Hi Community
I became a huge fan of qubes since I started to use it a few months ago. Now, I wanted to use a Yubikey for better auth security. However, it does not work…
Obviously, I followed the Yubikey Guide: YubiKey | Qubes OS
When I now try to login with my selected password, nothing happens and the screenlocker says just failed login - my Yubikey does not react as well.
My guess: I run sudo dnf install ykpers in the template of sys-usb (as step 1 in the guide). However, this is not persistently saved since the template for the sys-usb qube is the disposable fedora-dvm (since installation of qubes). So how should my sys-usb even use ykpers? And if that is the reason, what could I do to solve the problem? Whole new sys-usb qube?
I am not familiar with USB qube topics very much… so I would search for the easiest fix. And I apologize in advance when I miss something here…
