So now it’s the third time that Qubes got “broken”.
Here is what I found out in emergency rescue mode:
lvconvert --repair /dev/mapper/qubes_dom0-root–pool →
WARNING: Sum of all thin volume sizes (<9.04 TiB) exceeds the size of thin pools and the size of whole volume group (<1.82 TiB).
WARNING: You have not turned on protection against thin pools running out of space.
WARNING: Set activation/thin_pool_autoextend_threshold below 100 to trigger automatic extension of thin pools before they get full.
WARNING: LV qubes_dom0/root-pool_meta8 holds a backup of the unrepaired metadata. Use lvremove when no longer required.
My nvme has 2 TB. According to the "lvs"column “Lsize” however, I have a total of 10 TiB in use.
How can that happen?
I’ve not figured out how this can actually be fixed either… first time (a year ago) I imported backups, this time I’ve not done backups in 2 weeks, so that is not great.
My current thought on how to fix this is:
- backup the content of all VMs (using file system access with rsyc) onto folders on an external HDD
- reinstall Qubes with ZFS RAID-Z1 instead of LVM
- create the VMs and templates etc. again in Qube with same size
- delete and overwrite the content of each VM with the content of the backup
However, the important question remains: how can this happen in the first place? Based on the WARNINGs it sounds like it is “my” fault? If so: why do I (long time developer, no linux pro) / any user without deep LVM knowledge / any common user who likes privacy / any linux expert need to set these protections manually? I have NO CLUE on that, and as a developer I think that is something that should be set automatically by Qubes / constantly checked to prevent this case - and not leave it up to the end users.
And please let us spare the “you are responsible yourself for backups!” kind of comments - they are not the answer to the question/the root cause. Qubes has no automated backup policy and backups for all my VMs would take a 1/2 day probably. So that is not an option. But:I use nextcloud to sync the important files, but that is not enough.
Thanks!
