PC screen turns black for couple of seconds then shutdown.
I don’t understand why you use a GPU GUI VM? this is not yet stable and maybe doesn’t work with your hardware.
I would just compile dwm in a VM and than transfer it to Dom0.
Because I am concerned about security, and do not want anything to run in dom0.
Also this discussion would give another reason for this specific case:
I can’t help you.
https://forum.qubes-os.org/t/how-to-enable-the-new-gui-vm/2631/21
