Clodius
1
(xfce4-panel:157112): xfce4-panel-CRITICAL **: 08:32:43.072: panel-window.c:3086 (panel_window_thaw_autohide): expression 'window->autohide_block > 0' failed.
Not enough memory to start domain 'disp7399'
File "/usr/bin/qvm-run", line 5, in <module>
sys.exit(main())
File "/usr/lib/python3.8/site-packages/qubesadmin/tools/qvm_run.py", line 335, in main
dispvm.cleanup()
File "/usr/lib/python3.8/site-packages/qubesadmin/vm/__init__.py", line 410, in cleanup
self.kill()
File "/usr/lib/python3.8/site-packages/qubesadmin/vm/__init__.py", line 126, in kill
self.qubesd_call(self._method_dest, 'admin.vm.Kill')
File "/usr/lib/python3.8/site-packages/qubesadmin/base.py", line 74, in qubesd_call
return self.app.qubesd_call(dest, method, arg, payload,
File "/usr/lib/python3.8/site-packages/qubesadmin/app.py", line 748, in qubesd_call
return self._parse_qubesd_response(return_data)
File "/usr/lib/python3.8/site-packages/qubesadmin/base.py", line 109, in _parse_qubesd_response
raise exc_class(format_string, *args)
qubesadmin.exc.QubesVMNotFoundError: No such domain: 'disp7399'
(xfce4-panel:157112): xfce4-panel-CRITICAL **: 09:39:07.691: panel-window.c:3086 (panel_window_thaw_autohide): expression 'window->autohide_block > 0' failed.
(xfce4-panel:157112): xfce4-panel-CRITICAL **: 09:40:06.684: panel-window.c:3086 (panel_window_thaw_autohide): expression 'window->autohide_block > 0' failed.
File "/usr/bin/qvm-sync-appmenus", line 11, in <module>
load_entry_point('qubesdesktop==4.1.11', 'console_scripts', 'qvm-sync-appmenus')()
File "/usr/lib/python3.8/site-packages/qubesappmenus/receive.py", line 398, in main
new_appmenus = retrieve_appmenus_templates(vm, use_stdin=use_stdin)
File "/usr/lib/python3.8/site-packages/qubesappmenus/receive.py", line 374, in retrieve_appmenus_templates
new_appmenus = get_appmenus(vm if not use_stdin else None)
File "/usr/lib/python3.8/site-packages/qubesappmenus/receive.py", line 154, in get_appmenus
raise qubesadmin.exc.QubesException(
qubesadmin.exc.QubesException: Error getting application list
