Hi everybody.
I used qubes previously and I’m trying to do a fresh installation with the 4.1.0
All runs ok untill I restart the computer and I’m prompted to the final configuration steps:
All the templates are completely missing.
I was used to the “noob” qubes installation where since the beginning you had all the templates and the basic VMs (sys-net, sys-firewall, sys-whonix etc).
Now I’m stuck with an installation where I have only dom0 and nothing else, unable to connect to the network and to restore from backups.
I verified the iso with PGP and all seems fine
I tried to change the installation media (I’m installing via USB on the pc ssd)
I tried to change mirror for the iso download
I tried to write both the USB’s I’m using for the installation both in ISO and dd mode in Rufus
I tried to search deeply about this issue but nothing came up
I’m not able to copy the logs since I can’t attach any usb device to dom0 in this situation.
All I can tell is a message that comes up at the end of the final configuration:
“Qubes initial configuration failed. Login to the system and check /var/log/salt/minion for details. You can retry configuration by calling ‘sudo qubesctl --all state.highstate’ in dom0 (you will get detailed state there)”
Someone is experiencing the same issue?
Thank you.
