Another bluetooth headphone issue..help,please
Hello Team,
First a big thank you for the distro… absolutely love it that now is my the default home&work OS across devices and the way i work and play.
Need your help: managed to get the bluetooth working as a hardware and settings but cannot play the output to the bluetoothheadsets,even if the status is connected.
Cant’ see it as a valid output in the audio mixer either,which i slinked to dom0 but not “personal”.
Plays fine on the built-in speaker from a “personal” qube.
Also,if i understood corectly,i may need to setup a new sys-audio qube,fedora, which will be permanent as the curent sys-usb is a disposable and “forgets” the link to headsets each and every restart.
What i’m i missing here ?
Thanks in advance.
PS
found this post here,sorry !
I have completed lost it…
I can send & receive files with my Android phone via bluetooth
I can see the headphone connected but cannot “divert” the audio stream to it.
In order to be 100% away from MS$,need to use Teams online…
I will have to get a wired headset…hmmm !
Apologise.
Qube with bluetooth connected headphones must be configured as default_audiovm and have installed pipewire and pulse audio services.
By default it’s dom0.
Installing bluetooth stack and connecting bluetooh devices to dom0 is not advised.
You could make sys-usb your audio service but that’s also not advised.
Make sys-audio then, connect headphones there and youre set.
