Xvdi is mapped to /mnt/removable
Any idea why xvdi is alway mapped to /mnt/removable?
Will there be any issues if I remove the line from TemplateVM? I prefer the defaults provided by udisks2.
I have to say I can’t find any good documentation on that line, but I think Enable more than one block device in VM · Issue #419 · QubesOS/qubes-issues · GitHub is partially related?
Hmm, that was added 15 years ago in R2. Seems like a conventional location?
I’m not aware of anything that depends on that /etc/fstab line, and a GitHub code search didn’t bring up anything obvious.
However, if you modify the file at all, it will no longer automatically pick up updates to it. Maybe masking or overriding the mnt-removable.mount systemd unit in the TemplateVM instead would be enough to make a difference for udisks2?
